  3. Issues with indoor mapping speed and path planning with voxl-mapper
1 Posts 1 Posters 523 Views
  • A Offline
    ahmed-mustahid
    wrote on last edited by ahmed-mustahid
    I have multiple questions regarding path planning with voxl-mapper:
    voxl-mapper version: 0.0.7
    My voxl-mapper config file is :
    voxl:~$ cat /etc/modalai/voxl-mapper.conf
     * This file contains configuration that's specific to voxl-mapper.
    	"tof_pipe":	"/run/mpa/tof",
    	"tof_enable":	true,
    	"tof_rate":	10,
    	"depth_pipe_0":	"/run/mpa/dfs_point_cloud",
    	"depth_pipe_0_enable":	false,
    	"extrinsics0_name":	"stereo_l",
    	"depth0_rate":	10,
    	"depth_pipe_1":	"/run/mpa/stereo_front_pc",
    	"depth_pipe_1_enable":	false,
    	"extrinsics1_name":	"stereo_front_l",
    	"depth1_rate":	10,
    	"depth_pipe_2":	"/run/mpa/stereo_rear_pc",
    	"depth_pipe_2_enable":	false,
    	"extrinsics2_name":	"stereo_rear_l",
    	"depth2_rate":	10,
    	"depth_pipe_3":	"/run/mpa/dfs_point_cloud",
    	"depth_pipe_3_enable":	false,
    	"extrinsics3_name":	"stereo_l",
    	"depth3_rate":	10,
    	"robot_radius":	0.3,
    	"voxel_size":	0.20000000298023224,
    	"voxels_per_side":	16,
    	"esdf_save_path":	"/data/voxl_mapper/esdf_map",
    	"tsdf_save_path":	"/data/voxl_mapper/tsdf_map",
    	"mesh_save_path":	"/data/voxl_mapper/mesh.ply",
    	"esdf_max_distance":	4,
    	"esdf_min_distance":	0.10000000149011612,
    	"esdf_default_distance":	2,
    	"esdf_inner_sphere_radius":	0.20000000298023224,
    	"esdf_outer_sphere_radius":	0.600000023841858,
    	"rrt_min_distance":	0.2,
    	"rrt_max_runtime_nanoseconds":	1000000000,
    	"rrt_use_first_solution":	false,
    	"rrt_treat_unknown_as_occupied":	true,
    	"rrt_send_tree":	false,
    	"loco_num_segments":	10,
    	"loco_derivative_to_optimize":	3,
    	"loco_poly_degree":	10,
    	"loco_smoothness_cost_weight":	2.5,
    	"loco_collision_cost_weight":	14,
    	"loco_waypoint_cost_weight":	0,
    	"loco_min_collision_sampling_dist":	0.05,
    	"loco_add_waypoints":	true,
    	"loco_scale_time":	true,
    	"loco_split_at_collisions":	true,
    	"loco_resample_trajectory":	true,
    	"loco_verbose":	false
    voxl-vision-px4.conf file
    voxl:~$ cat /etc/modalai/voxl-vision-px4.conf
    	"config_file_version":	1,
    	"qgc_ip":	"192.168.8.60",
    	"en_secondary_qgc":	false,
    	"secondary_qgc_ip":	"192.168.1.214",
    	"qgc_udp_port_number":	14550,
    	"udp_mtu":	512,
    	"en_localhost_mavlink_udp":	true,
    	"localhost_udp_port_number":	14551,
    	"en_vio":	true,
    	"en_voa":	true,
    	"en_send_vio_to_qgc":	false,
    	"en_send_voa_to_qgc":	false,
    	"voa_upper_bound_m":	-0.15000000596046448,
    	"voa_lower_bound_m":	0.15000000596046448,
    	"en_set_clock_from_gps":	true,
    	"en_force_onboard_mav1_mode":	true,
    	"en_reset_px4_on_error":	true,
    	"qvio_auto_reset_quality":	0.00050000002374872565,
    	"horizon_cal_tolerance":	0.300000011920929,
    	"offboard_mode":	"trajectory",
    	"follow_tag_id":	0,
    	"figure_eight_move_home":	true,
    	"en_tag_fixed_frame":	false,
    	"fixed_frame_filter_len":	5,
    	"en_transform_mavlink_pos_setpoints_from_fixed_frame":	false
    1. The following is the image provided in the gitlab repo:
      https://gitlab.com/voxl-public/voxl-sdk/services/voxl-mapper/-/raw/master/images/path_plan.png!alt text
      This map has generated both red and blue paths but none of my two maps shown below have blue path. Has the blue path been removed in the new voxl-mapper version?
    2. I am confused as to how I should select the goal point for the drone to fly to, because it is very hard to visualize exactly where the goal point selected in the voxl mapper is located in the room.
      Is it the right apporach to view the map from the top (i.e. from z axis pointing outward the screen: last image) and then select the "goal point"?
    3. In the last image (viewed from z axis) why does the voxl-mapper create a zig zag path, whereas a straight path is enough to reach the goal point?
    1. Current mapping speed is very slow. What parameter in the voxl-mapper config map can I change in order to incease the mapping speed?
