  3. IMX412 for SDK 1.1.1 Example Request
1 Posts 1 Posters 564 Views 1 Watching
  • J Offline
    JoeC
    Re: IMX412 full resolution support at 12MP not working
    Hi Travis @modaltb , I took your prior advice and am trying to work with an IMX412 on the VOXL2 flight deck running SDK 1.1.1. I've played around with a couple different physical connections and for software the 'camera-server-config-helper', the 'voxl-configure-cameras' script, and simply modifying the voxl-camera-server.conf file directly and simply not able to get imagery. Interestingly, I get either a "ERROR: Found zero cameras connected, need at least one." or alternatively, "ERROR: Camera 3 failed to find supported stream config: 1920x1080 ERROR: Failed to start camera: hires" I also can't get the "--imx412" arg to work with the voxl-configure-cameras script so I'm guessing that's deprecated?
    If it's not too much trouble, would you kindly post an example that definitely works? Maybe using camera configuration 8 ("hires only") or 11 ("sentinel")?
    -Joe
