  3. HITL with VOXL 2 Serial Port Closed
7 Posts 3 Posters 2.0k Views
  • Taylor PresleyT Offline
    Taylor Presley
    wrote on last edited by Taylor Presley
    Hey good afternoon,
    I'm following this user guide and Zach's YT tutorial to setup HITL. I modified iris_hitl.sdf serialDevice to /dev/ttyUSB0, but continue to receive "Serial port closed!" message instead of expected "Opened serial device /dev/ttyUSB0" after running 'gazebo Tools/sitl_gazebo/worlds/hitl_iris.world'
    I've included PX4 output on target and QGC output below. I think I have cabling correct because QGC reads mavlink messages (and doesn't when I switch TX/RX).
    I'm using VOXL 2 Flight Deck, Ubuntu 20.04, ROS Noetic, Gazebo 11, QGC daily build.
    How can I fix this?
    mdr@mdr:~$ adb shell
    voxl2:/$ voxl-px4-hitl -v
    Found DSP signature file
    Setting VIO Parameters for HITL
    ______  __   __    ___
    | ___ \ \ \ / /   /   |
    | |_/ /  \ V /   / /| |
    |  __/   /   \  / /_| |
    | |     / /^\ \ \___  |
    \_|     \/   \/     |_/
    px4 starting.
    INFO  [px4] Calling startup script: /bin/sh /etc/modalai/voxl-px4-hitl-vio-parameters.config 0
      CBRK_SUPPLY_CHK: curr: 0 -> new: 894281
    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for CBRK_SUPPLY_CHK
      COM_DISARM_PRFLT: curr: 10.0000 -> new: -1.0000
    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for COM_DISARM_PRFLT
      COM_RC_IN_MODE: curr: 0 -> new: 1
    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for COM_RC_IN_MODE
      NAV_RCL_ACT: curr: 2 -> new: 0
    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for NAV_RCL_ACT
      EKF2_AID_MASK: curr: 1 -> new: 280
    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_AID_MASK
      SYS_HAS_MAG: curr: 1 -> new: 0
    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for SYS_HAS_MAG
      EKF2_MAG_TYPE: curr: 0 -> new: 5
    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_MAG_TYPE
      EKF2_HGT_MODE: curr: 0 -> new: 3
    ERROR [parameters] Timeout waiting for parameter_client_set_value_response for EKF2_HGT_MODE
    Exiting NOW.
    ______  __   __    ___
    | ___ \ \ \ / /   /   |
    | |_/ /  \ V /   / /| |
    |  __/   /   \  / /_| |
    | |     / /^\ \ \___  |
    \_|     \/   \/     |_/
    px4 starting.
    INFO  [px4] Calling startup script: /bin/sh /etc/modalai/voxl-px4-hitl.config 0
    INFO  [muorb] SLPI: Creating qurt thread hpwork
    INFO  [muorb] SLPI: Successfully created px4 task PX4_hpwork with tid 82
    INFO  [muorb] SLPI: Creating qurt thread lpwork
    INFO  [muorb] SLPI: Successfully created px4 task PX4_lpwork with tid 81
    INFO  [muorb] SLPI: Creating qurt thread wkr_hrt
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wkr_hrt with tid 80
    INFO  [muorb] SLPI: Creating qurt thread client_sync_thread
    INFO  [muorb] SLPI: Successfully created px4 task PX4_client_sync_thread with tid 79
    INFO  [muorb] SLPI: Creating qurt thread wq_manager
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_manager with tid 78
    INFO  [muorb] SLPI: Creating qurt thread qshell
    INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 77
    INFO  [logger] Start file log (type: full)
    INFO  [logger] [logger] /data/px4/log/sess011/log001.ulg
    INFO  [logger] Opened full log file: /data/px4/log/sess011/log001.ulg
    INFO  [muorb] SLPI: Advertising remote topic mavlink_log
    ERROR [logger] No subscriptions added
    INFO  [muorb] SLPI: Advertising remote topic logger_status
    INFO  [qshell] Send cmd: 'icm42688p start -s -h'
    INFO  [muorb] SLPI: qshell gotten: icm42688p start -s -h
    INFO  [muorb] SLPI: Creating qurt thread wq_SPI1
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_SPI1 with tid 76
    INFO  [muorb] SLPI: icm42688p #0 on SPI bus 1 (devid=0x0)
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: Ok executing command: icm42688p start -s -h
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 388011943, current timestamp 388011944
    INFO  [uorb] Advertising remote topic qshell_retval
    INFO  [qshell] qshell return value timestamp: 388011943, local time: 388014777
    ERROR [muorb] SLPI: Cannot reset all parameters on client side
    INFO  [uorb] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
    INFO  [uorb] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
    INFO  [uorb] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
    INFO  [dataman] Unknown restart, data manager file '/data/px4/dataman' size is 11798680 bytes
    INFO  [qshell] Send cmd: 'sensors start -h'
    INFO  [muorb] SLPI: qshell gotten: sensors start -h
    INFO  [muorb] SLPI: Creating qurt thread wq_nav_and_controllers
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_nav_and_controllers with tid 75
    INFO  [muorb] SLPI: Creating qurt thread wq_rate_ctrl
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_rate_ctrl with tid 74
    INFO  [muorb] SLPI: Ok executing command: sensors start -h
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 390387672, current timestamp 390387673
    INFO  [uorb] Advertising remote topic sensors_status_imu
    INFO  [qshell] qshell return value timestamp: 390387672, local time: 390391251
    INFO  [muorb] SLPI: Advertising remote topic mission
    INFO  [commander] LED: open /dev/led0 failed (22)
    INFO  [muorb] SLPI: Advertising remote topic led_control
    INFO  [muorb] SLPI: Advertising remote topic tune_control
    INFO  [PreFlightCheck] Failed barometer preflight check
    INFO  [PreFlightCheck] Failed EKF health preflight check while waiting for filter to settle
    INFO  [muorb] SLPI: Advertising remote topic vehicle_control_mode
    INFO  [muorb] SLPI: Advertising remote topic vehicle_status
    INFO  [muorb] SLPI: Advertising remote topic actuator_armed
    INFO  [muorb] SLPI: Advertising remote topic commander_state
    INFO  [muorb] SLPI: Advertising remote topic vehicle_status_flags
    INFO  [muorb] SLPI: Advertising remote topic vehicle_command
    INFO  [commander] Handling Commander command 176
    INFO  [muorb] SLPI: Advertising remote topic vehicle_command_ack
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 391611165, current timestamp 391611166
    INFO  [qshell] qshell return value timestamp: 391611165, local time: 391614168
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 391695176, current timestamp 391695177
    INFO  [qshell] qshell return value timestamp: 391695176, local time: 391696851
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 391819694, current timestamp 391819695
    INFO  [qshell] qshell return value timestamp: 391819694, local time: 391821826
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 391884503, current timestamp 391884503
    INFO  [qshell] qshell return value timestamp: 391884503, local time: 391887045
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 391986368, current timestamp 391986369
    INFO  [qshell] qshell return value timestamp: 391986368, local time: 391987655
    INFO  [uorb] Advertising remote topic vehicle_land_detected
    INFO  [qshell] Send cmd: 'pwm_out_sim start -m hil'
    INFO  [muorb] SLPI: qshell gotten: pwm_out_sim start -m hil
    INFO  [muorb] SLPI: Creating qurt thread wq_hp_default
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_hp_default with tid 73
    INFO  [uorb] Advertising remote topic test_motor
    INFO  [muorb] SLPI: Ok executing command: pwm_out_sim start -m hil
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 393044419, current timestamp 393044420
    INFO  [qshell] qshell return value timestamp: 393044419, local time: 393045458
    INFO  [qshell] Send cmd: 'mixer load /dev/pwm_output0 quad_x.main.mix'
    INFO  [muorb] SLPI: qshell gotten: mixer load /dev/pwm_output0 quad_x.main.mix
    INFO  [muorb] SLPI: Ok executing command: mixer load /dev/pwm_output0 quad_x.main.mix
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 393105036, current timestamp 393105037
    INFO  [qshell] qshell return value timestamp: 393105036, local time: 393107031
    INFO  [muorb] SLPI: Creating qurt thread wq_INS0
    INFO  [muorb] SLPI: Successfully created px4 task PX4_wq_INS0 with tid 4169
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 394406195, current timestamp 394406196
    INFO  [qshell] qshell return value timestamp: 394406195, local time: 394407062
    INFO  [qshell] Send cmd: 'modalai_dsp start -v -p 2 -b 921600'
    INFO  [muorb] SLPI: qshell gotten: modalai_dsp start -v -p 2 -b 921600
    INFO  [muorb] SLPI: Creating qurt thread modalai_dsp__main
    INFO  [muorb] SLPI: Successfully created px4 task PX4_modalai_dsp__main with tid 72
    INFO  [muorb] SLPI: Ok executing command: modalai_dsp start -v -p 2 -b 921600
    INFO  [muorb] SLPI: Sending qshell retval with timestamp 395459398, current timestamp 395459399
    ERROR [muorb] SLPI: Port is open: 0
    INFO  [uorb] Advertising remote topic sensor_accel
    INFO  [uorb] Advertising remote topic sensor_gyro
    INFO  [muorb] SLPI: Got 5 from orb_subscribe
    INFO  [muorb] SLPI: Got 6 from orb_subscribe
    INFO  [muorb] SLPI: Got 7 from orb_subscribe
    INFO  [muorb] SLPI: Got 8 from orb_subscribe
    INFO  [qshell] qshell return value timestamp: 395459398, local time: 395467699
    INFO  [muorb] SLPI: Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
    pxh> INFO  [muorb] SLPI: Advertising remote topic telemetry_status
    INFO  [muorb] SLPI: Advertising remote topic timesync_status
    INFO  [muorb] SLPI: Advertising remote topic vehicle_visual_odometry
    INFO  [muorb] SLPI: Advertising remote topic obstacle_distance
    pxh> parmaINFO  [PreFlightCheck] Failed barometer preflight check
    pxh> parINFO  [PreFlightCheck] Failed barometer preflight check
    pxh> param INFO  [PreFlightCheck] Failed barometer preflight check
    pxh> param setINFO  [PreFlightCheck] Failed barometer preflight check
    pxh> param set INFO  [PreFlightCheck] Failed barometer preflight check
    pxh> param set SYINFO  [PreFlightCheck] Failed barometer preflight check
    pxh> param set SYS_INFO  [PreFlightCheck] Failed barometer preflight check
    pxh> param set SYS_HAINFO  [PreFlightCheck] Failed barometer preflight check
    pxh> param set SYS_HAS_INFO  [PreFlightCheck] Failed barometer preflight check
    pxh> param set SYS_HAS_BAINFO  [PreFlightCheck] Failed barometer preflight check
    pxh> param set SYS_HAS_BAROINFO  [PreFlightCheck] Failed barometer preflight check
    pxh> param set SYS_HAS_BARO 0INFO  [PreFlightCheck] Failed barometer preflight check
      SYS_HAS_BARO: curr: 1 -> new: 0
    pxh> commander check
    ERROR [PreFlightCheck] Preflight Fail: no valid data from Accel 0
    INFO  [PreFlightCheck] Preflight Fail: no valid data from Accel 0
    ERROR [PreFlightCheck] Preflight Fail: Accel Range, hold still on arming
    ERROR [PreFlightCheck] Preflight Fail: no valid data from Gyro 0
    INFO  [PreFlightCheck] Preflight Fail: no valid data from Gyro 0
    INFO  [commander] Preflight check: FAILED
    INFO  [commander] Prearm check: OK
    INFO  [HealthFlags] DEVICE		STATUS
    INFO  [HealthFlags] ----------------------------------
    INFO  [HealthFlags] GYRO:
    INFO  [HealthFlags] ACC:
    INFO  [HealthFlags] MAG:
    INFO  [HealthFlags] PRESS:
    INFO  [HealthFlags] AIRSP:
    INFO  [HealthFlags] GPS:		 	OK
    INFO  [HealthFlags] OPT:
    INFO  [HealthFlags] VIO:
    INFO  [HealthFlags] LASER:
    INFO  [HealthFlags] GTRUTH:
    INFO  [HealthFlags] RATES:
    INFO  [HealthFlags] ATT:
    INFO  [HealthFlags] YAW:
    INFO  [HealthFlags] ALTCTL:
    INFO  [HealthFlags] POS:
    INFO  [HealthFlags] MOT:
    INFO  [HealthFlags] RC  :		EN	OFF
    INFO  [HealthFlags] GYRO2:
    INFO  [HealthFlags] ACC2:
    INFO  [HealthFlags] MAG2:
    INFO  [HealthFlags] GEOFENCE:
    INFO  [HealthFlags] AHRS:		EN	ERR
    INFO  [HealthFlags] TERRAIN:
    INFO  [HealthFlags] REVMOT:
    INFO  [HealthFlags] LOGGIN:
    INFO  [HealthFlags] BATT:
    INFO  [HealthFlags] PROX:
    INFO  [HealthFlags] SATCOM:
    INFO  [HealthFlags] PREARM:		EN	ERR
    INFO  [HealthFlags] OBSAVD:
    mdr@mdr:~/Downloads$ ./QGroundControl.AppImage
    Settings location "/home/mdr/.config/QGroundControl.org/QGroundControl Daily.ini" Is writable?: true
    Filter rules "*Log.debug=false\nGStreamerAPILog.debug=true\nqt.qml.connections=false"
    System reported locale: QLocale(English, Latin, United States) ; Name "en_US" ; Preffered (used in maps):  "en-US"
    serialnmea: No known GPS device found. Specify the COM port via QT_NMEA_SERIAL_PORT.
    MAVLinkLogManagerLog: MAVLink logs directory: "/home/mdr/Documents/QGroundControl Daily/Logs"
    Map Cache in: "/home/mdr/.cache/QGCMapCache300" / "qgcMapCache.db"
    setCurrentPlanViewSeqNum
    Adding target QHostAddress("192.168.0.2") 14550
    ParameterManagerLog: Attemping load from cache
    ParameterManagerLog: Parameters cache match failed /home/mdr/.config/QGroundControl.org/ParamCache/1_1.v2
    FactPanelControllerLog: Missing parameter: "1:SYS_AUTOSTART"
    FactPanelControllerLog: Missing parameter: "1:SYS_AUTOCONFIG"
    FactPanelControllerLog: Missing parameter: "1:BAT1_N_CELLS"
    FactPanelControllerLog: Missing parameter: "1:BAT1_V_EMPTY"
    FactPanelControllerLog: Missing parameter: "1:BAT1_V_CHARGED"
    • Zachary LowellZ Offline
      Zachary Lowell
      Hi @Taylor-Presley
      Does /dev/ttyUSB0 show up in your dev environment when you plug in your FTDI cable?
      Zach
        Taylor Presley
        Zach,
        Thanks for taking the time to look at this! Yes, see snippets below:
        mdr@mdr:~$ lsusb
        Bus 001 Device 002: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
        mdr@mdr:~$ dmesg | grep ttyUSB
        [    3.219261] usb 1-2: FTDI USB Serial Device converter now attached to ttyUSB0
        Taylor PresleyT 1 Reply Last reply
        • Taylor PresleyT Taylor Presley
          Zach,
          mdr@mdr:~$ lsusb
          Taylor Presley
          @Zachary-Lowell have you had a chance to investigate? Is there any additional information I could provide that would help?
          Taylor
            Zachary Lowell
            Try giving your usb device root permissions. Do the following:
            sudo chmod 777 /dev/ttyUSB0
            and then try rerunning all the same code. I think this might be a permissions issue. @Taylor-Presley
              Taylor Presley
              @Zachary-Lowell I have two instances setup, one for SITL with ROS, gazebo, and PX4 firmware, and another following the VOXL 2 PX4 HITL User Guide. I'm not sure why, but when I deleted the bashrc sources to the SITL catkin_ws and ROS package paths, and then followed the instructions, I was able to connect to gazebo with HITL and takeoff/land. Gazebo now prints 'Opened serial device /dev/ttyUSB0.' Thanks!
              • Zachary Lowell 0Z Offline
                Zachary Lowell 0
                Hm thats super strange but I am glad you got it working! Keep us posted on how the project turns out 🙂
