  3. No messages from PX4
2 Posts 2 Posters 697 Views
  • B Offline
    B Offline
    bendraper
    Currently using a VOXL 2 connected to a CubeOrange flight controller over UART 1 (using M0125) and can't seem to successfully get a link. When I try to run the vision-px4 server, I get "WARNING: connected to voxl-mavlink-server but no messages from PX4."
    Running systemctl status voxl-vision-px4, I get the following
    voxl2:/$ systemctl status voxl-vision-px4
    ● voxl-vision-px4.service - voxl-vision-px4
       Loaded: loaded (/usr/bin/voxl-vision-px4; enabled; vendor preset: enabled)
       Active: inactive (dead) since Wed 2022-11-30 21:04:56 UTC; 22min ago
     Main PID: 2284 (code=exited, status=0/SUCCESS)
    Nov 30 21:04:56 m0054 voxl-vision-px4[2284]: exiting QGC udp listener thread
    Nov 30 21:04:56 m0054 voxl-vision-px4[2284]: exiting localhost udp listener thread
    Nov 30 21:04:56 m0054 voxl-vision-px4[2284]: udp_mavlink stopped
    Nov 30 21:04:56 m0054 voxl-vision-px4[2284]: Stopping uart mavlink module
    Nov 30 21:04:56 m0054 voxl-vision-px4[2284]: waiting for px4 mavlink timer thread to join
    Nov 30 21:04:56 m0054 voxl-vision-px4[2284]: Stopping px4 monitor
    Nov 30 21:04:56 m0054 voxl-vision-px4[2284]: closing remaining client pipes
    Nov 30 21:04:56 m0054 voxl-vision-px4[2284]: closing remaining server pipes
    Nov 30 21:04:56 m0054 voxl-vision-px4[2284]: Removing PID file
    Also my mavlink server configuration is as follows
    px4_uart_bus:               1
    px4_uart_baudrate:          921600
    udp_port_to_px4:            14552
    udp_port_from_px4:          14552
    external_fc:                1
    Any ideas?
    • James StrawsonJ Offline
      James Strawson
      Have you used an oscilloscope to probe the line from the flight controller to VOXL2 to make sure the flight controller is sending data at the correct baudrate? Also note that the logic level of that UART connector on M0125 is 3.3V, I'm not sure if that matches the expected logic level of the port you are using on the CubeOrange.
      Also note PX4 requires some serial port configuration. We normally use mavlink channel 1 with the Telem2 port on our flight core set to 921600 and 'onboard' mode. This translates to the following px4 param settings, note that yours will most likely be different due to using a different flight controller in a different configuration.
      MAV_1_CONFIG 102
      MAV_1_FORWARD 0
      MAV_1_MODE 2
      MAV_1_RATE 0
      SER_TEL2_BAUD 921600
      • J jay.miller referenced this topic on
