Tanishq DuhanT
Tanishq Duhan
@Tanishq Duhan
  • Using voxl-configure-mpa erased the parameters_baro_tc.cal file
    Tanishq DuhanT Tanishq Duhan
    (voxl-suite: 1.4.5)
    Hi, I recently bought a Starling 2 Max drone, and I was following the developer bootcamp to get the drone running indoors.
    While following the First Flight Tutorial, I noticed that the drone didn't have a valid position estimate. I traced this to the fact that the voxl-qvio-server was |Disabled| and |Not Running|.
    To fix this, I used the "voxl-configure-mpa" command. While this fixed the original issue, and now voxl-qvio-server is |Enabled| and |Running|, I've got a missing /data/px4/param/parameters_baro_tc.cal file, and no idea how to calibrate it.
    My output for $ voxl-check-calibration
    Calibration File Status:
    Present /data/modalai/voxl-imu-server.cal
    Present /data/modalai/opencv_tracking_front_intrinsics.yml
    Present /data/modalai/opencv_tracking_down_intrinsics.yml
    Present /data/px4/param/parameters_gyro.cal
    Present /data/px4/param/parameters_acc.cal
    Present /data/px4/param/parameters_level.cal
    Missing /data/px4/param/parameters_baro_tc.cal
    Present /data/px4/param/parameters_mag.cal
    Detected Missing Calibration Files
    please run the required cals
    https://docs.modalai.com/calibration/
    Although the drone runs well in Position control mode, even with the missing cal file, I am worried if this affect the position estimate of the drone.
    I tried, following Documentation, but am unsure if there is a way to configure just this sensor, as I don't really want to mess with the working conf files. Also, is there a way to get the default/factory conf files back?
    Thank you for your help!
