  3. VVPX4 Deployment to VOXL depedencies
5 Posts 3 Posters 1.2k Views 1 Watching
  • ICI Offline
    ICI Offline
    IC
    I've been trying to deploy VVPX4 and see some dependencies. I am using the VOXL Platform 3.8.0-0.7 and VOXL-Cross-2.1 docker image.
    voxl-vision-px4-master $./deploy_to_voxl.sh
    searching for ADB device
    checking VOXL for dpkg/opkg
    opkg detected
    voxl-vision-px4_1.2.0.ipk: 1 file pushed. 3.4 MB/s (105362 bytes in 0.029s)
    Reinstalling voxl-vision-px4 (1.2.0) on root.
    Configuring voxl-vision-px4.
    Collected errors:
     * satisfy_dependencies_for: Cannot satisfy the following dependencies for voxl-vision-px4:
     * 	libmodal-pipe (>= 2.4.0) * 	libmodal-cv (>= 0.1.0) *
    DONE
    Maybe I have to build the following in a specific directory but I am not sure which one:
    $ mkdir cross-workspace
    $ cd cross-workspace
    $ voxl-docker -i voxl-cross:V1.9
    voxl-cross:~$ git clone https://gitlab.com/voxl-public/voxl-sdk/core-libs/libmodal-json.git
    voxl-cross:~$ cd libmodal-json/
    voxl-cross:~$ ./build.sh qrb5165
    Can I install or source these two dependencies separately?
      Yes you could, or you can install via our package management feed. Here's the two packages from there from SDK 0.8:
      http://voxl-packages.modalai.com/dists/apq8096/sdk-0.8/binary-arm64/libmodal-cv_0.1.0.ipk
      http://voxl-packages.modalai.com/dists/apq8096/sdk-0.8/binary-arm64/libmodal-pipe_2.4.0.ipk
      Depending on your setup, you could also install the VOXL-SDK fully and then modify parts you need from source. More info here: https://docs.modalai.com/voxl-sdk/
      Package management on VOXL1 here: https://docs.modalai.com/configure-pkg-manager/
      • ICI Offline
        ICI Offline
        IC
        Thank you @modaltb.
        I'm having trouble deploying VVPX4 to to VOXL. The dependencies not being satisfied are being installed so I'm not sure what to do.
        Here is what I'm doing:
        voxl-cross:~$ ./install_build_deps.sh apq8096 staging
        using apq8096 staging repo
        Downloading http://voxl-packages.modalai.com/dists/apq8096/staging/binary-arm64//Packages.gz.
        Updated source 'staging'.
        installing:
        libmodal-json
        libmodal-pipe
        librc-math
        libmodal-cv
        voxl-mpa-tools
        voxl-mavlink
        Installing libmodal-json (0.4.2) on root.
        Downloading http://voxl-packages.modalai.com/dists/apq8096/staging/binary-arm64//libmodal-json_0.4.2.ipk.
        Configuring libmodal-json.
        Installing libmodal-pipe (2.4.0) on root.
        Downloading http://voxl-packages.modalai.com/dists/apq8096/staging/binary-arm64//libmodal-pipe_2.4.0.ipk.
        Configuring libmodal-pipe.
        Installing librc-math (1.1.8) on root.
        Downloading http://voxl-packages.modalai.com/dists/apq8096/staging/binary-arm64//librc-math_1.1.8.ipk.
        Configuring librc-math.
        Installing libmodal-cv (0.1.0) on root.
        Downloading http://voxl-packages.modalai.com/dists/apq8096/staging/binary-arm64//libmodal-cv_0.1.0.ipk.
        Configuring libmodal-cv.
        Installing voxl-mpa-tools (0.7.2) on root.
        Downloading http://voxl-packages.modalai.com/dists/apq8096/staging/binary-arm64//voxl-mpa-tools_0.7.2.ipk.
        Configuring voxl-mpa-tools.
        Installing voxl-mavlink (0.1.0) on root.
        Downloading http://voxl-packages.modalai.com/dists/apq8096/staging/binary-arm64//voxl-mavlink_0.1.0.ipk.
        Configuring voxl-mavlink.
        Done installing dependencies
        voxl-cross:~$ ./build.sh apq8096
        -- The C compiler identification is GNU 4.9.3
        -- The CXX compiler identification is GNU 4.9.3
        -- Check for working C compiler: /usr/bin/aarch64-linux-gnu-gcc-4.9 - skipped
        -- Check for working CXX compiler: /usr/bin/aarch64-linux-gnu-g++-4.9 - skipped
        -- Building for platform APQ8096
        -- Configuring done
        -- Generating done
        -- Build files have been written to: /home/root/build64
        [  3%] Building C object utils/CMakeFiles/voxl-px4-shell.dir/voxl-px4-shell.c.o
        [ 11%] Building C object src/CMakeFiles/voxl-vision-px4.dir/geometry.c.o
        [ 11%] Building C object src/CMakeFiles/voxl-vision-px4.dir/config_file.c.o
        [ 15%] Building C object src/CMakeFiles/voxl-vision-px4.dir/control_input.c.o
        [ 23%] Building C object utils/CMakeFiles/voxl-calibrate-px4-horizon.dir/voxl-calibrate-px4-horizon.c.o
        [ 26%] Building C object src/CMakeFiles/voxl-vision-px4.dir/fixed_pose_input.c.o
        [ 23%] Building C object src/CMakeFiles/voxl-vision-px4.dir/horizon_cal.c.o
        [ 30%] Building C object src/CMakeFiles/voxl-vision-px4.dir/main.c.o
        In file included from /usr/aarch64-linux-gnu-2.23/include/features.h:367:0,
                         from /usr/aarch64-linux-gnu-2.23/include/stdio.h:27,
                         from /home/root/src/config_file.c:34:
        /usr/aarch64-linux-gnu-2.23/include/bits/stdlib.h:64:8: warning: no previous declaration for 'ptsname_r' [-Wmissing-declarations]
         __NTH (ptsname_r (int __fd, char *__buf, size_t __buflen))
        /usr/aarch64-linux-gnu-2.23/include/sys/cdefs.h:57:59: note: in definition of macro '__NTH'
         #  define __NTH(fct) __attribute__ ((__nothrow__ __LEAF)) fct
        In file included from /home/root/utils/voxl-px4-shell.c:39:0:
        /usr/aarch64-linux-gnu-2.23/include/string.h:649:1: warning: no previous declaration for '__mempcpy_inline' [-Wmissing-declarations]
         __mempcpy_inline (void *__restrict __dest,
                         from /home/root/utils/voxl-calibrate-px4-horizon.c:34:
                         from /home/root/src/main.c:34:
        [ 34%] Linking C executable voxl-calibrate-px4-horizon
        [ 38%] Linking C executable voxl-px4-shell
                         from /home/root/src/geometry.c:34:
        [ 38%] Built target voxl-calibrate-px4-horizon
        [ 42%] Building C object src/CMakeFiles/voxl-vision-px4.dir/misc.c.o
        [ 42%] Built target voxl-px4-shell
        [ 46%] Building C object src/CMakeFiles/voxl-vision-px4.dir/obs_pc_filter.c.o
        [ 50%] Building C object src/CMakeFiles/voxl-vision-px4.dir/offboard_figure_eight.c.o
                         from /home/root/src/obs_pc_filter.c:34:
        [ 53%] Building C object src/CMakeFiles/voxl-vision-px4.dir/offboard_follow_tag.c.o
        [ 57%] Building C object src/CMakeFiles/voxl-vision-px4.dir/offboard_mode.c.o
        [ 61%] Building C object src/CMakeFiles/voxl-vision-px4.dir/offboard_trajectory.c.o
        [ 65%] Building C object src/CMakeFiles/voxl-vision-px4.dir/pose_filter.c.o
        [ 69%] Building C object src/CMakeFiles/voxl-vision-px4.dir/px4_mavlink.c.o
        [ 73%] Building C object src/CMakeFiles/voxl-vision-px4.dir/px4_monitor.c.o
        [ 76%] Building C object src/CMakeFiles/voxl-vision-px4.dir/px4_shell.c.o
        [ 80%] Building C object src/CMakeFiles/voxl-vision-px4.dir/tag_manager.c.o
        [ 84%] Building C object src/CMakeFiles/voxl-vision-px4.dir/transform_ringbuf.c.o
                         from /home/root/src/transform_ringbuf.c:19:
        [ 88%] Building C object src/CMakeFiles/voxl-vision-px4.dir/udp_mavlink.c.o
        [ 92%] Building C object src/CMakeFiles/voxl-vision-px4.dir/vio_manager.c.o
                         from /home/root/src/udp_mavlink.c:34:
        [ 96%] Building C object src/CMakeFiles/voxl-vision-px4.dir/voa_manager.c.o
        [100%] Linking C executable voxl-vision-px4
        [100%] Built target voxl-vision-px4
        voxl-cross:~$ ./make_package.sh ipk
        Package Name:  voxl-vision-px4
        version Number:  1.2.0
        Consolidate compiler generated dependencies of target voxl-vision-px4
        [ 84%] Built target voxl-vision-px4
        Consolidate compiler generated dependencies of target voxl-px4-shell
        [ 92%] Built target voxl-px4-shell
        Consolidate compiler generated dependencies of target voxl-calibrate-px4-horizon
        [100%] Built target voxl-calibrate-px4-horizon
        Install the project...
        -- Install configuration: ""
        -- Installing: ../pkg/data/usr/bin/voxl-vision-px4
        -- Installing: ../pkg/data/usr/include/voxl_vision_px4.h
        -- Installing: ../pkg/data/usr/bin/voxl-px4-shell
        -- Installing: ../pkg/data/usr/bin/voxl-calibrate-px4-horizon
        /home/root
        starting building IPK package
        ar: creating voxl-vision-px4_1.2.0.ipk
        DONE
        voxl-cross:~$ logout
        voxl-vision-px4-master $./deploy_to_voxl.sh adb
        opkg detected
        voxl-vision-px4_1.2.0.ipk: 1 file pushed. 8.6 MB/s (105382 bytes in 0.012s)
        Collected errors:
        DONE
        After this, the package I am trying to deploy isn't on VOXL and the voxl-vision-px4 is enabled but not running.
        Any pointers to what I may be missing?
          The install build deps script installs the dependencies to your docker image for building, not onto the voxl. If you're building packages with recent dependencies you'll need to update your voxl with opkg update to make sure it has the latest dependencies.
          ICI 1 Reply Last reply
          • ? A Former User
            ICI Offline
            ICI Offline
            IC
            @Alex-Gardner Got it. Thank you!
