  2. VOXL SDK and Software
  3. SDK package versions and voxl-cross container versions
voxl-sdk
3 Posts 2 Posters 899 Views
  • I Offline
    I Offline
    ianjsherman
    I have a Docker-based build pipeline that:
    • Inside the voxl-cross:2.7 container, installs ModalAI packages
    DEPS="
    libmodal-pipe
    PLATFORM=qrb5165
    SECTION=sdk-1.4
    # Add to /etc/apt/sources.list.d
    DPKG_FILE="/etc/apt/sources.list.d/modalai.list"
    LINE="deb [trusted=yes] http://voxl-packages.modalai.com/ ./dists/$PLATFORM/$SECTION/binary-arm64/"
    sudo echo "${LINE}" > ${DPKG_FILE}
    ## Update package index
    sudo apt-get update -o Dir::Etc::sourcelist="sources.list.d/modalai.list" -o Dir::Etc::sourceparts="-" -o APT::Get::List-Cleanup="0"
    ## Install dependencies
    sudo apt install -y $DEPS
    • Inside the same container, builds my application
    Over the weekend my build broke due to an incompatibility between the newly released libmodal-pipe_2.13.1_arm64.deb (released to the sdk-1.4 apt repository) and the voxl-cross:2.7 build container.
    My workaround has been to pin the version of the libmodalpipe apt package I install: libmodal-pipe=2.10.6.
    How should I think about versioning guarantees between the SDK version and the voxl-cross container version? Should I expect packages in a given SDK version to continue to build in a given voxl-cross container version? Or is your recommendation to live at the bleeding edge of the voxl-cross container version?
    James StrawsonJ 1 Reply Last reply
    • I ianjsherman
      DEPS="
      libmodal-pipe
      PLATFORM=qrb5165
      SECTION=sdk-1.4
      James StrawsonJ Offline
      James Strawson
      @ianjsherman While we are slowly migrating packages to build in a new build environment, the API for libmodal_pipe should not have changed and installing the new binary package in voxl-cross 2.7 into order to build and link against should not have broken. Do you mind sharing what exactly broke in your build as there might have been something that I missed.
        James Strawson
        @James-Strawson
        hmmm, by any chance are you failing to link against symbols from libgmb.so? That is a new library dependency of libmodal_pipe. Most of our packages use the following linker flags to avoid recursive linking, I think this would be a better solution than specifying the libmodal_pipe version in install_build_deps.sh
        set(CMAKE_C_FLAGS "-Wl,--unresolved-symbols=ignore-in-shared-libs ${CMAKE_C_FLAGS}")
        set(CMAKE_CXX_FLAGS "-Wl,--unresolved-symbols=ignore-in-shared-libs ${CMAKE_CXX_FLAGS}")
