Harel YadidH
Harel Yadid
@Harel Yadid
  • running voxl-tflite-server dev
    Harel YadidH Harel Yadid
    Thanks for the answer!
    it worked great after the upgrades.
    what I am trying to do now is to run the deeplab dnn, but I am having some issues.
    I tried to run the 865 build but i couldn't run any tflite dnn.
    then I tried to run the 820 build which worked perfectly and than added manually the deeplab dnn.
    eventually i received the error:
    do you have any suggestions?
    VOXL SDK and Software mpa
    hi,
    I have been trying to run the new voxl-tflite-server dev branch but when I ran the ./deploy_to_voxl_sh, I received the error: Screenshot from 2022-03-07 13-38-47.png
    Is it possible to solve it?
    just in case it matters: I built using ./install_build_deps.sh dev and ./build.sh 820
  • voxel-portal shared libraries error
    Thanks for the answer, I found another solution as well that worked for me.
    It is probably more intuitive for experts, but i noticed that in the third party from your git you should also imply git submodule init and git submodule update .
    After doing that, the old instructions worked semi-properly, and I could reinstall the voxl-portal package with not farther problems. It's just the README files that were not so obvious in explaining so.
    Hi.
    I've been trying to calibrate my tracking camera with the voxel-calibration-camera in
    3.3 voxl version.
    The problem is i cannot see the front view of the camera, or any interface.
    I noticed there is voxl-portal , however when i try to run adb shell voxl-portal i receive the following message:
    voxl-portal: error while loading shared libraries: libmongoose.so: cannot open shared object file: No such file or directory
    I tried to create a voxl-portal pkg manually but there are missing third party repos such as mongoose and jpeg-turbo, and I am having difficulties trying to merge them or even build them according to the voxel gitlab (the mongoose holds jpeg-turbo README, and i also couldn't found submodules in the voxel-portal as mentioned ).
    any help?
    if there is a way to push in the libmongoose.so, I would like to know how to do it,
    but if there is a global solution, I would prefer that.
    Thanks in advance
