Techsawi TechsawiT
Techsawi Techsawi
@Techsawi Techsawi
  • Replacement for trcking camera
    Techsawi TechsawiT Techsawi Techsawi
    Hi, my tracking camera and VIO were working perfectly until yesterday , as I had a crash landing the tracking camera got damaged (the connector part of the camera cable came out ), So I'm looking for alternate methods to replace the tracking camera,
    Is it possible to connect the hires camera in J4 as a replacement for the tracking camera?
    Or Can I connect the hires camera to any other port and is it possible to Give that feed to the VIO server by modifying the config files?
    Please suggest to me the possible ways to replace the tracking camera ...
  • Link VIO to stereo instead of tracking camera
    Hi @marian I'm trying the same solution as my tracking camera is not working, are you able to get it working this way?
    yocto:/etc/modalai$ voxl-qvio-server
    loading qvio config file
    imu_name: imu1
    cam_name: stereo_l
    odr_hz: 30.000
    use_camera_height_bootstrap: 1
    camera_height_off_ground_m: 0.100
    enable_init_while_moving: 1
    cam_imu_timeshift_s: 0.002
    cam_imu_timeshift_s_uncertainty: 0.001
    T_cam_wrt_imu_uncertainty: 0.005 0.005 0.005
    R_cam_to_imu_uncertainty: 0.040 0.040 0.040
    accl_fsr_ms2: 156.000
    gyro_fsr_rad: 34.000
    accl_noise_std_dev: 0.316
    gyro_noise_std_dev: 0.010
    cam_noise_std_dev: 100.000
    min_std_pixel_noise: 0.500
    fail_high_pixel_noise_points: 1.665
    limited_imu_bw_trigger: 35.000
    gps_imu_time_alignment_s: 0.000
    T_gps_wrt_imu: -0.115 0.450 0.100
    enable_mapping: 1
    enable_gps_vel: 0
    exising instance of qvio-server found, attempting to stop it
    setting scheduler
    WARNING Failed to set priority, errno = 1
    This seems to be a problem with ADB, the scheduler
    should work properly when this is a background process
    ERROR failed to set scheduler
    loading extrinsics config file
    #0:
    parent: imu1
    child: stereo_l
    T_child_wrt_parent: 0.017 0.015 0.013
    RPY_parent_to_child: 0.0 0.0 90.0
    R_child_to_parent: 0.000 -1.000 0.000
    1.000 0.000 -0.000
    0.000 0.000 1.000
    tbc: 0.017 0.015 0.013
    ombc: 0.000 0.000 1.571 (axis angle)
    ombc: 0.000 0.000 90.000 (RPY deg)
    loading /data/modalai/opencv_tracking_intrinsics.yml
    using camera intrinsics:
    focal lengths: 291.001662 291.248381
    principle points: 303.812740 244.632261
    distortion: -0.007658 -0.008713 0.013827 -0.003393
    MachineVision is licensed as community user
    LNX_8074 supported? 1
    LNX_8096 supported? 1
    LNX_IA64 supported? 1
    WINDOWS supported? 0
    AR ERROR: arFileOpen(): Failed to open file: /etc/modalai/vislam/Configuration.SF.xml
    FASTCV: fcvAvailableHardware Linux
    mempool cur block size 307200, new block size 307200
    Please ignore the error about Configuration.SF.xml above. ^^^
    It's an optional file, and should be a warning not an error
    waiting for imu
    waiting for cam
    connected to imu server
