  2. VOXL SDK and Software
  3. RMW_IMPLEMENTATION not set for ros2
ros
2 Posts 1 Posters 1.2k Views
  • Kyuhyong YouK Offline
    Kyuhyong You
    wrote on last edited by Kyuhyong You
    I just upgraded my voxl2 with the latest sdk 1.1.0 and apt installed ros2 relate packages as follows
    sudo apt install voxl-ros2-foxy
    $ sudo apt install voxl-microdds-agent
    $ sudo apt install voxl-mpa-to-ros2
    $ pip3 install netifaces
    $ pip3 install pyyaml
    After source /opt/ros/foxy/setup.bash and tried to run ros2 topic and it returns following error.
    $ ros2 topic list
    Unable to get rmw_implementation_identifier, try specifying the implementation to use via the 'RMW_IMPLEMENTATION' environment variable
    It seems like RMW_IMPLEMENTATION not set in the bash.
    How to set this variable to run on voxl?
    Also tried to run configuration as below
    $ sudo voxl-configure-microdds
    Starting Wizard
    do you want to enable or disable voxl-microdds-agent
    factory-enable will also reset the config file back to default
    1) disable
    2) enable
    #? 2
    enabling  voxl-microdds-agent systemd service
    Created symlink /etc/systemd/system/multi-user.target.wants/voxl-microdds-agent.service → /etc/systemd/system/voxl-microdds-agent.service.
    Done configuring voxl-microdds-agent
    And inspect service returns
    $ voxl-inspect-services
    Scanning services...
     voxl-camera-server       |  Enabled  | Not Running |
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.7%
     voxl-imu-server          |  Enabled  |   Running   |     6.2%
     voxl-mavlink-server      |  Enabled  |   Running   |     3.4%
     voxl-microdds-agent      |  Enabled  |   Running   |    13.5%
     voxl-portal              |  Enabled  |   Running   |     0.1%
     voxl-px4-imu-server      | Disabled  | Not Running |
     voxl-px4                 |  Enabled  |   Running   |    40.2%
     voxl-qvio-server         |  Enabled  |   Running   |     4.2%
     voxl-streamer            |  Enabled  |   Running   |     0.1%
     voxl-vision-hub          |  Enabled  |   Running   |     1.8%
     voxl-wait-for-fs         |  Enabled  |  Completed  |``
    Kyuhyong YouK 1 Reply Last reply
    • Kyuhyong YouK Kyuhyong You
      $ ros2 topic list
      Starting Wizard
      1) disable
      2) enable
      #? 2
      Kyuhyong You
      @Kyuhyong-You
      After reboot this error is magically gone.
      now I can see topics
      after $ ros2 run voxl_mpa_to_ros2 voxl_mpa_to_ros2_node
      then in another terminal on voxl, I see below topics
      $ ros2 topic list
      /fmu/in/obstacle_distance
      /fmu/in/offboard_control_mode
      /fmu/in/onboard_computer_status
      /fmu/in/sensor_optical_flow
      /fmu/in/telemetry_status
      /fmu/in/trajectory_setpoint
      /fmu/in/vehicle_attitude_setpoint
      /fmu/in/vehicle_command
      /fmu/in/vehicle_mocap_odometry
      /fmu/in/vehicle_rates_setpoint
      /fmu/in/vehicle_trajectory_bezier
      /fmu/in/vehicle_trajectory_waypoint
      /fmu/in/vehicle_visual_odometry
      /fmu/out/failsafe_flags
      /fmu/out/position_setpoint_triplet
      /fmu/out/sensor_combined
      /fmu/out/timesync_status
      /fmu/out/vehicle_attitude
      /fmu/out/vehicle_control_mode
      /fmu/out/vehicle_local_position
      /fmu/out/vehicle_odometry
      /fmu/out/vehicle_status
      /parameter_events
      /rosout
