  2. VOXL Dev Drones
  3. Starling & Starling 2
  4. Using Mocap with ROS 2 for Starling 2
5 Posts 3 Posters 1.8k Views
  • L Offline
    L Offline
    labkit
    wrote on last edited by labkit
    The flight cage I am using has an Optitrack motion capture camera system installed that communicates my Starling 2 drone's position data on the LAN using NatNet protocol. I have a ROS 2 package on my computer that can receive this data. I plan to transmit this data to the drone after it has been converted to the appropriate format. By referencing this guide, I see that mocap data should be published to the vehicle_visual_odometry topic. When PX4 is running on the drone, I can access the ROS 2 topic /fmu/in/vehicle_visual_odometry. However,when I publish test data to this topic it does not have any obvious effect. By using the ros2 topic echo command I can see that the data is indeed getting published. However, echoing the /fmu/out commands return nothing, including the commands that are supposed to return the drone's position.
    Publishing to /fmu/in/vehicle_visual_odometry
    Listening to /fmu/in/vehicle_visual_odometry while publishing topic
    Attempting to listen to /fmu/out topics
    When I disable PX4 with systemctl disable voxl-px4 I am able to view the data from these /fmu/out topics. But still, publishing to vehicle_visual_odometry does not change the /fmu/out readings that display vehicle position.
    Images of /fmu/out commands when not publishing to /fmu/in/vehicle_visual_odometry
    when publishing to /fmu/in/vehicle_visual_odometry
    • Zachary Lowell 0Z Offline
      Zachary Lowell 0
      @labkit can you confirm if you have VIO actively going as well? There could be competing information for incoming odometry messages - can you send a screenshot of voxl-inspect-services and then also show what you have for the value of ekf2_ev_ctrl.
      Zach
      L 1 Reply Last reply
        Zach
        L Offline
        L Offline
        labkit
        @Zachary-Lowell-0 I said yesterday that echoing the /fmu/out topics only worked if voxl-px4 was disabled on startup and run in a terminal with voxl-px4. This no longer appears to be the case, although I don't know what changed from yesterday to cause this. Now ros2 topic echo can print those topics when px4 is launched at startup. However, the topics still don't print the data I would expect if the drone were correctly reading the data I publish to /fmu/in/visual_odometry, unchanged from yesterday.
        The qvio server was on. I disabled it, but that didn't fix the issue of the drone not using the data from /fmu/in/vehicle_visual_odometry. I believe that shutting down this server should disable VIO, correct? This is the output after disabling qvio server and having px4 enabled to launch at startup.
        Here is the output of /fmu/out/vehicle odometry when I am not publishing to /fmu/in/vehicle_visual_odometry
        And here is the output when I am publishing to it using the command topic pub /fmu/in/vehicle_visual_odometry px4_msgs/msg/VehicleOdometry '{timestamp: 1234567890, timestamp_sample: 1, pose_frame: 1, position: [1.23, 4.56, 7.89], q: [0.707, 0.707, 0.0, 0.0], velocity_frame: 1, velocity: [0.5, 1.0, -2.3], angular_velocity: [0.1, 0.2, -0.3], position_variance: [0.01, 0.02, 0.03], orientation_variance: [0.001, 0.002, 0.003], velocity_variance: [0.005, 0.01, 0.02], reset_counter: 0, quality: 1}' which is supposed to provide it with test mocap data.
        This is the value of ekf2_ev_ctrl from QGroundControl.
          Zachary Lowell 0
          Understood - ofcourse disabling wont do much as it is the same thing as running it from command line/bash vs in systemd - I am surprised it created different results when running in systemd vs bash.
          Reason I want to disable/stop qvio is so that when you echo the /out topic you arent receiving anything from the ekf2 inside PX4 that is ingesting and creating the output.
          Lastly, the fmu/in/visual_odometry, and fmu/out/visual_odometry are not supposed to be the same - the fmu/out is post processing - they should differ as it fuses all sensor data and such - what is the movement you are expecting?
          Also have you checked the yaml file for PX4 - looks like there is a ros2 message specific just for mocap odometry.
          Link Preview Image
          px4-firmware/src/modules/microdds_client/dds_topics.yaml at 636ffefcb1a96ad2b53e988d23bf6419955b69ea · modalai/px4-firmware
          PX4 Autopilot Software. Contribute to modalai/px4-firmware development by creating an account on GitHub.
          favicon
          GitHub (github.com)
          Ricardo MetralR 1 Reply Last reply
            Link Preview Image
            favicon
            GitHub (github.com)
            Ricardo MetralR Offline
            Ricardo Metral
            I am having the exact same issue, if by any chance you see this @lakbit can you let me know if you found a solution since this thread?
