Tyler ScottT
Tyler Scott
@Tyler Scott
  • No ADB Devices showing up on VOXL 2
    Tyler ScottT Tyler Scott
    I'm setting up my VOXL 2 (on a Starling 2 drone) for the first time and running into an issue where no devices show up when I run adb devices. The drone is powered via the external battery, and I can see a solid green LED on the VOXL 2, which I understand indicates that it has booted successfully. I'm connecting the drone to my PC using a USB Type-A to Type-C data cable and have tried multiple known-good cables and USB ports. However, nothing appears in adb devices, and lsusb doesn't list any new devices when I connect the drone. I also monitored the output of dmesg -w and didn’t see any USB events when plugging in the cable.
    I’m using WSL (Windows Subsystem for Linux) with Ubuntu, so I’m wondering if that might be contributing to the issue.
    Any help with troubleshooting this would be greatly appreciated.
  • How to stream sensor data from VOXL 2 to Unreal Engine?
    I'm working with VOXL 2 and would like to stream live or recorded sensor data (e.g., camera, IMU, GPS) into a simulation environment like Unreal Engine.
    I’m currently using the VOXL SDK and aware of voxl-mpa-to-ros2 for publishing data to ROS 2 topics.
    Is there a recommended way to bridge this data into Unreal Engine? Also, does VOXL 2 support video streaming via RTSP or similar protocols?
    Any guidance or reference examples would be appreciated.
