C
Chris P
@Chris P
  • GPS time
    C Chris P
    @Chris-P
    to answer my own question, I checked the voxl-vision-px4 code and the system time will be set once from gps time (when valid) if it has not been set yet by ntp or manually.
  • GPS time
    C Chris P
    @Alex-Gardner
    Thanks for the clarification. I am planning to have a local network enabled but without internet/ntp server. Is there a way to trigger the gps time sync manually in this situation ?
    Chris
  • GPS time
    C Chris P
    I would like to be able to synchronize event across multiple platform by using gps time (or unix time based on gps time).
    I checked the gps_raw_int message which contains a timestamp but it only seems to be the time since boot and not an unix timestamp. It also seems like the sys_timestamp message might have a gps converted unix time but I am not sure if this message is available as a MPA pipe on the voxl side.
    Any pointer to get gps time synchronization would be appreciated 🙂 !
    Chris
  • ZMQ library
    C Chris P
    Thanks Steve,
    I went to compile the source code with the voxl emulator and it compiled without issues.
  • ZMQ library
    C Chris P
    Is there an existing package to get ZMQ (c++ binding) available on the platform ?
    Thank you!
