  3. VOXL2 HITL
VOXL2 HITL
voxl-2
10 Posts 3 Posters 4.5k Views 1 Watching
  • M Offline
    M Offline
    MikeD
    Hi -
    I'm having issues getting HITL running with ModalAI's Gazebo Docker container while following the instructions below:
    https://docs.modalai.com/voxl2-PX4-hitl/#gazebo-setup
    1. FTDI cable is connected to J18 and linux host (Ubuntu 22.04)
    2. Starting the Docker Gazebo instance reports the following:
      Opened serial device /dev/ttyUSB0
      libcurl: (28) Failed to connect to fuel.ignitionrobotics.org port 443: Connection timed out
      libcurl: (28) Failed to connect to fuel.gazebosim.org port 443: Connection timed out
      ** Gazebo appears to start successfully.
    3. In adb shell I run: voxl-px4-hitl
    4. Here is an excerpt from that output:
    INFO [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
    INFO [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
    INFO [muorb] SLPI: Too many arming check events (1, 14 > 14). Not reporting all
    INFO [muorb] SLPI: Preflight Fail: No valid data from Accel 0
    INFO [muorb] SLPI: Preflight Fail: barometer 0 missing
    INFO [muorb] SLPI: Preflight Fail: ekf2 missing data
    INFO [muorb] SLPI: Preflight Fail: No valid data from Gyro 0
    INFO [muorb] SLPI: Preflight Fail: Compass Sensor 0 missing
    INFO [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
    INFO [px4] Startup script returned successfully
    ==> Note that there are many Preflight check failures.
    1. Running dsp_hitl status returns this:
      INFO [muorb] SLPI: Running: yes
      INFO [muorb] SLPI: Status of IMU_Data counter: 0
      INFO [muorb] SLPI: Value of current accel x, y, z data: 0.000000, 0.000000, 0.000000
      INFO [muorb] SLPI: Value of current gyro x, y, z data: 0.000000, 0.000000, 0.000000
      INFO [muorb] SLPI: Value of HIL_Sensor counter: 0
      INFO [muorb] SLPI: Value of Heartbeat counter: 15
      INFO [muorb] SLPI: Value of Vision data counter: 0
      INFO [muorb] SLPI: Value of odometry counter: 0
      INFO [muorb] SLPI: Value of GPS Data counter: 0
      INFO [muorb] SLPI: Ok executing command: dsp_hitl status
    ==> Note that accel & gyro data are always zero AND only the heartbeat counter is incrementing.
    1. Inspection via Wireshark reveals that only heartbeat messages are flowing.
    Any help would be greatly appreciated
    • M MikeD
      Hi -
      @MikeD It doesn't look like the serial link is working. That count of heartbeats is just the heartbeats sent out from HITL on the VOXL2, it doesn't mean that there is anything coming back from the PC running Gazebo. it's possible that your cable isn't correct. You also get some odd messages from Gazebo. Here's what I see when I launch it:
      modalai@modalai-XPS-15-9570:~$ xhost +
      access control disabled, clients can connect from any host
      modalai@modalai-XPS-15-9570:~$ docker run --rm -it --net=host --privileged -e DISPLAY=$DISPLAY -v /dev/input:/dev/input:rw -v /tmp/.X11-unix:/tmp/.X11-unix:ro voxl-gazebo-docker ./run_gazebo.bash
      GAZEBO_PLUGIN_PATH :/usr/workspace/voxl2_hitl_gazebo
      GAZEBO_MODEL_PATH :/usr/workspace/voxl2_hitl_gazebo/models
      LD_LIBRARY_PATH :/usr/workspace/voxl2_hitl_gazebo/build
      Warning [parser.cc:833] XML Attribute[version] in element[sdf] not defined in SDF, ignoring.
      M 1 Reply Last reply
        M Offline
        M Offline
        MikeD
        The only difference I see is that I'm getting these status messages and you do not:
        Could this be a problem? Those websites do not appear to exist any longer. Also, if the serial cable was bad how would Wireshark be able to pick up heartbeats from HITL on VOXL2?
        • M MikeD
          @MikeD Ah, I see, Wireshark on PC sees heartbeats coming over serial line from VOXL 2. So that's a good sign. I am worried about those extra messages you get, I've never seen that so probably an indication that something isn't correct.
            M Offline
            M Offline
            MikeD
            @Eric-Katzfey We finally determined that the heart beat messages were going over an ethernet port and not from the FTDI cable. If I unplug the ethernet connection then we don't get heartbeats any longer. Is there a way to configure the VOXL2 to always use the FTDI connection via J18 on the board or should it just work?
            • M MikeD
              @MikeD The HITL driver runs on the DSP and only uses the serial port. There is no way to make it use Ethernet. What you were seeing was the standard heartbeats being sent out by the Mavlink module in PX4, not related to HITL. That allows you to connect a ground control station while using HITL.
                M Offline
                M Offline
                MikeD
                wrote on last edited by MikeD
                @Eric-Katzfey We think that Gazebo is transmitting over the serial link based on the following observation. While running Gazebo,
                if we power off the VOXL2 FlightDeck Gazebo reports the following:
                Exception sending a multicast message:Network is unreachable
                If we unplug the FTDI cable from the host Gazebo reports the following:
                Tx queue overflow
                By the way, the FTDI cable we are using is the MODAL AI MCBL-00091 - we tried two different cables with the same results.
                The hardware configuration is a VOXL2 FlightDeck. Could there be anything special we need to do to configure the FlightDeck?
                • M MikeD
                  Tx queue overflow
                  @MikeD Yes, Gazebo is transmitting over the serial link but it doesn't appear that PX4 receives anything based on dsp_hitl status.
                  • M MikeD
                    Tx queue overflow
                    @MikeD said in VOXL2 HITL:
                    MCBL-00091
                    I haven't had much luck with that cable for HITL. I use this: https://www.sparkfun.com/products/12977 and add this: https://www.sparkfun.com/products/17240
                    R 1 Reply Last reply
                      MCBL-00091
                      R Offline
                      R Offline
                      RyanH
                      @Eric-Katzfey , @MikeD and I were able to resolve the issue by swapping pins 2 and 3 on the MCBL-00091.
                      We found the following post on the forum: https://forum.modalai.com/topic/3511/serial-port-closed-and-other-hitl-errors. One of the posts notes that in order to use the MCBL-00091, pins 2 and 3 need to be swapped. This appears to be documented here: https://docs.modalai.com/cable-userguides/#m0163-4-pin-jst-to-4-pin-jst-cross-over-example.
                      Thanks for your help!
