  3. Trouble with EM7565 startup...
24 Posts 3 Posters 7.0k Views 3 Watching
    @Ed-Sutter And to be safe if you're in station mode I would set your ssid and pass to dummy values, i.e voxl-wifi station tmp tmp because I've seen in the past where wlan0 will try to bring itself back up after you manually force it down.
    Ed SutterE Offline
    Ed SutterE Offline
    Ed Sutter
    @tom One thing I just noticed...
    If I boot up without an LTE modem, then /etc/resolv.conf is:
    # Generated by dhcpcd from wlan0
    # /etc/resolv.conf.head can replace this line
    domain myfiosgateway.com
    nameserver 192.168.1.1
    # /etc/resolv.conf.tail can replace this line
    That (above) makes sense. That's my ISP (Fios) and wifi subnet in my home.
    If I boot up with the LTE modem, then /etc/resolve.conf is:
    nameserver 172.26.38.1
    Looks like something in the modem startup overwrites /etc/resolv.conf. The script "enable-dns.sh" is called by voxl-modem-start.sh, but it only writes to /etc/resolve.conf if it doesn't already exist (plus it writes 8.8.8.8, which apparently is Google dns).
    Any idea how this is being written?
      Ed SutterE Offline
      Ed SutterE Offline
      Ed Sutter
      @tom I'm starting a new thread on this...
        @Ed-Sutter I'm speaking specifically of VOXL, not your host computer, but it's the same idea. It's the actual Linux device driver for that piece of hardware. For example: https://gitlab.com/voxl-public/system-image-build/apq8096-kernel/-/blob/main/drivers/net/usb/qmi_wwan.c#L772
        Ed SutterE Offline
        Ed SutterE Offline
        Ed Sutter
        #23
        @Eric-Katzfey Somehow this slipped through the cracks... I just looked in that file and I don't see the VID/PID of the EM7565 listed. So a couple of questions:
        1. What does this mean?
        2. Do you know what is involved in getting it listed?
        I have the latest driver files from Sierra Wireless, and they do have what I need. Is this a module that I can update on VOXL?
        Ed
          Ed SutterE Offline
          Ed SutterE Offline
          Ed Sutter
          @Eric-Katzfey @tom Digging a bit deeper into this, I see that the voxl-build procedure does patch the qmi_wwan.c file, and after the patch, the VID/PID for EM7565 is in there. On one hand this is good news because it implies that the kernel does have support for the modem I'm trying to use; however, its not-so-good news for me because running with that modem has not reliable on VOXL. 😞
          Aside from verifying that I am actually running the same version on my VOXL-Flight-Deck as is being built in voxl-build (see below), I'm at a loss regarding other things to do to debug this. Any thoughts on this?
          Following is the output of voxl-version on my board:
          / # voxl-version
          cat: /etc/modalai/voxl-software-bundle-version.txt: No such file or directory
          system-image:    ModalAI 3.3.0 BUILDER: ekatzfey BUILD_TIME: 2021-06-06_19:28
          kernel:          #1 SMP PREEMPT Sun Jun 6 19:41:01 UTC 2021 3.18.71-perf
          architecture:    aarch64
          processor:       apq8096
          os:              GNU/Linux
          voxl-suite:
          Package: voxl-suite
          Version: 0.5.0
          Depends: libjpeg_turbo (>= 9.0.4), libmodal_exposure (>= 0.0.2), libmodal_json (>= 0.3.6), libmodal_pipe (>= 2.1.1), lib
          rc_math (>= 1.1.5), libvoxl_cutils (>= 0.0.2), libvoxl_io (>= 0.5.4), mavlink-camera-manager (>= 0.0.2), mongoose (>= 7.
          3.0), opencv (>= 4.5.2-2), openmp (>= 10.0.2), voxl-camera-calibration (>= 0.1.1), voxl-camera-server (>= 0.8.1), voxl-c
          pu-monitor (>= 0.2.0), voxl-dfs-server (>= 0.2.2), voxl-docker-support (>= 1.1.3), voxl-gphoto2 (>= 0.0.5), voxl-imu-ser
          ver (>= 0.9.1), voxl-mavlink (>= 0.0.2), voxl-modem (>= 0.12.0), voxl-mpa-tools (>= 0.3.6), voxl-nodes (>= 0.2.0), voxl-
          portal (>= 0.1.2), voxl-qvio-server (>= 0.3.4), voxl-streamer (>= 0.2.6), voxl-tag-detector (>= 0.0.2), voxl-tflite (>=
          2.2.3), voxl-tflite-server (>= 0.1.5), voxl-utils (>= 0.8.4), voxl-vision-px4 (>= 0.9.5), voxl-vpn (>= 0.0.3)
          Section: base
          Architecture: all
          Maintainer: james@modalai.com
          MD5Sum: 172dd2541a4b01ec415651b5ded3afab
          Filename: voxl-suite_0.5.0_202111041852.ipk
          Description: meta-package for voxl-suite software collection
          Installed-Time: 144
