  3. VOXL2 temporary boot loop issue
voxl-2
3 Posts 2 Posters 906 Views 1 Watching
  • vivek rkV Offline
    vivek rkV Offline
    vivek rk
    I had this weird problem with the VOXL2 board I'm working with. When I first connect the battery to the platform, the VOXL2 does not boot up, but instead gets stuck in a boot loop (the fan powers down for a second and starts back up, a green led turns off and on on the bottom of the board) and we need to keep reconnecting the battery until it stops boot looping and starts working again. Sometimes I need to put it in fastboot mode and reboot right after for the board to work again. Does anyone here know whats happening ?
    • modaltbM Offline
      modaltbM Offline
      modaltb
      Hi @vivek-rk ,
      So far this issue has been resolved by re-attaching or sometimes replacing the 4 wire cable that is between the VOXL Power Module and the VOXL 2... Can you try to see if re-seating this cable in the connectors resolves the issue? If not if you have another cable to try?
      • vivek rkV Offline
        vivek rkV Offline
        vivek rk
        Hi @modaltb
        Thanks for sharing that information. It happened today and changing the power cable fixed it.
