    Stereo interface received non-stereo frame, exiting stereo
    • C
      cch
      Hi, I'm using voxl2 with:
      system-image: 1.5.5-M0054-14.1a-perf
      kernel: #1 SMP PREEMPT Fri Mar 24 00:48:55 UTC 2023 4.19.125
      hw version: M0054
      voxl-suite: 0.9.5
      I'm facing the same problem with Re: [Stereo interface received non-stereo frame](exiting stereo), where the stereo images and the disparity image are shown on voxl-portal. And every thing works fine after launching 'voxl-mpa-to-ros':
      voxl2:~/.ros/log/1257f2ae-9f10-11ee-bc6c-00c0cab5947a$ roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
      ... logging to /home/root/.ros/log/19d7c026-9f16-11ee-86c1-00c0cab5947a/roslaunch-m0054-32592.log
      Checking log directory for disk usage. This may take a while.
      Press Ctrl-C to interrupt
      started roslaunch server http://m0054:38073/
      SUMMARY
      PARAMETERS
       * /rosdistro: melodic
       * /rosversion: 1.14.13
      NODES
          voxl_mpa_to_ros_node (voxl_mpa_to_ros/voxl_mpa_to_ros_node)
      auto-starting new master
      process[master]: started with pid [32606]
      ROS_MASTER_URI=http://localhost:11311
      setting /run_id to 19d7c026-9f16-11ee-86c1-00c0cab5947a
      process[rosout-1]: started with pid [32617]
      process[voxl_mpa_to_ros_node-2]: started with pid [32620]
      MPA to ROS app is now running
      Found new interface: stereo
      Found new interface: stereo_disparity
      Found new interface: stereo_disparity_scaled
      Found new interface: stereo_pc
      I also checked the topic info in another terminal:
      voxl2:/$ rostopic list
      /rosout
      /rosout_agg
      /stereo/left
      /stereo/right
      /stereo_disparity/left
      /stereo_disparity/right
      /stereo_disparity_scaled/left
      /stereo_disparity_scaled/right
      /stereo_pc
      voxl2:/$ rostopic info /stereo/left
      Type: sensor_msgs/Image
      Publishers:
       * /voxl_mpa_to_ros_node (http://m0054:41893/)
      Subscribers: None
      voxl2:/$ rostopic info /stereo_disparity/left
      Publishers:
      Subscribers: None
      Everything looks great but a strange thing happens that: 1. If I use 'rostopic echo /stereo/left', the /stereo/left topic is subscribed and shows in terminal 2.If I use 'rostopic echo /stereo_disparity/left', the /stereo_disparity/left topic won't be subscribed and the 'voxl-mpa-to-ros' will crash after announcing that 'Stereo interface received non-stereo frame, exiting stereo':
      ... logging to /home/root/.ros/log/fafd37b2-9f15-11ee-bc54-00c0cab5947a/roslaunch-m0054-31666.log
      started roslaunch server http://m0054:36119/
      SUMMARY
      PARAMETERS
      NODES
      process[master]: started with pid [31680]
      setting /run_id to fafd37b2-9f15-11ee-bc54-00c0cab5947a
      process[rosout-1]: started with pid [31691]
      process[voxl_mpa_to_ros_node-2]: started with pid [31694]
      Interface stereo_disparity now publishing
      [voxl_mpa_to_ros_node-2] process has died [pid 31694, exit code -11, cmd /opt/ros/melodic/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node __name:=voxl_mpa_to_ros_node __log:=/home/root/.ros/log/fafd37b2-9f15-11ee-bc54-00c0cab5947a/voxl_mpa_to_ros_node-2.log].
      log file: /home/root/.ros/log/fafd37b2-9f15-11ee-bc54-00c0cab5947a/voxl_mpa_to_ros_node-2*.log
      ^C[rosout-1] killing on exit
      [master] killing on exit
      shutting down processing monitor...
      ... shutting down processing monitor complete
      done
      I tried several times after rebooting voxl2. And I also tried to flash sdk 0.9.5 or turn off the voxl-portal. But I get the same result every time. It's hard to explain why this happens as the /stereo/left has the same type compared with /stereo_disparity/left, however, the /stereo/left can be subscribed but the /stereo_disparity/left can't.
      Any clue on what is going on?
      C 1 Reply Last reply Reply Quote 0
      • C
        cch @cch
        There is also no 'voxl_mpa_to_ros_node-2*.log' for analyzing:
        voxl2:~/.ros/log$ cd 1257f2ae-9f10-11ee-bc6c-00c0cab5947a/
        voxl2:~/.ros/log/1257f2ae-9f10-11ee-bc6c-00c0cab5947a$ ls
        master.log  roslaunch-m0054-30807.log  rosout-1-stdout.log  rosout.log
        P 1 Reply Last reply Reply Quote 0
        • P
          planch98 @cch
          @cch try to update voxl-mpa-to-ros, they should have fixed it in https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros/-/commit/921db500db1f7109c3f2dde870a2a31ed0c38f2c
          • C
            cch @planch98
            @planch98 Thank you so much! I have solved the problem.
