  2. Software Development
  3. Modal Pipe Architecture (MPA)
  4. running voxl-tflite-server dev
Scheduled Pinned Locked Moved Modal Pipe Architecture (MPA)
3 Posts 2 Posters 1.2k Views
  • Harel YadidH Offline
    Harel Yadid
    hi,
    I have been trying to run the new voxl-tflite-server dev branch but when I ran the ./deploy_to_voxl_sh, I received the error: Screenshot from 2022-03-07 13-38-47.png
    Is it possible to solve it?
    just in case it matters: I built using ./install_build_deps.sh dev and ./build.sh 820
      Hey @Harel-Yadid,
      In order to properly install packages from the dev branches/repo, you must point opkg on VOXL to the dev repo as well so the same packages are available. You can do this by running
       voxl:/$ voxl-configure-opkg dev
        Harel Yadid
        Thanks for the answer!
        it worked great after the upgrades.
        what I am trying to do now is to run the deeplab dnn, but I am having some issues.
        I tried to run the 865 build but i couldn't run any tflite dnn.
        then I tried to run the 820 build which worked perfectly and than added manually the deeplab dnn.
        eventually i received the error:
        do you have any suggestions?
