  3. Voxl_mpa_to_ros
Voxl_mpa_to_ros
8 Posts 3 Posters 1.8k Views 1 Watching
  • G Offline
    G Offline
    gauravshukla914
    wrote on last edited by tom
    For some reason, when I do -
    roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
    it doesn't seem to work fully. Here's the output -
    voxl:~$ roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
    ... logging to /home/root/.ros/log/7da4c736-3eb2-11ed-b715-18473db1be57/roslaunch-apq8096-3745.log
    Checking log directory for disk usage. This may take awhile.
    Press Ctrl-C to interrupt
    started roslaunch server http://localhost:57891/
    SUMMARY
    PARAMETERS
     * /rosdistro: indigo
     * /rosversion: 1.11.21
    NODES
        voxl_mpa_to_ros_node (voxl_mpa_to_ros/voxl_mpa_to_ros_node)
    auto-starting new master
    process[master]: started with pid [3764]
    ROS_MASTER_URI=http://localhost:11311
    setting /run_id to 7da4c736-3eb2-11ed-b715-18473db1be57
    process[rosout-1]: started with pid [3777]
    process[voxl_mpa_to_ros_node-2]: started with pid [3780]
    MPA to ROS app is now running
    Found new interface: qvio_overlay
    Found new interface: stereo
    Found new interface: tracking
    Found new interface: imu1
    And it stops after this. When I do rostopic list on the other terminal, it says unable to communicate with the Master. My bashrc file is correct with correct ROS_MASTER_IP and ROS_IP. Even rqt says the same thing. I plan to see the output of the camera in the rqt viewer.
    Dong LiuD 1 Reply Last reply
    • G Offline
      G Offline
      gauravshukla914
      Can someone help me with this? Thanks!
      • T Offline
        T Offline
        tangotoo
        I don't know if its related to your problem, but I had a lack of communication issue between voxl-vision and my PX4 and it was due to an additional process, voxl-mavlink-server not running. You may want to check if there are any other supporting processes you need running first in order to bring up ROS. I'm not a ROS user, so I can't help too much in that regard.
        • G Offline
          G Offline
          gauravshukla914
          @modaltb @Ed-Sutter @tom @Alex-Gardner anyone?
          • G gauravshukla914
            SUMMARY
            PARAMETERS
            NODES
            Dong LiuD Offline
            Dong LiuD Offline
            Dong Liu
            wrote on last edited by Dong Liu
            @gauravshukla914
            Don't know it is related. But I had the same experience. You can't rostopic list because the ROS_MASTER_URI and ROS_IP are not set correctly.
            There is file /home/root/my_ros_env.sh which defines these two variables. Need to be changed to reflect the real values.
            Dong
            • G Offline
              G Offline
              gauravshukla914
              @Dong-Liu yes that's correct. Everytime a master ip or ros ip changes, I make sure to give the corrects IPs in the bachrc file and source it. This is not the issue, but thanks for the suggestion though!
              • G Offline
                G Offline
                gauravshukla914
                This is solved. I'm made to source my_ros_env.sh file everytime before launching the mpa file. But this never used to happen before. Anyway for now its working by sourcing the my_ros_env.sh everytime. Thanks all!
                • G gauravshukla914
                  Dong LiuD Offline
                  Dong LiuD Offline
                  Dong Liu
                  @gauravshukla914 I also noticed it. Somehow on the drone's ROS indigo system. roslaunch voxl_mpa_to_ros voxl_map_to_ros.launch won't honor the existing ROS_MASTER_URI, it always source ROS_MASTER_URI etc from my_ros_env.sh
