  2. VOXL SDK and Software
  3. Build voxl-uvc-server with voxl-cross
mpa
26 Posts 2 Posters 9.3k Views 1 Watching
  • Philemon BennerP Offline
    Philemon Benner
    @Eric-Katzfey
    Hey,
    i am currently trying to integrate voxl-uvc-server dev with voxl-tflite-server. But i am having issues compiling it in voxl-cross. Build Error is shown below:
    voxl-cross:~(dev)$ ./build.sh
    Building for voxl
    BUILDSIZE=32
    BUILDSIZE does not match 64
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/root/build32
    Consolidate compiler generated dependencies of target voxl-uvc-server
    [ 50%] Linking C executable voxl-uvc-server
    /usr/lib/libmodal_json.so: error adding symbols: File in wrong format
    collect2: error: ld returned 1 exit status
    CMakeFiles/voxl-uvc-server.dir/build.make:98: recipe for target 'voxl-uvc-server' failed
    make[2]: *** [voxl-uvc-server] Error 1
    CMakeFiles/Makefile2:82: recipe for target 'CMakeFiles/voxl-uvc-server.dir/all' failed
    make[1]: *** [CMakeFiles/voxl-uvc-server.dir/all] Error 2
    Makefile:135: recipe for target 'all' failed
    make: *** [all] Error 2
    Help would be appreciated.
    • Philemon BennerP Philemon Benner
      @Eric-Katzfey
      Hey,
      Building for voxl
      BUILDSIZE=32
      -- Configuring done
      -- Generating done
      @Philemon-Benner The build instructions are here: https://gitlab.com/voxl-public/modal-pipe-architecture/voxl-uvc-server/-/tree/dev. In short, you need to build in the emulator, not with voxl-cross.
      Philemon BennerP 1 Reply Last reply
        Philemon Benner
        @Eric-Katzfey yeah i know, but is it possible to do it in voxl-cross or what would i have to change to make it work with voxl-cross?
          @Philemon-Benner You would need to change it. Is there a reason that you prefer building in voxl-cross?
            Philemon Benner
            @Eric-Katzfey Not really it's used in the tutorial for building voxl-tflite-server from source. I basically want to replace libmodal pipe input with libuvc in the tflite-server, using parts of the voxl-uvc-server. Is it possible to build tflite-server in the voxl-emulator without changing anything?
              @Philemon-Benner That's not something we have tried. But I can't imagine that it would be too difficult to get voxl-tflite-server building in voxl-emulator. Any reason that you can't leave voxl-uvc-server and voxl-tflite-server as separate processes communicating via MPA?
                Philemon Benner
                @Eric-Katzfey yeah i want to have in/output in one executable(tflite-server). So that i have better control and exception handling for these. I will try and integrate tflite-server in voxl-emulator.
                  Philemon Benner
                  @Eric-Katzfey so tried compiling tflite-server in voxl-emulator, but when building it complains about everything. So i tried just integrating libuvc in tflite-server in voxl-cross. Installation works fine. But when building it's complaining about libuvc being incompatible. Is it because i'm trying to build it with arm64 instead of the way voxl-emulator does in arm32 ?(mentioned in the docs https://gitlab.com/voxl-public/utilities/voxl-docker) What would i have to change to build in voxl-cross?
                  Package Installation:
                  voxl-cross:~$ ./install_build_deps.sh dev
                  using dev IPK repo
                  Downloading http://voxl-packages.modalai.com/dev/Packages.gz.
                  Updated source 'dev'.
                  installing:
                  libmodal-pipe libmodal-json voxl-opencv voxl-tflite libuvc
                  Installing libmodal-pipe (2.1.5) on root.
                  Downloading http://voxl-packages.modalai.com/dev/libmodal-pipe_2.1.5_202203110042.ipk.
                  Configuring libmodal-pipe.
                  Installing libmodal-json (0.4.0) on root.
                  Downloading http://voxl-packages.modalai.com/dev/libmodal-json_0.4.0_202203110044.ipk.
                  Configuring libmodal-json.
                  Installing voxl-opencv (4.5.5) on root.
                  Downloading http://voxl-packages.modalai.com/dev/voxl-opencv_4.5.5_202202082046.ipk.
                  Configuring voxl-opencv.
                  Installing voxl-tflite (2.2.3) on root.
                  Downloading http://voxl-packages.modalai.com/dev/voxl-tflite_2.2.3-1_202201270503.ipk.
                  Configuring voxl-tflite.
                  Done installing voxl-tflite
                  Installing libuvc (1.0.3) on root.
                  Downloading http://voxl-packages.modalai.com/dev/libuvc_1.0.3_202201232120.ipk.
                  Configuring libuvc.
                  /home/root
                  Done installing libuvc
                  Done installing dependencies
                  Build Output:
                  voxl-cross:~$ ./build.sh 820
                  -- The C compiler identification is GNU 4.9.3
                  -- The CXX compiler identification is GNU 4.9.3
                  -- Check for working C compiler: /usr/bin/aarch64-linux-gnu-gcc-4.9 - skipped
                  -- Check for working CXX compiler: /usr/bin/aarch64-linux-gnu-g++-4.9 - skipped
                  -- Configuring done
                  -- Generating done
                  -- Build files have been written to: /home/root/build64
                  [ 50%] Building CXX object src/CMakeFiles/voxl-tflite-server.dir/main.cpp.o
                  [ 50%] Building CXX object src/CMakeFiles/voxl-tflite-server.dir/inference_helper.cpp.o
                  [ 75%] Building C object src/CMakeFiles/voxl-tflite-server.dir/resize.c.o
                  In file included from /usr/aarch64-linux-gnu-2.23/include/features.h:367:0,
                                   from /usr/aarch64-linux-gnu-2.23/include/stdio.h:27,
                                   from /home/root/src/resize.c:1:
                  /usr/aarch64-linux-gnu-2.23/include/bits/stdlib.h:64:8: warning: no previous declaration for 'ptsname_r' [-Wmissing-declarations]
                   __NTH (ptsname_r (int __fd, char *__buf, size_t __buflen))
                  /usr/aarch64-linux-gnu-2.23/include/sys/cdefs.h:57:59: note: in definition of macro '__NTH'
                   #  define __NTH(fct) __attribute__ ((__nothrow__ __LEAF)) fct
                  [100%] Linking CXX executable voxl-tflite-server
                  /usr/lib/gcc-cross/aarch64-linux-gnu/4.9/../../../../aarch64-linux-gnu/bin/ld: skipping incompatible /usr/lib/../lib/libuvc.so when searching for -luvc
                  /usr/lib/gcc-cross/aarch64-linux-gnu/4.9/../../../../aarch64-linux-gnu/bin/ld: skipping incompatible /usr/lib/../lib/libuvc.a when searching for -luvc
                  /usr/lib/gcc-cross/aarch64-linux-gnu/4.9/../../../../aarch64-linux-gnu/bin/ld: skipping incompatible //usr/lib/libuvc.so when searching for -luvc
                  /usr/lib/gcc-cross/aarch64-linux-gnu/4.9/../../../../aarch64-linux-gnu/bin/ld: skipping incompatible //usr/lib/libuvc.a when searching for -luvc
                  /usr/lib/gcc-cross/aarch64-linux-gnu/4.9/../../../../aarch64-linux-gnu/bin/ld: cannot find -luvc
                  src/CMakeFiles/voxl-tflite-server.dir/build.make:128: recipe for target 'src/voxl-tflite-server' failed
                  make[2]: *** [src/voxl-tflite-server] Error 1
                  CMakeFiles/Makefile2:97: recipe for target 'src/CMakeFiles/voxl-tflite-server.dir/all' failed
                  make[1]: *** [src/CMakeFiles/voxl-tflite-server.dir/all] Error 2
                    using dev IPK repo
                    installing:
                    Configuring libuvc.
                    /home/root
                    Build Output:
                    -- Configuring done
                    -- Generating done
                    @Philemon-Benner You can build a 64 bit version of libuvc with the dev branch on our libuvc project: https://gitlab.com/voxl-public/third-party/libuvc/-/tree/dev. Use the instructions to build for qrb5165 and it will produce 64 bit versions.
                      Philemon Benner
                      @Eric-Katzfey Do i have to use the qrb-emulator for that or can i do it in voxl-emulator?
                        Philemon Benner
                        @Eric-Katzfey tried that getting the following errors:
                        /usr/lib/gcc-cross/aarch64-linux-gnu/4.9/../../../../aarch64-linux-gnu/bin/ld: warning: libusb-1.0.so.0, needed by /usr/lib/../lib/libuvc.so, not found (try using -rpath or -rpath-link)
                        /usr/lib/gcc-cross/aarch64-linux-gnu/4.9/../../../../aarch64-linux-gnu/bin/ld: warning: libjpeg.so.8, needed by /usr/lib/../lib/libuvc.so, not found (try using -rpath or -rpath-link)
                        when trying to build in tflite-server. I Built libuvc in qr-emulator. Installed the deb file in tflite-server without errors.
                          @Philemon-Benner In voxl-cross?
                            Philemon Benner
                            yeah i think i need to install libusb and libjpeg but wich exact verisions?
                              @Philemon-Benner Now you are starting to see the problem with voxl-cross. It is a much faster way to compile code but for projects that have more complex dependencies it can be a real pain to get them setup. That is why some projects use voxl-emulator. It's much easier to setup dependencies there.
                                Philemon Benner
                                @Eric-Katzfey yeah i see
                                  Philemon Benner
                                  Ok so i finally got it working if someone ever needs it, with installing:
                                  sudo apt-get update
                                  sudo apt-get install libusb-1.0-0:arm64
                                  sudo apt-get install libjpeg-turbo8:arm64
                                  For other third part libraries add the :arm64 architecture when building with 820, because in voxl-cross it will install amd64 by default. Still wondering what 820 exactly is🤔
                                  Thanks @Eric-Katzfey for the suggestion on the 64-Bit deb package.
                                    sudo apt-get update
                                    @Philemon-Benner 820 refers to the Qualcomm Snapdragon 820 SoC that is the heart of the Voxl product. https://www.qualcomm.com/products/snapdragon-820-mobile-platform
                                      Philemon Benner
                                      wrote on last edited by Philemon Benner
                                      #18
                                      @Eric-Katzfey Ok i ran into the next problem when trying to run tflite-server.
                                      voxl:~/tflite-server(master)$ voxl-tflite-server -t -d
                                      voxl-tflite-server: error while loading shared libraries: libuvc.so.0: cannot open shared object file: No such file or directory
                                      Tried to install the 64-Bit BInary file but it's throwing the following error:
                                      voxl:~/tflite-server(master)$ opkg install libuvc_1.0.3.deb
                                      Collected errors:
                                       * pkg_extract_control_file_to_stream: Failed to extract control.tar.gz from package 'libuvc_1.0.3.deb'.
                                       * pkg_init_from_file: Failed to extract control file from libuvc_1.0.3.deb.
                                      So i tried using this from ur code:
                                      voxl:~/tflite-server(master)$ dpkg -i --force-downgrade --force-depends /data/libuvc_1.0.3.deb
                                      -bash: dpkg: command not found
                                      Normal installation from modalai dev branch still throws the same error after installation:
                                      opkg install libuvc
                                      Any suggestions?
                                        Collected errors:
                                        opkg install libuvc
                                        Any suggestions?
                                        @Philemon-Benner You can only install a Debian package with dpkg, which we have on our qrb5165 based platform, but not on our 820 based Voxl. That only has opkg and you need ipk packages, not debian packages.
                                        Philemon BennerP 2 Replies Last reply
                                          Philemon Benner
                                          #20
