John KellerJ
John Keller
@John Keller
  • Bots Unlimited Wifi Crash
    John KellerJ John Keller
    Hi Luke,
    The fix has been working very well on our drones. There were certain things, like downloading large amounts of data, that would trigger the problem very consistently and after the fix it has been working. Thank you for all the help.
    We encountered a new crash that happened for a different reason than what the patch fixed. It looks like a USB transport error on the RX transfers (EOVERFLOW, then EPROTO), after which the driver stops resubmitting RX and never reports the link down. This happened while apt installing packages. We have only seen this type of crash once. Here is a link to the output of the collect script along with some other info that claude thought might be helpful: https://drive.google.com/file/d/1clRCxrHUqIgw3P5EQwbC14zVKAzlFJm2/view?usp=sharing
    Hi Luke,
    Sorry for the late response. When I ran the verification after installing and power cycling, I got this:
    unit enabled : static
    unit state   : failed
    [up=112s] driver not present (mlan0 or /proc/mwlan/adapter0 missing)
    RESULT: NOT ACTIVE -- ADDBA timeout reads '<unreadable>', expected 0
    It seems like it is because my system is missing mlanutl. Claude thinks there is a specific of version of that program that I might need. If you know the version, I can build it or if you wanted to sent the binary that would work too, whichever is easier. Here is claude's full summary in case it helps:
    I read the bundle and ran read-only checks against the drone (no changes made). The install is fine — the problem is a missing dependency the script never names.
    What's actually wrong
    mlanutl does not exist on this board. Nothing else is broken.
    On 10.3.1.82 right now:
    check result
    mlan0 up, holds 10.3.1.82/16 — you are SSH'd in over it
    /proc/mwlan/adapter0 present (config, mlan0/, uap0/)
    lsmod usbxxx + mlan loaded, USB dev 1286:204e (post-firmware, normal)
    mlan0 registered at uptime 7.9 s, associated at 11.4 s
    find / -name mlanutl* nothing — not in /usr/sbin, not in any package
    The botsu-sparrow 1.0.8-r0 deb ships 9 files (2 .ko, 6 firmware blobs, sparrow.conf) and no userspace tools; ModalAI's voxl2-wlan doesn't provide mlanutl either. Their bench board has it, yours never did.
    Why that produces those two misleading messages
    sparrow-ba-fix.sh:53 —
    have_driver() {
        [ -d "$ADAP" ] || return 1
        [ -x "$MLANUTL" ] || return 1     # <-- fails here
        ip link show "$IFACE" >/dev/null 2>&1 || return 1
    MLANUTL falls back to /usr/sbin/mlanutl, which doesn't exist, so have_driver returns false while the driver is perfectly healthy. Every caller then lies:
    • status prints driver not present (mlan0 or /proc/mwlan/adapter0 missing) — both of which are present.
    • apply-wait spins 15 × 2 s and prints mlan0 did not appear within 30s, hence unit state: failed.
    • verify's own mlanutl mlan0 addbapara produces nothing → '<unreadable>'.
    The journal confirms the wiring works: udev fired on mlan0 creation and started the unit at up=8 s (matching the 7.9 s dmesg line), and it died at up=38 s — exactly the 30 s loop. (The journal's wall clocks look 13 min apart because the VOXL2 has no RTC and the clock jumps once the network syncs; trust the up= numbers.) unit enabled: static is also expected — the unit has no [Install] section on purpose; udev starts it.
    Meanwhile the crash trigger is live and unmitigated — /proc/mwlan/adapter0/mlan0/debug shows BA streams on tid 0 and tid 4, win_size 64, at the default 65535 TU timeout.
    What to change
    1. Ask ModalAI for an aarch64 mlanutl built against this driver, and ask them to add it to the botsu-sparrow deb. The version string to quote them:
      USB8997---16.197.121.p2-MX5X16505.p7.2-(FP197), firmware 16.197.121.
      (mlanutl lives in NXP's mxm_wifiex tree at mapp/mlanutl — buildable yourself, but it drives private ioctls whose subcommand numbering tracks the driver release, so ask which release the sparrow build came from rather than grabbing an arbitrary tag.)
    2. Drop it at /usr/sbin/mlanutl, chmod 755. Then no power cycle is needed — it's a runtime ioctl: sh /usr/sbin/sparrow-ba-fix.sh apply, then sh sparrow-ba-install.sh verify should read ADDBA timeout = 0. The existing udev rule + oneshot will then handle it at every boot with no reinstall.
    3. Consider reinstalling as install monitor instead of oneshot — the setting is runtime-only and silently reverts on a module reload or warm reset, which is exactly the situation you're in after a wifi wedge.
    Two things worth sending back to ModalAI with the request: the deb ships no mlanutl, and have_driver() conflates "tool missing" with "driver missing" — that's what sent you looking at the power cycle instead of the toolchain. Same as the region_code note, it's a packaging gap on their side.
    Also note robot/setup/copy.sh runs this installer on every drone you provision, so all of them will fail verify identically until mlanutl is in the image.
    Hi Luke,
    I uploaded the wifcap and corresponding dump file here https://drive.google.com/drive/folders/11nv9jt6RslnnnDXi7DgAw6W-eMBwbSsG.
    The crash is sporadic in general but I was able to make it happen pretty consistently by viewing the hires_small_color image though the web gui. We have the rgb camera, forwards and downward tracking camera, and tof sensor. The only modifications we have done are removing the downward range sensor, adding some neopixel leds, and putting a larger ground plane on the gps. We have seen the crash before removing the range sensor and adding the leds. We usually run a ros2 autonomy stack and stream the hires camera via gstreamer. We see it happen randomly while doing this.
    Thanks,
    John
    Thank you for looking into it. Here is a google drive link. [https://drive.google.com/drive/folders/1cRrAo7wXScs-se2wVErIZE_t8HV11EbR?usp=sharing](link url)
    containing the /data/dump. dump_958 is from a crash that just happened. The other files in there are things that claude thought might be relevant.
    @Hector-Nevarez Hi Hector,
    Here is the output of voxl-wifi getmode
    WiFi is currently set up as follows:
    	Mode: station
    	Hardware: Concurrent STA+AP capable (AP:uap0, STA:mlan0)
    	Station: Active on mlan0 - "Chiron"
    	SoftAP: Disabled
    Thank you!
    Here is the relevant part from dmesg
    [ 2130.644295] FW trigger fw dump
    [ 2130.644332] =====FW trigger dump====
    [ 2130.644347] ==== Start Receive FW dump event  ====
    [ 2130.645036] Create directory /data/dump_2130 successfully
    [ 2130.645058] Firmware Dump directory name is /data/dump_2130
    [ 2130.645078] === START DRIVER INFO DUMP===
    [ 2130.645180] DRV dump data in /data/dump_2130/file_drv_info
    [ 2130.653905] Drv info total bytes = 205002 (0x320ca)
    [ 2130.653933] === DRIVER INFO DUMP END===
    [ 2131.373918] ==== FW DUMP END: 1381912 bytes ====
    [ 2131.374101] Start to process hanging
    [ 2131.374170] Cancel all pending cmd and txrx queue
    [ 2131.374381] Block woal_cfg80211_del_key in abnormal driver state
    [ 2131.374408] Block woal_cfg80211_del_key in abnormal driver state
    [ 2131.374430] Block woal_cfg80211_del_key in abnormal driver state
    [ 2131.374451] Block woal_cfg80211_del_key in abnormal driver state
    [ 2131.374472] Block woal_cfg80211_del_key in abnormal driver state
    [ 2131.374493] Block woal_cfg80211_del_key in abnormal driver state
    [ 2131.477115] Block woal_cfg80211_scan in abnormal driver state
    [ 2132.479524] Block woal_cfg80211_scan in abnormal driver state
    [ 2133.481978] Block woal_cfg80211_scan in abnormal driver state
    [ 2134.484164] Block woal_cfg80211_scan in abnormal driver state
    [ 2135.486210] Block woal_cfg80211_scan in abnormal driver state
    [ 2136.489052] Block woal_cfg80211_scan in abnormal driver state
    [ 2137.491936] Block woal_cfg80211_scan in abnormal driver state
    We are using the Bots Unlimited wifi board attached directly to our voxl2 board. It seems like the wifi driver will sometimes randomly crash with this message being repeated in dmesg: "Block woal_cfg80211_scan in abnormal driver state". When this happens the drone can no longer connect to wifi. We couldn't find any way in software to reboot the wifi board. To get it working again we have to power cycle the drone. Is there a fix for this?
  • Failing to boot
    I was using the voxl2 on my starling 2 drone out in the sun for a few hours on a ~80 F day. Commands which would normally be responsive like ros2 topic echoing, etc. were taking a long time to output any text so I thought it might be overheating and powered it off.
    A few days later I tried turning it on and it doesn't boot up. I can't connect over adb shell. I get the following output from dmesg when plugging it in:
    [31549.649340] usb 1-9: new high-speed USB device number 15 using xhci_hcd
    [31549.800919] usb 1-9: New USB device found, idVendor=05c6, idProduct=900e, bcdDevice= 0.00
    [31549.800933] usb 1-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [31549.800937] usb 1-9: Product: QUSB_BULK_SN:C67DF5D4
    [31549.800941] usb 1-9: Manufacturer: Qualcomm CDMA Technologies MSM
    [31549.800944] usb 1-9: SerialNumber: 22d3828
    I see this in lsusb
    Bus 001 Device 015: ID 05c6:900e Qualcomm, Inc. QUSB_BULK_SN:C67DF5D4
    fastboot devices doesn't list anything.
    Is there a way to fix or debug this? Thank you.
  • EGL example for voxl2
    I saw that the voxl2 supports OpenGLES 3.1 and I would like to port over some of our OpenGL code to run on the voxl2. I am starting off by trying to get EGL to initialize with the following program but it is failing on the call to eglInitialize with error 0x3001 which is EGL_NOT_INITIALIZED. I am building with gcc egl-query.c -o egl-query -lEGL.
    Is there any examples of using EGL/OpenGL or does anyone know how to get this working?
    Thank you
    #include <EGL/egl.h>
    #include <EGL/eglext.h>
    #include <stdio.h>
    int main(void)
        EGLDisplay display;
        EGLint major, minor;
        display = eglGetDisplay(EGL_DEFAULT_DISPLAY);
        if (display == EGL_NO_DISPLAY) {
            printf("eglGetDisplay failed\n");
            return 1;
        if (!eglInitialize(display, &major, &minor)) {
            EGLint err = eglGetError();
            printf("eglInitialize failed (0x%x)\n", err);
            return 1;
        printf("EGL initialized successfully\n");
        printf("EGL version: %d.%d\n", major, minor);
        const char* vendor     = eglQueryString(display, EGL_VENDOR);
        const char* version    = eglQueryString(display, EGL_VERSION);
        const char* extensions = eglQueryString(display, EGL_EXTENSIONS);
        const char* clientapis = eglQueryString(display, EGL_CLIENT_APIS);
        printf("EGL_VENDOR:      %s\n", vendor ? vendor : "(null)");
        printf("EGL_VERSION:     %s\n", version ? version : "(null)");
        printf("EGL_CLIENT_APIS: %s\n", clientapis ? clientapis : "(null)");
        printf("EGL_EXTENSIONS:\n%s\n", extensions ? extensions : "(null)");
        eglTerminate(display);
        return 0;
