  3. Query /run/mpa/vvpx4_sys_status in terminal
4 Posts 2 Posters 755 Views 1 Watching
  • W Offline
    W Offline
    wouter
    I like to query the data from /run/mpa/vvpx4_sys_status from inside a docker container.
    I'm running docker with -v /run/mpa/:/run/mpa:rw, so I can see /run/mpa/vvpx4_sys_status
    Is there a way to read the data without using modal_pipe_client?
    I tried cat /run/mpa/vvpx4_sys_status/request but that just stalls.
    I'm running dotnet in the container and tried using NamedPipeClientStream, but that eventually gives a time-out.
      Hi, this is not a plaintext pipe and won't show any viewable data with a cat. The data coming through is in the mavlink packet protocol. We'd strongly recommend using the library that we've set up to manage all the pipes, but it is theoretically possible to use standard unix commands or another interface. The libmodal-pipe pipes are actually more of folders that contain a number of pipes so that the data can be distributed to an arbitrary number of clients. To read the data you should echo a plaintext name into the request pipe, after which the server will create a fifo with that name which could then be catted or opened with a read i.e. echo "test" > /run/mpa/vvpx4_sys_status/request && cat /run/mpa/vvpx4_sys_status/test
      W 1 Reply Last reply
      • W Offline
        W Offline
        wouter
        Thanks, this makes a bit more clear.
        I tried running your command, but it returns an error. I tried cat'ing test? and that stalls.
        yocto:~$ echo "test" > /run/mpa/vvpx4_sys_status/request && cat /run/mpa/vvpx4_sys_status/test
        cat: /run/mpa/vvpx4_sys_status/test: No such file or directory
        yocto:~$ ls -alh /run/mpa/vvpx4_sys_status/
        total 4.0K
        drwxr-xr-x.  2 root root 100 Jun  7 04:33 .
        drwxr-xr-x. 12 root root 260 Jan  1  1970 ..
        -rw-r--r--.  1 root root 185 Jan  1  1970 info
        prw-r--r--.  1 root root   0 Jun  7 04:33 request
        prw-r--r--.  1 root root   0 Jun  7 04:33 test?
        yocto:~$ cat /run/mpa/vvpx4_sys_status/test?
        • ? A Former User
          W Offline
          W Offline
          wouter
          wrote on last edited by wouter
          @Alex-Gardner Thank for your reply, could you maybe look at my question I still have?
