Johnny KeelerJ
Johnny Keeler
@Johnny Keeler
Global Moderator
  • Unable to start voxl-dfs-server
    Johnny KeelerJ Johnny Keeler
    Hi Tamas...
    you started it correctly and i'd like to ask if you've followed it up with a couple other steps to just check the situation.
    First after the configuration is set up, which you've done correctly, the device usually needs a full restart to begin working.
    After the restart, check 'voxl-inspect-services' again to make sure the service is Enabled and Running, just to check.
    If that passes the check, run 'ifconfig' to get your ip and post it in a web page browser. Among the available selections should be 'VOA PC' and should give you some positive results.!
    Screenshot from 2022-10-27 11-36-44.png Screenshot from 2022-10-26 17-42-25.png
