A
Alan_S
@Alan_S
  • VRX Ground Unit Baked In OSD Elements
    A Alan_S
    There are a number of OSD elements managed by the VRX Ground Unit that are not configurable (e.g. link status/health, the various symbols in the upper left corner, the center-screen crosshair). The position of several of these seems to have changed from when I ordered my first batch of Ground Units to my second, as link health moved from the middle-left side of the screen to the bottom left.
    This is a bit of a headache; I am implementing a few custom OSD elements by forking voxl-osd, and the layout that works on one set of receivers now collides with elements on receivers from the other batch. I don't see a way to update the voxl-vtx package to unify my fleet on my end, and as OSD config is per-drone instead of per VRX, I can't reliably manage it that way either.
    I would love to be able to configure the position of these elements myself rather than rely on their default placement, and to be able to hide those that aren't relevant for my specific use case (e.g. I have no use for the flashlight indicator).
    Failing that, guidance on how to update my first wave of Ground Units would be lovely.
    Development Drones fpv
  • Stinger FPV Cam Assembly Model/Shop Ambiguity
    A Alan_S
    Similarly, I cannot find the model for the new "slim" VTX mount, only the older, taller one.
    Development Drones stinger
    A Alan_S
    I have not been able to find a STEP for the Stinger v2's FPV cam assembly without the Boson- while there is a published Stinger STEP, it is for the Stinger with Boson. Is this model available, and if not, could it be published?
    Similarly, the "Stinger Spare Parts" page on the ModalAI Shop includes a "Stinger IMX664 FPV Cam Assembly, V2 ModalAI Alum FPV Config". Is that for the Boson or Boson-less variant? How would one specify an order for one or the other?
  • voxl-vtx and voxl-vrx source not on gitlab?
    A Alan_S
    The source for the voxl-vtx and voxl-vrx services appears to be missing from the gitlab.
    https://gitlab.com/voxl-public/voxl-sdk/ci-status lists voxl-vtx as the next to last entry under services, but the links are dead. voxl-vrx is not referenced anywhere.
    Is this intentional?
  • Latest voxl-cross images missing?
    A Alan_S
    @ZuraNeb Perfect! Thank you!
    A Alan_S
    The voxl gitlab for voxl-cross lists v4.8 as latest, but the latest version available on https://downloads.modalai.com is v4.4. Similarly, the sysroots required to build v4.8 are also not listed on https://downloads.modalai.com.
    This is an issue for me, as I'm working on a fork of voxl-osd, which lists voxl-cross 4.6+ as a requirement.
    Is this omission intentional? If not, any chance someone could upload voxl-cross v4.8?
  • Stinger not responding to throttle (and only throttle)
    A Alan_S
    I forgot to post the resolution, oops.
    It was indeed turtle mode. That channel was not mapped on my remote, and I ended up having to adjust the relevant PX4 parameters to disable turtle mode entirely.
    Thank you for the assistance!
    A Alan_S
    I have a Stinger running SDK 1.5, and I am unable to takeoff. Connecting the drone to QGroundControl gives me a "Ready to Fly" status, and I am able to pair my remote with it successfully.
    On setting to Manual mode, arming, and throttling up, the status in QGroundControl transitions to "Armed" then "Flying". However, the props do not actually move. Trying to pitch, roll, or yaw does cause the appropriate pair of props to begin spinning, but no matter what value I set the throttle to, the drone doesn't actually spin all 4 props at once to take off.
    Here is a quick log demoing the behavior.
    https://logs.px4.io/plot_app?log=ff2de1e2-4a90-452a-aaba-8ce57933b60b
    Any assistance would be appreciated.
