  3. QGC Starts up showing a heading of north no mater the direction of compass
voxl-2
29 Posts 2 Posters 7.1k Views 2 Watching
  • Chase RileyC Chase Riley
    @Eric-Katzfey I was also able to flash 1 of my 5 systems to SDK 1.1.2 just to check to see if I have the same issue and it seems I do. I have included an error I found while running voxl-px4 on my SDK 1.1.2.
    INFO  [muorb] SLPI: >>> ICM42688P this: 3176eba0
    INFO  [qshell] qshell return value timestamp: 46007098, local time: 46011498
    INFO  [muorb] SLPI: Register interrupt b21d31a4 e6201b3c 3176eba0
    INFO  [muorb] SLPI:
    INFO  [qshell] qshell return value timestamp: 46049655, local time: 46051360
    INFO  [qshell] qshell return value timestamp: 46090352, local time: 46091734
    ERROR [qshell] Command failed
    INFO  [muorb] SLPI:
    INFO  [qshell] qshell return value timestamp: 46128693, local time: 46130008
    INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097647
    INFO  [qshell] qshell return value timestamp: 46153157, local time: 46155078
    Looking for ncp5623c RGB LED
    @Chase-Riley That error is normal. It tries to start both mag drivers assuming that one will fail.
      INFO  [muorb] SLPI:
      INFO  [muorb] SLPI:
      @Chase-Riley Also, when arming is failing in position mode you can do a listener on the failsafe_flags topic to see what flags are set.
        @Chase-Riley It makes me believe that one of the rotations somewhere is not set correctly. What is SENS_BOARD_ROT set to? I guess we can just trace the topic messages through the system to see where it is getting confused. So you already did listener sensor_mag and you can see it publishing and the values updating regularly when you move the unit around? That topic goes to the sensors module that then publishes the vehicle_magnetometer topic. Can you do a listener on that to make sure it looks like it is working?
        Chase RileyC Offline
        Chase Riley
        @Eric-Katzfey running px4-listener sensor_mag shows the mag data and it changes as I move the GPS/Mag around. So that is behaving how I would expect it to SENS_BOARD_ROT is set to YAW 180. This is due to the VOXL2 being mounted 180 degrees rotated in the air frame.
        Everything seems to go well through an compass calibration. We have done quite a few while troubleshooting this.
        I will take a look at the failsafes when I try to go into position mode, however at this point I think the heading needs to be resolved first either way. Am I correct to think that when rotating the GPS/Mag separate from the VOXL2 I should see a heading change based on the direction of the GPS/Mag? In this case I only see the heading change when rotating the VOXL2 (Which to my knowledge has no Mag on board).
          @Chase-Riley Instead of setting SENS_BOARD_ROT you can set the rotation on the IMU driver to -R 4. But don't do both. I would try setting SENS_BOARD_ROT to 0 and keeping the -R 4 on the IMU driver start and see if that makes any difference. Also, do the listener vehicle_magnetometer to see if it is updating nicely like listener sensor_mag does.
            @Chase-Riley Is there any way that you can orient the board exactly as we have it in one of our drones (Sentinel, Starling) and use our parameter set and see if it works fine then?
            Chase RileyC 3 Replies Last reply
              Chase Riley
              @Eric-Katzfey I set SENS_BOARD_ROT to No rotation and made the change to the IMU driver as you mentioned and had the same results still always points north on startup. px4-listener vehicle_magnetometer updates nicely as just like px4-listener sensor_mag.
              I was able to flash the sentinel params on to the board and was able to match the orientation of the Sentinel and had the same results. I made sure to change the IMU driver back to original before this test.
                Chase Riley
                @Eric-Katzfey I went back in this morning and flashed the ci_sentinel-params which seems to be a entire param set and was able to get it working. Now I need to change the VOXL2 orientation. Would you recomend doing this through QGC or the voxl-px4-start? I am unsure which parameter caused it to start to work. Any insight would be appreciated so that I can make that change in my other systems with out having to change a bunch of params.
                  Chase Riley
                  @Eric-Katzfey I pulled the params from the system I have working and one of the systems that is having the Mag problem. Weirdly enough there is only 9 differences. I have listed them below. They all seem to be calibration differences if I understand correctly.
                  CAL_ACC0_XOFF
                  CAL_ACC0_YOFF
                  CAL_ACC0_ZOFF
                  CAL_GYRO0_XOFF
                  CAL_GYRO0_YOFF
                  CAL_GYRO0_ZOFF
                  CAL_MAG0_XSCALE
                  CAL_MAG0_YSCALE
                  CAL_MAG0_ZSCALE
                    CAL_ACC0_XOFF
                    CAL_ACC0_YOFF
                    CAL_ACC0_ZOFF
                    CAL_GYRO0_XOFF
                    CAL_GYRO0_YOFF
                    CAL_GYRO0_ZOFF
                    CAL_MAG0_XSCALE
                    CAL_MAG0_YSCALE
                    CAL_MAG0_ZSCALE
                    @Chase-Riley Huh, that's very interesting. I'm guessing that if the rotation isn't set properly and a calibration is done then those calibration parameters will be incorrect such that even when all rotations are specified correctly those old calibration values will mess everything up. So I guess that each time any rotation parameter or option is changed you need to go and recalibrate everything. For your case it seems like you should leave everything the same as Sentinel except change the rotation of the IMU driver in voxl-px4-start to -R 4 and then recalibrate everything.
                      Chase Riley
                      @Eric-Katzfey It is interesting. I was able to get this working on SDK 1.1.2. This morning I tried to follow the same procedure with one of my SDK 1.0 systems and have had no luck. I reflashed the sentinel params and changed the rotations back to factory just like I did on the SDK 1.1.2 system and had no luck. I am guessing next steps at this point will be to upgrade my SDK 1.0 system to SDK 1.1.2 and see if the issue is solved.
                        @Chase-Riley Definitely would recommend being on 1.1.2 at this point.
