Amilia SchimmelA
Amilia Schimmel
@Amilia Schimmel
  • Storage location
    Amilia SchimmelA Amilia Schimmel
    @Eric-Katzfey thank you for your help
  • Storage location
    Just wondering where Voxl2's Logs are stored, is there an SD card, or is it stored onboard? also for recording video, is it stored onboard or SD card? is there an sd card location, if so where?
    Thanks
  • vio/ camera server/ streamer
    @Chad-Sweet thank you!
    hi, im trying to provide less load on the voxl2, so that I can attach more cameras, USB camera, plus thermal camera. I've turned off the rear stereo cameras, only using the front stereo, hires, and tracking now. I've noticed that too many cameras on at once, will not load frames on voxl-portal, so now I have a few questions. assuming voxl-portal is off, will vio work if the camera-server is off? do i need to have camera-server running in order to use voxl-streamer on qgroundcontrol? can i subscribe to my USB cameras using voxl-streamer only, on qgroundcontrol?
  • VOXL 2 SIM Card slot
    We have just received the VOXL 2 flight deck and are trying to insert a sim card to use the LTE function of the flight deck. we are having issues identifying the best way it access it as its location is at the center of the flight deck with the frame also blocking access to the sim card slot. is there a way to access the slot without entirely disassembling the flight deck?
