    1. Home
    2. daniel.p.nikolov
    D
    • Profile
    • Following 0
    • Followers 0
    • Topics 4
    • Posts 6
    • Best 0
    • Controversial 0
    • Groups 0
    Posts made by daniel.p.nikolov
    • RE: Issue recognizing camera MSU-0107 using M0135 dual camera board
      PXL_20241118_174146798.jpg Alex,
      Currently using the following Config:
      M0107 -> FPC-M0036 Cable -> M0135 Upper Port -> J7 Port.
      Using the same setup as in the M0107 Product Page.
      Tried various setups, however, it does not see any camera connected to the VOXL2.
      posted in VOXL 2
      D
      daniel.p.nikolov
    • Issue recognizing camera MSU-0107 using M0135 dual camera board
      Firmware and settings for running MSU-0107 with the M0135 dual camera expander board. I have been trying to find a firmware and camera setup that will recognize that the camera is connected.
      posted in VOXL 2 m0135 msu-0107 camera firmware
      D
      daniel.p.nikolov
    • Starling 2 Drone Micro Coax Cables
      I see that the Starling 2 drone is utilizing a lot of micro coax cables for board and camera inter-connections. Are these special cables or are the freely available from you or a vendor? Do you have upcoming plans to use them more?
      posted in Starling & Starling 2
      D
      daniel.p.nikolov
    • RE: Voxl2 Wifi not working
      @Hector-Nevarez
      system-image: 1.2.1-M0054-14.1a-perf
      lsmod reports nothing:
      Module Size Used by
      posted in VOXL 2
      D
      daniel.p.nikolov
    • Voxl2 Wifi not working
      I purchased the AWUS036ACS dongle and cant get it to work on the Voxl2. I am using a USB connection through a microhard board. When I run lsusb it sees the realtek controller however, it doesnt automatically create the wlan0 instance so I cannot connect to a wifi source. Is there something I am missing or will I have to compile a driver for the dongle before I can use it. It is one of the three that is supported on your site so I assumed connection would be relatively automatic.
      posted in VOXL 2
      D
      daniel.p.nikolov
    • 5G expansion board Peripherals
      Is the 5G M2 slot capable of hosting a WiFi card? Is there plans to support a particular card in the future rather than running a USB Dongle?
      Thanks.
      posted in VOXL 2
      D
      daniel.p.nikolov
