<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[VOXL2 temporary boot loop issue]]></title><description><![CDATA[<p dir="auto">I had this weird problem with the VOXL2 board I'm working with. When I first connect the battery to the platform, the VOXL2 does not boot up, but instead gets stuck in a boot loop (the fan powers down for a second and starts back up, a green led turns off and on on the bottom of the board) and we need to keep reconnecting the battery until it stops boot looping and starts working again. Sometimes I need to put it in fastboot mode and reboot right after for the board to work again. Does anyone here know whats happening ?</p>
]]></description><link>https://forum.modalai.com/topic/1552/voxl2-temporary-boot-loop-issue</link><generator>RSS for Node</generator><lastBuildDate>Sun, 06 Sep 2026 15:09:07 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/1552.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 17 Nov 2022 19:26:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to VOXL2 temporary boot loop issue on Fri, 18 Nov 2022 21:31:24 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/modaltb" aria-label="Profile: modaltb">@<bdi>modaltb</bdi></a><br />
Thanks for sharing that information. It happened today and changing the power cable fixed it.</p>
]]></description><link>https://forum.modalai.com/post/7227</link><guid isPermaLink="true">https://forum.modalai.com/post/7227</guid><dc:creator><![CDATA[vivek rk]]></dc:creator><pubDate>Fri, 18 Nov 2022 21:31:24 GMT</pubDate></item><item><title><![CDATA[Reply to VOXL2 temporary boot loop issue on Thu, 17 Nov 2022 21:04:44 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/vivek-rk" aria-label="Profile: vivek-rk">@<bdi>vivek-rk</bdi></a> ,</p>
<p dir="auto">So far this issue has been resolved by re-attaching or sometimes replacing the <a href="https://docs.modalai.com/cable-datasheets/#mcbl-00001" rel="nofollow ugc">4 wire cable</a> that is between the VOXL Power Module and the VOXL 2...  Can you try to see if re-seating this cable in the connectors resolves the issue?  If not if you have another cable to try?</p>
]]></description><link>https://forum.modalai.com/post/7221</link><guid isPermaLink="true">https://forum.modalai.com/post/7221</guid><dc:creator><![CDATA[modaltb]]></dc:creator><pubDate>Thu, 17 Nov 2022 21:04:44 GMT</pubDate></item></channel></rss>
