Wesley GunawanW
Wesley Gunawan
@Wesley Gunawan
  • VOXL 2 Camera Connected but Not Feed
    Wesley GunawanW Wesley Gunawan
    This is after power cycle (poweroff -f, power source off, turn on again)
    @Moderator voxl-camera-server -d0
    detected system image 1.7.8
    using new imx412 defaults
    configuration for 1 cameras:
    cam #0
    sensor type: imx412
    isEnabled: 1
    camId: 0
    camId2: -1
    fps: 30
    en_rotate: 0
    en_rotate2: 0
    en_preview:          1
    pre_width:           640
    pre_height:          480
    en_raw_preview:      0
    en_small_video:      1
    small_video_width:   1024
    small_video_height:  768
    en_large_video:      1
    large_video_width:   3840
    large_video_height:  2160
    en_snapshot:         0
    snap_width:          3840
    snap_height:         2160
    exif_focal_length:   0.000000
    exif_focal_len_35mm_format:0
    exif_fnumber:        0.000000
    ae_mode:             isp
    msv_exposure_min_us: 20
    msv_exposure_max_us: 33000
    standby_enabled:     0
    decimator:           1
    independent_exposure:0
    fsync_en: 0
    fsync_gpio: 109
    DEBUG: Attempting to open the hal module
    DEBUG: SUCCESS: Camera module opened on attempt 0
    DEBUG: ----------- Number of cameras: 1
    (Too long, in the end):
    VERBOSE: Entered thread: cam0-request(tid: 2735)
    DEBUG: Value of standby_active is: 0
    received SIGINT Ctrl-C
    ------ voxl-camera-server: Camera server is now stopping
    DEBUG: Stopping Camera: hires
    DEBUG: ------ Last request frame for hires: 0
    VERBOSE: Leaving hires request thread
    DEBUG: ------ Last hires result frame: -1
    VERBOSE: Leaving hires result thread
    DEBUG: ------ Last frame encoded: -1
    DEBUG: OMX_EventCmdComplete
    DEBUG: Deleting buffers for hires preview stream
    DEBUG: Deleting buffers for hires small video stream
    DEBUG: Deleting buffers for hires large video stream
    DEBUG: Deleting buffers for hires snapshot stream
    free(): invalid pointer
    Aborted
    voxl-inspect-cam -a output is the picture attached
    @Moderator I already tried that in the past, even before I consulted this forum, the output has always been like thisScreenshot_20241025-132204.png
    @Moderator It is camera configuration 8, the board wouldn't detect the camera otherwise (tried that before) so I'm assuming the camera configuration is correct.
    voxl2:~$ voxl-camera-server -d0
    cam #0
    sensor type: imx412
    isEnabled: 1
    camId: 0
    camId2: -1
    fps: 30
    en_rotate: 0
    en_rotate2: 0
    en_preview:          0
    pre_width:           640
    pre_height:          480
    en_raw_preview:      0
    en_small_video:      1
    en_large_video:      1
    en_snapshot:         1
    snap_width:          3840
    snap_height:         2160
    ae_mode:             isp
    standby_enabled:     0
    decimator:           1
    fsync_en: 0
    fsync_gpio: 109
    VERBOSE: cci-direct: using voxl_platform_mod config 0 layout
    DEBUG: Cam idx: 0, Cam slot: 2, Slave Address: 0x0034, Sensor Id: 0x0577
    connected to mavlink pipe
    DEBUG: ------ voxl-camera-server: Starting 1 cameras
    Starting Camera: hires (id #0)
    DEBUG: Checking Gain limits for Camera: hires
    DEBUG: Using gain limits min: 100 max: 1600
    DEBUG: cam ID 0 checking for fmt: 35 w: 1024 h: 768 o: 0
    DEBUG: ==> option 0: format= 34 width=4056 height=3040 is_input=0
    DEBUG: ==> option 4: format= 34 width=4056 height=3040 is_input=1
    DEBUG: ==> option 8: format= 35 width=4056 height=3040 is_input=0
    DEBUG: ==> option 12: format= 35 width=4056 height=3040 is_input=1
    DEBUG: ==> option 16: format= 33 width=4056 height=3040 is_input=0
    DEBUG: ==> option 20: format= 34 width=4000 height=3000 is_input=0
    DEBUG: ==> option 24: format= 34 width=4000 height=3000 is_input=1
    DEBUG: ==> option 28: format= 35 width=4000 height=3000 is_input=0
    DEBUG: ==> option 32: format= 35 width=4000 height=3000 is_input=1
    DEBUG: ==> option 36: format= 33 width=4000 height=3000 is_input=0
    DEBUG: ==> option 40: format= 34 width=3840 height=2160 is_input=0
    DEBUG: ==> option 44: format= 34 width=3840 height=2160 is_input=1
    DEBUG: ==> option 48: format= 35 width=3840 height=2160 is_input=0
    DEBUG: ==> option 52: format= 35 width=3840 height=2160 is_input=1
    DEBUG: ==> option 56: format= 33 width=3840 height=2160 is_input=0
    DEBUG: ==> option 60: format= 34 width=3264 height=2448 is_input=0
    DEBUG: ==> option 64: format= 34 width=3264 height=2448 is_input=1
    DEBUG: ==> option 68: format= 35 width=3264 height=2448 is_input=0
    DEBUG: ==> option 72: format= 35 width=3264 height=2448 is_input=1
    DEBUG: ==> option 76: format= 33 width=3264 height=2448 is_input=0
    DEBUG: ==> option 80: format= 34 width=3200 height=2400 is_input=0
    DEBUG: ==> option 84: format= 34 width=3200 height=2400 is_input=1
    DEBUG: ==> option 88: format= 35 width=3200 height=2400 is_input=0
    DEBUG: ==> option 92: format= 35 width=3200 height=2400 is_input=1
    DEBUG: ==> option 96: format= 33 width=3200 height=2400 is_input=0
    DEBUG: ==> option 100: format= 34 width=2976 height=2976 is_input=0
    DEBUG: ==> option 104: format= 34 width=2976 height=2976 is_input=1
    DEBUG: ==> option 108: format= 35 width=2976 height=2976 is_input=0
    (Too much to show, at the end of the output):
    VERBOSE: Dumping GBM flags
    DEBUG: Found flag GBM_BO_USAGE_CPU_READ_QTI
    DEBUG: Found flag GBM_BO_USAGE_CAMERA_WRITE_QTI
    DEBUG: Allocated BO with width=25054814 height=1 stride=25054814 aligned_w=25054814 aligned_h=1 size=25054814 flags=0x20003 format=GBM_FORMAT_BLOB fd=226 vaddr=0x7fe8aaae70
    DEBUG: Successfully set up pipeline for stream: SNAPSHOT
    DEBUG: Started Camera: hires
    ------ voxl-camera-server: Started 1 of 1 cameras
    VERBOSE: Entered thread: cam0-result(tid: 2676)
    VERBOSE: Entered thread: cam0-request(tid: 2675)
    VERBOSE: added request for small video stream
    VERBOSE: Sending request for frame 0 for camera hires for 1 streams
    VERBOSE: Received result from HAl3 for frame number 0
    VERBOSE: Received 0 buffers from camera hires, partial result:1
    VERBOSE: finished sending request for frame 0 for camera hires
    VERBOSE: returning from SendOneCaptureRequest for frame 1 for camera hires
    VERBOSE: Sending request for frame 1 for camera hires for 1 streams
    VERBOSE: finished sending request for frame 1 for camera hires
    VERBOSE: returning from SendOneCaptureRequest for frame 2 for camera hires
    VERBOSE: Sending request for frame 2 for camera hires for 1 streams
    VERBOSE: finished sending request for frame 2 for camera hires
    VERBOSE: returning from SendOneCaptureRequest for frame 3 for camera hires
    VERBOSE: Sending request for frame 3 for camera hires for 1 streams
    VERBOSE: finished sending request for frame 3 for camera hires
    VERBOSE: returning from SendOneCaptureRequest for frame 4 for camera hires
    VERBOSE: Sending request for frame 4 for camera hires for 1 streams
    VERBOSE: finished sending request for frame 4 for camera hires
    VERBOSE: returning from SendOneCaptureRequest for frame 5 for camera hires
    VERBOSE: Sending request for frame 5 for camera hires for 1 streams
    VERBOSE: Received result from HAl3 for frame number 1
    VERBOSE: Received result from HAl3 for frame number 2
    Killed
    @Moderator
    Hi, the camera is connected correctly because when the configuration or installation setup isn't correct, voxl-camera-server wouldn't even detect the camera's connection, in this case it does, but no input from the camera has ever been acquired. Here is the image of the setup:
    Is there any other information you need to help me debug this issue? It's been over a week and I need it working as soon as possible or else I have to return the whole kit. As for the camera defect possibility suggested by a user in this forum last week, I already tried swapping the camera and it still doesn't work.
    @tom ^ (Reminder)
    Hi Tom, I only have the access to the device several days a week, please let me know the complete information you need if further information is needed. Here is the outputs requested:
    voxl2:~$ cat /etc/modalai/voxl-camera-server.conf
    • voxl-camera-server Configuration File
    • Each camera has configurations for up to 4 HAL3 streams:
      • preview stream for raw unprocessed images from CV cameras
      • small_video 720p (ish) h264/h265 compressed for fpv video streaming
      • large_video 4k (ish) h264/h265 for onboard video recording to disk
      • snapshot ISP-processed JPG snapshots that get saved to disk
    • on QRB5165 platforms (VOXL2 and VOXL2 mini) you can only have 3 of the 4 enabled
    • This file is generated from default values by voxl-configure-cameras.
    • Do not expect arbitrary resolutions to work, the ISP and video compression
    • pipelines only support very specific resolutions.
    • The default video compression mode is cqp or Constant Quantization Parameter
    "version": 0.1,
    "fsync_en": false,
    "fsync_gpio": 109,
    "cameras": [{
    "type": "imx412",
    "name": "hires",
    "enabled": true,
    "camera_id": 0,
    "fps": 30,
    "en_preview": false,
    "preview_width": 640,
    "preview_height": 480,
    "en_raw_preview": false,
    "en_small_video": true,
    "small_video_width": 1024,
    "small_video_height": 768,
    "small_venc_mode": "h265",
    "small_venc_br_ctrl": "cqp",
    "small_venc_Qfixed": 30,
    "small_venc_Qmin": 15,
    "small_venc_Qmax": 40,
    "small_venc_nPframes": 9,
    "small_venc_mbps": 2,
    "en_large_video": true,
    "large_video_width": 3840,
    "large_video_height": 2160,
    "large_venc_mode": "h265",
    "large_venc_br_ctrl": "cqp",
    "large_venc_Qfixed": 38,
    "large_venc_Qmin": 15,
    "large_venc_Qmax": 50,
    "large_venc_nPframes": 29,
    "large_venc_mbps": 30,
    "en_snapshot": true,
    "en_snapshot_width": 3840,
    "en_snapshot_height": 2160,
    "exif_focal_length": 0,
    "exif_focal_length_in_35mm_format": 0,
    "exif_fnumber": 0,
    "ae_mode": "isp"
    voxl2:~$ voxl-inspect-sku
    family code: TF-M0054 (voxl2-test-fixture)
    compute board: 4 (voxl2)
    hw version: 1
    cam config: 11
    modem config: 0 (none)
    tx config: 0 (none)
    extras config: 0 (none)
    SKU: TF-M0054-4-V1-C11
    @tom Thank you for replying Tom. I am aware that voxl-camera-server was already running in the background, the reason why I manually run it is just to show that the camera hardware is connected properly. When I do voxl-inspect-cam -a, I don't see any output that indicates the image sensors receive any input information like it's supposed to be based on the documentation. The only thing that I saw was an empty table with hires_large_color, hires_large_encoded, .etc (basically everything in the Multi-View).
    We are experiencing difficulties accessing the IMX412 camera connected to our VOXL 2 (connector 8). While voxl-camera-server successfully detects the camera, we are unable to view the camera feed through the voxl-portal webserver or the RTSP stream. Additionally, camera input is not visible during inspection.
    We have attached detailed information about our setup for your review.
    This is a time-sensitive project, and we require a prompt resolution to avoid further delays. If the issue cannot be resolved quickly, we may need to consider returning the kit for a refund.
    voxl2:~$ voxl-version
    system-image: 1.7.8-M0054-14.1a-perf
    kernel: #1 SMP PREEMPT Fri May 17 23:29:23 UTC 2024 4.19.125
    hw platform: M0054
    mach.var: 1.0.0
    voxl-suite: 1.3.5
    Packages:
    Repo: http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.3/binary-arm64/
    Last Updated: 2024-10-11 18:06:54
    List:
    kernel-module-voxl-fsync-mod-4.19.125 1.0-r0
    kernel-module-voxl-gpio-mod-4.19.125 1.0-r0
    kernel-module-voxl-platform-mod-4.19.125 1.0-r0
    libfc-sensor 1.0.7
    libmodal-cv 0.5.11
    libmodal-exposure 0.1.1
    libmodal-journal 0.2.2
    libmodal-json 0.4.3
    libmodal-pipe 2.10.2
    libqrb5165-io 0.4.6
    libvoxl-cci-direct 0.2.3
    libvoxl-cutils 0.1.1
    modalai-slpi 1.1.19
    mv-voxl 0.1-r0
    qrb5165-bind 0.1-r0
    qrb5165-dfs-server 0.2.0
    qrb5165-imu-server 1.0.1
    qrb5165-rangefinder-server 0.1.3
    qrb5165-slpi-test-sig 01-r0
    qrb5165-system-tweaks 0.3.0
    qrb5165-tflite 2.8.0-2
    voxl-bind-spektrum 0.1.1
    voxl-camera-calibration 0.5.7
    voxl-camera-server 2.0.1
    voxl-ceres-solver 2:1.14.0-10
    voxl-configurator 0.8.5
    voxl-cpu-monitor 0.4.8
    voxl-docker-support 1.3.1
    voxl-elrs 0.2.2
    voxl-esc 1.4.7
    voxl-feature-tracker 0.4.1
    voxl-flow-server 0.3.6
    voxl-fsync-mod 1.0-r0
    voxl-gphoto2-server 0.0.10
    voxl-gpio-mod 1.0-r0
    voxl-jpeg-turbo 2.1.3-5
    voxl-lepton-server 1.2.3
    voxl-lepton-tracker 0.0.2
    voxl-libgphoto2 0.0.4
    voxl-libuvc 1.0.7
    voxl-logger 0.4.7
    voxl-mavcam-manager 0.5.7
    voxl-mavlink 0.1.1
    voxl-mavlink-server 1.4.2
    voxl-modem 1.1.3
    voxl-mongoose 7.7.0-1
    voxl-mpa-to-ros 0.3.9
    voxl-mpa-tools 1.2.3
    voxl-neopixel-manager 0.0.3
    voxl-open-vins 0.4.14
    voxl-open-vins-server 0.2.75
    voxl-opencv 4.5.5-2
    voxl-osd 0.0.1
    voxl-platform-mod 1.0-r0
    voxl-portal 0.7.0
    voxl-px4 1.14.0-2.0.84
    voxl-px4-imu-server 0.1.2
    voxl-px4-params 0.5.3
    voxl-qvio-server 1.0.4
    voxl-remote-id 0.0.9
    voxl-reset-slpi 0.0.1
    voxl-state-estimator 0.0.2
    voxl-streamer 0.7.4
    voxl-suite 1.3.5
    voxl-tag-detector 0.0.4
    voxl-tflite-server 0.3.4
    voxl-utils 1.4.3
    voxl-uvc-server 0.1.7
    voxl-vision-hub 1.8.9
    voxl-vtx 1.1.0
    voxl2-io 0.0.3
    voxl2-system-image 1.7.8-r0
    voxl2-wlan 1.0-r0
    --------------------------------------------------------------------------------downsized_image_1.png downsized_image_2.png downsized_image_3.png
