    1. Home
    2. 이광철
    • Profile
    • Following 0
    • Followers 0
    • Topics 1
    • Posts 15
    • Best 1
    • Controversial 0
    • Groups 0
    Posts made by 이광철
    • RE: voxl_spi_init, failed to open /dev/spidev device: No such file or directory.
      @modaltb
      Hi.
      I try a test on voxl-mini with your advice applied.
      voxl-mini sdk version is 1.0.0
      My program and spi device operates is normal.
      Thanks for your advice.
      posted in FAQs
      이광철이
      이광철
      @Alex-Kushleyev
      Yes.
      After executing voxl-gpio -w 67 1, run my test.
      voxl-gpio -r 67
      posted in FAQs
      이광철이
      이광철
      @Alex-Kushleyev
      I tested it by connecting my spi device to j10.
      This spi device is working normally in voxl2.
      My program for testing also operates normally with this spi device in voxl2.
      voxl_spi_init(SPI_BUS, SPI_MODE_0, VOXL_SPI_MAX_SPEED) is OK
      but, there is no response to the voxl_spi_write function.
      posted in FAQs
      이광철이
      이광철
      @Alex-Kushleyev
      Please note that qrb5165io-spi-test -d 14 is a test app that just tries to detect a specific IMU on the SPI port. If the specific IMU is not connected, the test will not be successful.
      Yes I know.
      My spi device and test program works fine on volx2's J10.
      Please refer to j10 in the url below.
      https://docs.px4.io/main/en/flight_controller/modalai_voxl_2.html
      posted in FAQs
      이광철이
      이광철
      @이광철
      Alex-Kushleyev sorry.
      voxl2-mini:~$ cd /usr/bin
      voxl2-mini:/usr/bin$ spidev_test -D /dev/spidev3.0 -p "\x76\x00\xF5\x00"
      spi mode: 0x0
      bits per word: 8
      max speed: 500000 Hz (500 KHz)
      can't send spi message: Invalid argument
      Aborted
      This test was my mistake.
      Below are the final test results.
      spi mode: 0x0
      bits per word: 8
      RX | 00 00 00 47 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ | ...G
      posted in FAQs
      이광철이
      이광철
      @Alex-Kushleyev
      I tested according to your advice.
      This is the result of testing on my mini.
      spi mode: 0x0
      bits per word: 8
      Aborted
      posted in FAQs
      이광철이
      이광철
      @Alex-Kushleyev
      Hi.
      However, when I test the spi device and test program on voxl mini, there is no response to the voxl_spi_write function.
      Also, the test below is the same as before.
      voxl2-mini:/dev$ qrb5165io-spi-test -d 14
      There is no response to the qrb5165io-spi-test -d 14 command.
      I need your help and thanks in advance.
      posted in FAQs
      이광철이
      이광철
      @Alex-Kushleyev
      I will connect my spi device and let you know the results after testing.
      Thanks for your help.
      posted in FAQs
      이광철이
      이광철
      @Alex-Kushleyev
      I downloaded voxl2-mini_SDK_1.0.0.tar.gz from https://developer.modalai.com/asset/eula-download/127
      It was tested as follows.
      C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>adb reboot bootloader
      C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>fastboot flash boot_a qti-ubuntu-robotics-image-m0104-boot.img
      Sending 'boot_a' (17552 KB) OKAY [ 0.399s]
      Writing 'boot_a' OKAY [ 0.023s]
      Finished. Total time: 0.565s
      C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>fastboot flash boot_b qti-ubuntu-robotics-image-m0104-boot.img
      Sending 'boot_b' (17552 KB) OKAY [ 0.397s]
      Writing 'boot_b' OKAY [ 0.019s]
      Finished. Total time: 0.561s
      C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>fastboot reboot
      Rebooting OKAY [ 0.000s]
      Finished. Total time: 0.005s
      C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>adb shell
      system-image: 1.7.1-M0104-14.1a-perf-nightly-20231025
      kernel: #1 SMP PREEMPT Fri May 19 22:53:15 UTC 2023 4.19.125
      hw version: M0104
      voxl-suite: 1.1.2
      no current network connection
      voxl2-mini:/dev$ ls spi*
      spidev0.0 spidev11.0 spidev14.0 spidev3.0
      OK!
      The spidev14.0 file exists.
      I tested it as below:
      voxl2-mini:/dev$ qrb5165io-spi-test -d 0
      failed to ping icm42688p IMU
      voxl2-mini:/dev$ qrb5165io-spi-test -d 11
      voxl2-mini:/dev$ qrb5165io-spi-test -d 3
      [INFO] success! ICM42688 Detected
      is this right?
      Is spidev14.0 not working?
      posted in FAQs
      이광철이
      이광철
      @Alex-Kushleyev
      I downloaded voxl2-mini_SDK_1.1.1.tar.gz from https://developer.modalai.com/asset/eula-download/141
      C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>fastboot boot qti-ubuntu-robotics-image-m0104-boot.img
      Sending 'boot.img' (17548 KB) OKAY [ 0.382s]
      Booting OKAY [ 0.034s]
      Finished. Total time: 0.471s
      kernel: #1 SMP PREEMPT Thu Oct 26 04:23:26 UTC 2023 4.19.125
      hw version: M0104
      voxl-suite: 1.1.2
      spidev14.0 still does not exist.
      There is something strange.
      Why voxl-suite: 1.1.2?
      voxl-suite: 1.1.1 Isn't that correct?
      posted in FAQs
      이광철이
      이광철
      @Alex-Kushleyev
      just to double check.. after building the kernel, did you install it to voxl2 mini?
      Yes
      I built the kernel and installed it on voxl2-mini.
      The process is as follows.
      Sending 'boot_a' (20088 KB) OKAY [ 0.458s]
      Writing 'boot_a' OKAY [ 0.026s]
      Finished. Total time: 0.637s
      Sending 'boot_b' (20088 KB) OKAY [ 0.463s]
      Writing 'boot_b' OKAY [ 0.032s]
      Finished. Total time: 0.654s
      Rebooting OKAY [ 0.001s]
      Finished. Total time: 0.006s
      C:\Users\User\Desktop\OpenSDP\platform-tools_r33.0.3-windows\platform-tools>adb wait-for-device
      kernel: #1 SMP PREEMPT Wed Mar 27 02:44:30 UTC 2024 4.19.125
      hw version: M0104
      voxl-suite: 1.1.2
      posted in FAQs
      이광철이
      이광철
      @Alex-Kushleyev
      First of all thank you for your advice.
      build_mount/lu.um.1.2.1/apps_proc/poky/meta-voxl2-bsp/recipes-kernel/linux-msm/files/dts/m0104/m0104-modalai-qupv3.dtsi
      /* M0104 - J10 - GPIO 40-44 */
      &qupv3_se14_spi {
      status = "ok";
      /* M0104 - J10 JST connector */
      &qupv3_se14_2uart {
      status = "disabled";
      Modified as above.
      After building the kernel, the contents of /dev are as follows.
      Why doesn't spidev14.0 exist?
      What am I doing wrong?
      voxl2-mini:/dev$ ls spidev*
      spidev0.0 spidev3.0
      voxl2-mini:/dev$ ls tty*
      tty tty10 tty13 tty16 tty19 tty21 tty24 tty27 tty3 tty32 tty35 tty38 tty40 tty43 tty46 tty49 tty51 tty54 tty57 tty6 tty62 tty8 ttyprintk
      tty0 tty11 tty14 tty17 tty2 tty22 tty25 tty28 tty30 tty33 tty36 tty39 tty41 tty44 tty47 tty5 tty52 tty55 tty58 tty60 tty63 tty9
      tty1 tty12 tty15 tty18 tty20 tty23 tty26 tty29 tty31 tty34 tty37 tty4 tty42 tty45 tty48 tty50 tty53 tty56 tty59 tty61 tty7 ttyMSM0
      posted in FAQs
      이광철이
      이광철
      @Alex-Kushleyev
      Hi.
      I rebuilt the kernel referring to your advice.
      The modified contents are as follows.
      modify file: build_mount/lu.um.1.2.1/apps_proc/poky/meta-voxl2-bsp/recipes-kernel/linux-msm/files/dts/m0104/m0104-modalai-qupv3.dtsi
      &qupv3_se14_spi {
      status = "ok";
      &qupv3_se14_2uart {
      status = "ok";
      ./qrb5165-clean.sh
      ./qrb5165-build.sh -m M0104
      After building the kernel, ttyMSM0 was created in /dev.
      However, spidev14.0 is still not found.
      ls /dev/spidev*
      spidev0.0 spidev3.0
      I'm looking forward to your advice.
      Thanks.
      posted in FAQs
      이광철이
      이광철
      @admin
      Do I need to change the kernel to use spi14 using the voxl_spi_init function?
      or
      Is this possible using voxl2_SDK_1.1.1?
      Thanks
      posted in FAQs
      이광철이
      이광철
    • voxl_spi_init, failed to open /dev/spidev device: No such file or directory.
      Hello.
      I have voxl2 mini.
      The system and kernel versions are as follows.
      hw version: M0104
      voxl-suite: 1.1.2
      I want to use j10 External UART in spi mode.
      I called the voxl_spi_init function as below.
      SPI_BUS = 14;
      if (voxl_spi_init(SPI_BUS, SPI_MODE_0, 12000000) < 0)
      return FALSE;
      The result is ERROR in voxl_spi_init, failed to open /dev/spidev device: No such file or directory.
      The results of ls -al /dev/spi* are as follows:
      crw------- 1 root root 153, 0 Mar 2 2023 spidev0.0
      crw------- 1 root root 153, 1 Mar 2 2023 spidev3.0
      The result of voxl-gpio -r 67 are as follows:
      where is spidev14.0?
      Or what am I doing wrong?
      Thanks.
      posted in FAQs
      이광철이
      이광철
