William ChungW
William Chung
@William Chung
  • Input of tflite-server on voxl2
    William ChungW William Chung
    I am running yolov5 on tflite-server. The problem is when I change input_pipe to the rtsp-mpa, tflite-server don't show anything. Is there anything I need to process the stream?
    The tflite-server works fine with built-in stereo camera (RAW8 input)
    The rtsp-mpa code is here. It get rtsp video stream and output a 1280*720 RGB stream.
    import gi
    gi.require_version('Gst', '1.0')
    from gi.repository import Gst, GObject, GLib
    import numpy as np
    import time
    import cv2
    import sys
    from pympa import *
    print("init gstreamer")
    # Initialize GStreamer
    Gst.init(None)
    app_name    = 'voxl-camera-server'
    output_name = 'rtsp-debug'
    pympa_create_pub(output_name, app_name)
    def pub_image_mpa(img, frame_id):
        #convert from BGR (opencv native) to RGB
        img_out = cv2.cvtColor(img, cv2.COLOR_BGR2RGB) #cv2.cvtColor(img, cv2.COLOR_BGR2GRAY)
        #img_out = img
        meta              = camera_image_metadata_t()
        meta.magic_number = CAMERA_MAGIC_NUMBER
        meta.timestamp_ns = int(time.time() * 1000000000) #unknown from rtsp stream, so use current timestamp
        meta.frame_id     = frame_id
        meta.width        = img_out.shape[1]
        meta.stride       = meta.width
        meta.height       = img_out.shape[0]
        meta.size_bytes   = int(meta.width * meta.height * 3) #RGB888
        meta.exposure_ns  = 0 #unknown from rtsp stream
        meta.gain         = 0 #unknown from rtsp stream
        meta.format       = 10 # 0:IMAGE_FORMAT_RAW8, 1:IMAGE_FORMAT_NV12, 10:IMAGE_FORMAT_RGB
        meta.framerate    = 0
        pympa_publish_image(img_out,meta)
    def resize_frame(frame_data, width, height):
        resized_frame = cv2.resize(frame, (width, height))
        return resized_frame
    def convertYUVI420toNV12(i420byte, nv12byte, width, height):
        nLenY = width * height
        nLenU = nLenY // 4
        for i in range(nLenU):
            nv12byte[nLenY + 2 * i] = i420byte[nLenY + nLenU + i]  # U
            nv12byte[nLenY + 2 * i + 1] = i420byte[nLenY + i]      # V
        return nv12byte
    # Define the RTSP stream URL
    stream_url = 'rtsp://169.254.4.201:554/live0'
    # Create a GStreamer pipeline voxl-inspect-mavlink mavlink_onboard
    pipeline = Gst.parse_launch(f"rtspsrc location={stream_url} latency=0 ! rtph264depay ! h264parse ! avdec_h264 ! videoconvert ! appsink")
    # Start the pipeline
    pipeline.set_state(Gst.State.PLAYING)
    # fourcc = cv2.VideoWriter_fourcc(*'MJPG')
    # out = cv2.VideoWriter('output.avi', fourcc, 30.0, (1280, 720))
    # Main loop to read frames from pipeline and publish them to MPA
    frame_cntr = 0
    start_t = time.time()
    # while time.time() - start_t <= 5:
    print("start streaming")
    while True:
        # Retrieve a frame from the pipeline
        sample = pipeline.get_by_name('appsink0').emit('pull-sample')
        buffer = sample.get_buffer()
        result, info = buffer.map(Gst.MapFlags.READ)
        if result:
            # Convert the frame to numpy array
            data = np.ndarray((info.size,), dtype=np.uint8, buffer=info.data)
            # frame = np.reshape(data, (720, 640, 3))
            # Increment frame counter
            width = 1280
            height = 720
            y_size = width * height
            uv_size = int(y_size / 2)
            y_data = data[:y_size]
            u_data = data[y_size:y_size + uv_size]
            v_data = data[y_size + uv_size:]
            yuv_data_reshaped = np.concatenate((y_data, u_data, v_data))
            yuv_data_reshaped = yuv_data_reshaped.reshape((int(height * 1.5), width))
            frame = yuv_data_reshaped
            frame = cv2.cvtColor(yuv_data_reshaped, cv2.COLOR_YUV2BGR_I420)
            #frame = cv2.cvtColor(frame, cv2.COLOR_BGR2YUV_I420)
            #frame = cv2.cvtColor(frame, cv2.COLOR_YUV2YUV_I420)
            # frame = resize_frame(frame, 640, 480)
            def BGRtoNV12(frame):
                yuv = cv2.cvtColor(frame, cv2.COLOR_BGR2YUV_YV12)
                uv_row_cnt = yuv.shape[0] // 3
                uv_plane = np.transpose(yuv[uv_row_cnt * 2:].reshape(2, -1), [1, 0])
                yuv[uv_row_cnt * 2:] = uv_plane.reshape(uv_row_cnt, -1)
                frame = yuv
                return frame
            #BGRtoNV12(frame)
            frame_cntr += 1
            sys.stdout.write("\r")
            sys.stdout.write(f'got frame {frame_cntr} with dims {frame.shape}')
            sys.stdout.flush()
            pub_image_mpa(frame, frame_cntr)
            # out.write(frame)
        else:
            print("Error mapping buffer")
        # unmap buffer so that program would occupy the whole memoy and killed
        buffer.unmap(info)
    # out.release()
    # Stop the pipeline
    pipeline.set_state(Gst.State.NULL)
    General Questions tflite-server
