  3. ERROR: Camera 1 failed to find supported snapshot config
1 Posts 1 Posters 369 Views
  • wilkinsafW Offline
    wilkinsafW Offline
    wilkinsaf
    wrote on last edited by wilkinsaf
    Hello, I get the following error when starting voxl-camera-server
    voxl2:/$ voxl-camera-server
    ------ voxl-camera-server: Starting camera server
    	Started Camera: tracking
    ERROR: Camera 1 failed to find supported snapshot config: 3840x2160
    Encountered error starting camera: hires, exiting
    	Stopped Camera: tracking
    This error disappears when I change "/etc/modalai/voxl-camera-server.conf" so that the hires camera has a snapshot width X height of 640 X 480 respectively.
            "version":      0.1,
            "cameras":      [{
                            "name": "tracking",
                            "enabled":      true,
                            "frame_rate":   30,
                            "type": "ov7251",
                            "camera_id":    0,
                            "ae_desired_msv":       60,
                            "ae_filter_alpha":      0.600000023841858,
                            "ae_ignore_fraction":   0.20000000298023224,
                            "ae_slope":     0.05000000074505806,
                            "ae_exposure_period":   1,
                            "ae_gain_period":       1
                            "name": "hires",
                            "enabled":      true,
                            "frame_rate":   30,
                            "type": "imx214",
                            "camera_id":    1,
                            "preview_width":        640,
                            "preview_height":       480,
                            "snapshot_width":       640,
                            "snapshot_height":      480
    So, I thought I would check to see what possible resolutions I could stream from these cameras. I ran "voxl-camera-server -l" and see the following
    oxl2:/$ voxl-camera-server -l
    Note: This list comes from the HAL module and may not be indicative
    	of configurations that have full pipelines
    Number of cameras: 3
    Stats for camera: 0:
    ANDROID_SCALER_AVAILABLE_RAW_SIZES:
    	640x480,
    ANDROID_SCALER_AVAILABLE_PROCESSED_SIZES:
    	 640x 480,
    ANDROID_SENSOR_INFO_SENSITIVITY_RANGE
    	min = 54
    	max = 431
    ANDROID_SENSOR_MAX_ANALOG_SENSITIVITY
    	431
    ANDROID_SENSOR_INFO_EXPOSURE_TIME_RANGE
    	min = 0ns
    	max = 17942880ns
    Stats for camera: 1:
    	640x480,
    	 640x 480,
    	min = 54
    	max = 431
    	431
    	min = 0ns
    	max = 17942880ns
    Stats for camera: 2:
    	640x480,
    	 640x 480,
    	min = 54
    	max = 431
    	431
    	min = 0ns
    	max = 17942880ns
    It seems like I can only stream 640 X 480 from the cameras.
    I tried staging and dev releases and found the same issue. Here is my current version
    voxl2:/$ voxl-version
    system-image: 1.3.1-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Tue Aug 2 05:23:05 UTC 2022 4.19.125
    hw version:   M0054
    voxl-suite:   0.8.1
    Packages:
    Repo:  http://voxl-packages.modalai.com/ qrb5165 dev
    Last Updated: 2022-10-14 18:40:46
    List:
    	libmodal-cv              0.2.3-202209222148
    	libmodal-exposure        0.0.7-202204081652
    	libmodal-journal         0.2.1-202210062030
    	libmodal-json            0.4.3-202209281920
    	libmodal-pipe            2.6.0-202210052046
    	libqrb5165-io            0.1.0-202204072150
    	libvoxl-cutils           0.1.1-202210072352
    	mv-voxl                  0.1-r0
    	qrb5165-bind             0.1-r0
    	qrb5165-dfs-server       0.1.0-202210072209
    	qrb5165-imu-server       0.5.0-202210122008
    	qrb5165-slpi-test-sig    01-r0
    	qrb5165-system-tweaks    0.1.5-202210132034
    	qrb5165-tflite           2.8.0-2-202210071637
    	voxl-bind                0.0.1-202205182247
    	voxl-camera-calibration  0.2.3-202209282205
    	voxl-camera-server       1.1.0
    	voxl-cpu-monitor         0.3.0-202210112348
    	voxl-docker-support      1.2.4-202204112218
    	voxl-jpeg-turbo          2.1.3-4-202210072353
    	voxl-libgphoto2          0.0.4-202204111958
    	voxl-libuvc              1.0.7-202210072357
    	voxl-logger              0.3.4-202209082335
    	voxl-mavlink             0.1.0-202207052152
    	voxl-mavlink-server      0.2.0-202209022350
    	voxl-modem               0.16.1-202210071715
    	voxl-mongoose            7.7.0-1-202210072105
    	voxl-mpa-to-ros          0.3.6-202210052049
    	voxl-mpa-tools           0.7.6-202210131904
    	voxl-opencv              4.5.5-1-202210072305
    	voxl-portal              0.4.1-202210122031
    	voxl-px4                 1.12.29-202210120000
    	voxl-px4-imu-server      0.1.2-202205131833
    	voxl-qvio-server         0.8.2-202209282248
    	voxl-streamer            0.4.1-202210080136
    	voxl-suite               0.8.1
    	voxl-tag-detector        0.0.4-202206302112
    	voxl-tflite-server       0.3.1-202209141826
    	voxl-utils               1.2.2-202210062045
    	voxl-uvc-server          0.1.2-202210121726
    	voxl-vision-px4          1.4.0-202210072317
    	voxl2-system-image       1.3.1-r0
    	voxl2-wlan               1.0-r0
    Was wondering if anyone else has seen this. Thanks!
