Samer JaradatS
Samer Jaradat
@Samer Jaradat
  • Sentinel PX4 ( NO GPs Lock and firmware problem )
    Samer JaradatS Samer Jaradat
    @Eric-Katzfey
    this is our GPS status right now
    INFO [muorb] SLPI: qshell gotten: gps status
    INFO [muorb] SLPI: Main GPS
    INFO [muorb] SLPI: protocol: UBX
    INFO [muorb] SLPI: status: NOT OK, port: 6, baudrate: 0
    INFO [muorb] SLPI: sat info: disabled
    INFO [muorb] SLPI: rate reading: 0 B/s
    INFO [muorb] SLPI: Ok executing command: gps status
    INFO [muorb] SLPI: Sending qshell retval with timestamp 855143719, current timestamp 855143720
    INFO [qshell] qshell return value timestamp: 855143719, local time: 855147735
    pxh>
    Development Drones sentinel
    @Eric-Katzfey
    this is file open when i use vi program ( no command qshell gps start -d 7 -b 115200 in script file )
    this is all file command :
    #!/bin/sh
    PX4 commands need the 'px4-' prefix in bash.
    (px4-alias.sh is expected to be in the PATH)
    . px4-alias.sh
    Figure out what platform we are running on.
    Eventually there will be a utility called voxl-platform that will
    return the platform tag or an error code. This utility is not yet
    ubiquitous so it may be that it isn't available. Trying to call a
    non existent program will generate an error code by the OS. If the
    program exists and doesn't return an error code then use the results.
    PLATFORM=/usr/bin/voxl-platform 2> /dev/null
    RETURNCODE=$?
    if [ $RETURNCODE -ne 0 ]; then
    # If we couldn't get the platform from the voxl-platform utility then check
    # then we assume that we are on M0052. Otherwise assume M0054.
    VERSIONSTRING=$(</etc/version)
    M0052SUBSTRING="M0052"
    if [[ "$VERSIONSTRING" == "$M0052SUBSTRING" ]]; then
    PLATFORM="M0052"
    else
    PLATFORM="M0054"
    fi
    fi
    We can only run on M0052 or M0054 so exit with error if that is not the case
    if [ $PLATFORM = "M0052" ]; then
    /bin/echo "Running on M0052"
    if [ "$RC" == "CRSF" ]; then
    /bin/echo "Error, crossfire not supported on M0052!"
    exit 0
    fi
    elif [ $PLATFORM = "M0054" ]; then
    /bin/echo "Running on M0054"
    else
    /bin/echo "Error, cannot determine platform!"
    exit 0
    fi
    uorb start
    muorb start
    In order to just exit after starting the uorb / muorb modules define
    the environment variable MINIMAL_PX4. (e.g. export MINIMAL_PX4=1)
    This is useful for testing / debug where you may want to start drivers
    and modules manually from the px4 command shell
    if [ ! -z $MINIMAL_PX4 ]; then
    /bin/echo "Running minimal script"
    exit 0
    fi
    #!/bin/sh
    . px4-alias.sh
    RETURNCODE=$?
    PLATFORM="M0052"
    else
    PLATFORM="M0054"
    fi
    fi
    exit 0
    fi
    else
    exit 0
    fi
    uorb start
    muorb start
    exit 0
    fi
    Sleep a little here. A lot happens when the uorb and muorb start
    and we need to make sure that it all completes successfully to avoid
    any possible race conditions.
    /bin/sleep 1
    IMU (accelerometer / gyroscope)
    Start this first because it gets the high rate interrupts coming in to the
    DSP. Without this the DSP will oversleep and miss critical timeouts.
    TODO: Why is that the case?
    if [ "$IMU" == "ROTATE_IMU_YAW_180" ]; then
    /bin/echo "Starting IMU driver with yaw 180 rotation"
    qshell icm42688p start -s -R 4
    else
    fi
    /bin/sleep 1
    Load in all of the parameters that have been saved in the file
    param load
    Start logging and use timestamps for log files when possible.
    Add the "-e" option to start logging immediately. Default is
    to log only when armed
    logger start -t
    We do not change the value of SYS_AUTOCONFIG but if it does not
    show up as used then it is not reported to QGC and we get a
    #!/bin/sh
    . px4-alias.sh
    RETURNCODE=$?
    PLATFORM="M0052"
    else
    PLATFORM="M0054"
    fi
    fi
    exit 0
    fi
    else
    exit 0
    fi
    uorb start
    muorb start
    exit 0
    fi
    /bin/sleep 1
    else
    fi
    /bin/sleep 1
    param load
    logger start -t
    missing parameter error.
    param touch SYS_AUTOCONFIG
    Start all of the device drivers on DSP
    Magnetometer
    if [ "$GPS" == "MATEK" ]; then
    # Use this line for the magnetometer in the Matek Systems M8Q-5883 module
    /bin/echo "Starting Mateksys M8Q-5883 magnetometer"
    qshell qmc5883l start -R 10 -X -b 1
    elif [ "$GPS" == "HERE3" ]; then
    # Use this line for the magnetometer in the Here3 GPS module
    /bin/echo "Starting Here3 ak09916 magnetometer"
    qshell ak09916 start -R 2 -X
    else
    # Use this line for the magnetometer in the Holybro GPS module
    /bin/echo "Starting Holybro magnetometer"
    qshell ist8311 start -R 10 -X -b 1
    fi
    LED driver for the Pixhawk 4 GPS module
    Older units have i2c address 0x39 (57) and newer ones 0x38 (56)
    M0054 only supports the newer one. M0052 can support either.
    qshell rgbled_ncp5623c start -X -b 1 -f 400 -a 57
    fi
    102,18 33%
    else
    qshell ist8310 start -R 10 -X -b 1
    fi
    fi
    if [ "$GPS" == "HOLYBRO" ]; then
    /bin/echo "Starting Holybro LED driver"
    qshell rgbled_ncp5623c start -X -b 1 -f 400 -a 56
    # Use this line for the Here3 GPS module LED controller
    /bin/echo "Starting Here3 LED"
    qshell rgbled start -X -f 400
    fi
    Barometer
    qshell icp10100 start -I -b 5
    ESC driver
    We start this even if there is a PX4IO module. If there is
    a PX4IO (M0065) module it will be plugged into the RC port
                                                              117,1         39%
    @Eric-Katzfey
    when i open vi program this is the result as shown on my pc i cant show the command that need to editing
    GNU nano 2.9.3 /etc/modalai/voxl-px4.config
    #!/bin/sh
    . px4-alias.sh
    RETURNCODE=$?
    # /etc/version to see if there is an M0052 substring in the version string.$
    [ Read 271 lines ]
    ^G Get Help ^O Write Out ^W Where Is ^K Cut Text ^J Justify ^C Cur Pos
    ^X Exit ^R Read File ^\ Replace ^U Uncut Text^T To Linter ^_ Go To Line
    @Eric-Katzfey
    OK, but i don't know how we can edit it,
    please tell me how i can edit it and save it.
    @Eric-Katzfey
    adb shell creat this result after do this command.
    voxl2:/$ /etc/modalai/voxl-px4.config
    bash: /etc/modalai/voxl-px4.config: Permission denied
    @tom
    no txt file created after do this command on my computer / tmp
  • No GPs lock for vehicle
    no text file created
    voxl2:/$ px4-qshell gps status
    INFO [qshell] Send cmd: 'gps status'
    INFO [qshell] qshell return value timestamp: 2376085469, local time: 2376088441
    voxl2:/$ ^C
    voxl2:/$ px4-listener sensor_gps
    never published
    never published
    voxl2:/$ journalctl --no-pager -b -u voxl-px4 > /tmp/test.txt
    -- Logs begin at Thu 2023-03-02 12:58:02 UTC, end at Fri 2023-06-23 18:06:16 UTC. --
    Jun 23 16:24:45 m0054 systemd[1]: Starting px4...
    Jun 23 16:24:50 m0054 systemd[1]: Started px4.
    Jun 23 16:24:50 m0054 bash[1691]: Found DSP signature file
    Jun 23 16:24:50 m0054 bash[1691]: Running on M0054
    Jun 23 16:24:52 m0054 bash[1691]: INFO [qshell] Send cmd: 'icm42688p start -s'
    Jun 23 16:24:52 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 11522033, local time: 11523559
    Jun 23 16:24:54 m0054 bash[1691]: Starting Holybro magnetometer
    Jun 23 16:24:54 m0054 bash[1691]: INFO [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
    Jun 23 16:24:54 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14344064, local time: 14345444
    Jun 23 16:24:54 m0054 bash[1691]: Starting Holybro LED driver
    Jun 23 16:24:54 m0054 bash[1691]: INFO [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
    Jun 23 16:24:54 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14401400, local time: 14402064
    Jun 23 16:24:54 m0054 bash[1691]: INFO [px4] mlockall() enabled. PX4's virtual address space is locked into RAM.
    Jun 23 16:24:54 m0054 bash[1691]: INFO [px4] assuming working directory is rootfs, no symlinks needed.
    Jun 23 16:24:54 m0054 bash[1691]: ______ __ __ ___
    Jun 23 16:24:54 m0054 bash[1691]: | ___ \ \ \ / / / |
    Jun 23 16:24:54 m0054 bash[1691]: | |/ / \ V / / /| |
    Jun 23 16:24:54 m0054 bash[1691]: | __/ / \ / /
    Jun 23 16:24:54 m0054 bash[1691]: | | / /^\ \ ___ |
    Jun 23 16:24:54 m0054 bash[1691]: _| / / |_/
    Jun 23 16:24:54 m0054 bash[1691]: px4 starting.
    Jun 23 16:24:54 m0054 bash[1691]: INFO [px4] Calling startup script: /bin/sh /etc/modalai/voxl-px4.config 0
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread hpwork
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_hpwork with tid 83
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread lpwork
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_lpwork with tid 82
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wkr_hrt
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wkr_hrt with tid 81
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread client_sync_thread
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_client_sync_thread with tid 80
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_manager
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_manager with tid 79
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread qshell
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 78
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: icm42688p start -s
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_SPI1
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_SPI1 with tid 76
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
    Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensor_accel
    Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_topic
    Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensor_gyro
    Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Advertising remote topic imu_server
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: on SPI bus 1
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: icm42688p #0 on SPI bus 1 (devid=0x0)
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: icm42688p start -s
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 11522033, current timestamp 11522034
    Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Advertising remote topic qshell_retval
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
    Jun 23 16:24:54 m0054 bash[1691]: ERROR [muorb] SLPI: Cannot reset all parameters on client side
    Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic parameter_update
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_topic
    Jun 23 16:24:54 m0054 bash[1691]: INFO [uorb] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
    Jun 23 16:24:54 m0054 bash[1691]: INFO [logger] logger started (mode=all)
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: ist8310 start -R 10 -X -b 1
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_I2C1
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_I2C1 with tid 75
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: *** I2C Device ID 0x60e09 396809
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: ist8310 #0 on I2C bus 1 (external)
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: ist8310 start -R 10 -X -b 1
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14344064, current timestamp 14344065
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: *** I2C Device ID 0x7b3809 8075273
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1 (external)
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14401400, current timestamp 14401401
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: icp10100 start -I -b 5
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_I2C5
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_I2C5 with tid 74
    Jun 23 16:24:54 m0054 bash[1691]: INFO [muorb] SLPI: *** I2C Device ID 0x9c6329 1024INFO [qshell] Send cmd: 'icp10100 start -I -b 5'
    Jun 23 16:24:54 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14434955, local time: 14435823
    Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] Send cmd: 'modalai_esc start'
    Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14487155, local time: 14487822
    Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] Send cmd: 'mixer load /dev/uart_esc quad_x.main.mix'
    Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14542181, local time: 14543199
    Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] Send cmd: 'voxlpm start -X -b 2'
    Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14585276, local time: 14586089
    Jun 23 16:24:55 m0054 bash[1691]: Starting Holybro GPS
    Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] Send cmd: 'gps start -d 7 -b 115200'
    Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14617107, local time: 14618038
    Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] Send cmd: 'px4io detect'
    Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] cmd returned with: -17
    Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14668509, local time: 14669837
    Jun 23 16:24:55 m0054 bash[1691]: ERROR [qshell] Command failed
    Jun 23 16:24:55 m0054 bash[1691]: M0065 not detected, starting Spektrum RC driver
    Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] Send cmd: 'spektrum_rc start -d 8'
    Jun 23 16:24:55 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 14706420, local time: 14708458
    Jun 23 16:24:56 m0054 bash[1691]: 9001
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: probe probe succeeded. data = 0x1 0x48
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: icp10100 #0 on I2C bus 5
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: icp10100 start -I -b 5
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14434955, current timestamp 14434956
    Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensor_mag
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: modalai_esc start
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_hp_default
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_hp_default with tid 73
    Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic test_motor
    Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensor_baro
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: modalai_esc start
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14487155, current timestamp 14487156
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Opened UART ESC device
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: mixer load /dev/uart_esc quad_x.main.mix
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_rate_ctrl
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_rate_ctrl with tid 71
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: mixer load /dev/uart_esc quad_x.main.mix
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14542181, current timestamp 14542182
    Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic actuator_outputs
    Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic multirotor_motor_limits
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_I2C2
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_I2C2 with tid 4169
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: *** I2C Device ID 0x784411 7881745
    Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic battery_status
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: voxlpm #0 on I2C bus 2 (external)
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14585276, current timestamp 14585277
    Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic power_monitor
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: gps start -d 7 -b 115200
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread gps
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_gps with tid 70
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: gps start -d 7 -b 115200
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14617107, current timestamp 14617107
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: px4io detect
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: serial port fd 2
    Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: px4io read failed
    Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: px4io io_reg_get(0,0,1): data error -5
    Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: IO not installed
    Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: Detection attempt 2 failed
    Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: Detection attempt 1 failed
    Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: Detection attempt 0 failed
    Jun 23 16:24:56 m0054 bash[1691]: ERROR [muorb] SLPI: Failed to execute command: px4io detect
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14668509, current timestamp 14668510
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: spektrum_rc start -d 8
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread spektrum_rc_main
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 67
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: spektrum_rc start -d 8
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 14706420, current timestamp 14706421
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: sensors start
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_nav_and_controllers
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_nav_and_controllers with tid 66
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: sensors start
    Jun 23 16:24:56 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 15763186, current timestamp 15763187
    Jun 23 16:24:56 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_angINFO [qshell] Send cmd: 'sensors start'
    Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 15763186, local time: 15766524
    Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] Send cmd: 'ekf2 start'
    Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 15924808, local time: 15926148
    Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] Send cmd: 'mc_pos_control start'
    Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 15977526, local time: 15978641
    Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] Send cmd: 'mc_att_control start'
    Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 16020779, local time: 16021799
    Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] Send cmd: 'mc_rate_control start'
    Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 16076014, local time: 16077458
    Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] Send cmd: 'mc_hover_thrust_estimator start'
    Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 16115582, local time: 16117055
    Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] Send cmd: 'land_detector start multicopter'
    Jun 23 16:24:56 m0054 bash[1691]: INFO [qshell] qshell return value timestamp: 16150880, local time: 16151957
    Jun 23 16:24:57 m0054 bash[1691]: ular_acceleration
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_angular_velocity
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Creating qurt thread wq_INS0
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Successfully created px4 task PX4_wq_INS0 with tid 65
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_imu
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_imu_status
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensors_status_imu
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_acceleration
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_air_data
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensor_selection
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic sensor_combined
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: ekf2 start
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: ekf2 start
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 15924808, current timestamp 15924809
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic ekf2_timestamps
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: mc_pos_control start
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: mc_pos_control start
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 15977526, current timestamp 15977527
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: mc_att_control start
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: mc_att_control start
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 16020779, current timestamp 16020780
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: mc_rate_control start
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: mc_rate_control start
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 16076014, current timestamp 16076015
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 16115582, current timestamp 16115583
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: qshell gotten: land_detector start multicopter
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Ok executing command: land_detector start multicopter
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Sending qshell retval with timestamp 16150880, current timestamp 16150881
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_land_detected
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: 16481861: reset position to last known position
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: 16481861: reset velocity to zero
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_local_position
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic vehicle_odometry
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic estimator_states
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic estimator_status
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic estimator_status_flags
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic estimator_innovations
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic estimator_innovation_test_ratios
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic estimator_innovation_variances
    Jun 23 16:24:57 m0054 bash[1691]: INFO [dataman] Unknown restart, data manager file '/data/px4/dataman' size is 11798680 bytes
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic position_setpoint_triplet
    Jun 23 16:24:57 m0054 bash[1691]: INFO [commander] LED: open /dev/led0 failed (22)
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic led_control
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic tune_control
    Jun 23 16:24:57 m0054 bash[1691]: INFO [PreFlightCheck] Failed EKF health preflight check while waiting for filter to settle
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic vehicle_control_mode
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic vehicle_status
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic actuator_armed
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic commander_state
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic rate_ctrl_status
    Jun 23 16:24:57 m0054 bash[1691]: INFO [uorb] Advertising remote topic actuator_controls_0
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic vehicle_status_flags
    Jun 23 16:24:57 m0054 bash[1691]: INFO [muorb] SLPI: Advertising remote topic vehicle_command
    voxl2:/$ /tmp/test.txt
    bash: /tmp/test.txt: Permission denied
    voxl2:/$
    @Eric-Katzfey
    never published
    this is the result
  • Sentinel PX4 firmware update
    @tom
    OK this is my title ( Sentinel PX4 ( NO GPS Lock and firmware problem ) )
    please review it.
    I've got some Sentinels that have been sitting on a shelf since last fall that I'm trying to get up and running for indoor flight tests. I've been running into some errors when trying to arm them via qgroundcontrol. For reference these are running with the microhard carrier add-on and two pMDDL2450 radios to communicate back and forth.
    I'm unable to enable GPS even after updating the EKF2_AID_MASK parameter, I get frequent MAG#0 Timeout warnings and I have a pretty high loss rate over MAVLink. Also when the vehicles are ready to arm and I can get the motors to spin for a second and then some failsafe is enable that shuts everything down and forces the vehicle to reboot. When that happens I get the following logs in the QGC console:
    ""_handleCommandAck command(MAV_CMD_COMPONENT_ARM_DISARM)result(MAV_RESULT_ACCEPTED)""
    "_handleCommandAck Ack not in list "MAV_CMD_COMPONENT_ARM_DISARM"
    I also get the following error when navigating around the vehicle settings in QGC:
    "Parameters are missing from firmware. You may be running a version of firmware which is not fully supported or your firmware has a bug in it. Missing paramsL 1:SDLOG_MODE"
    I'm wondering if any of this has to do with the voxl-px4 firmware and whether updating it would help. These are running voxl-px4 version1.12.31beta 352462912_803653048098626_8696777585441101018_n.jpg 356112415_1288905648711495_7985451779473636071_n.jpg 356264180_1207399063268837_8454904516466682716_n.jpg
    Who I flashed release of the sentinels with the SDK 0.9.5 and to solve at least a few of the issues Are there specific steps ?
    Please tell me the details that help to solve these problems and how we can get rid of them as soon as possible
    @josephmlullo
    I am facing the same problems that you are facing. Please tell me the details that help to solve these problems and how we can get rid of them as soon as possible. Please explain to me the previous step in detail to get rid of this problem
    @tom
    I am happy to communicate with you.
    I need some help. I received my sentinels several days ago, and now I am running it, but I am facing some problems like this one. I am new to this type of UAV. I want you.
    Who I flashed release of the sentinels with the SDK 0.9.5 and to solve at least a few of the issues Are there specific steps to include? Please help me in this regard with many thanks
  • No Gps location in QGC when conent in wifi
    When i conenct my drone in wifi using QGCs i cant find my Gps location”the massege is No GPs lock for vehicle” the massege is Gps disable all time how can i enable it and how i can lock my location using Gps
    Feature Requests
