  3. VOXL2 Mini Camera Configuration Instability
1 Posts 1 Posters 494 Views
  • Steve TurnerS Offline
    Steve Turner
    We are trying to get a 3xTracking and 1x Hi-Res configuration working. Based on testing, it seems this might not be a supported configuration.
    • Based on stock bionic Modal kernel and image released
    • Based on interface board m0135
      • The Tracker sensor (ov7251) can only be connected to JU (furthest from Qualcomm chip)
      • The HiRes sensor (Imx214) can only be connected to JL, (Closest to the Qualcomm chip)
      • Connecting the wrong sensor to the JU/JL on Voxl2 mini J6 connector will fail to boot and normally require a fast boot to reimage
        • Connecting to J7 does not boot, but generally recovers without fastboot reimage required.
      • If using the m0135 inteface board, one must be fully populated with both a high res and a tracker sensor
        • If using two, the second board should not populate the HiRes sensor
      • Trying to connect two of the same sensors to the interface board will fail, and depending if J6 is used, a fast boot reimage may be required
    Reviewing m0014 (tracker) shows the cable is 1 lane CSI with most pins not connected. There is no obvious reason for crashing when connecting to the wrong JU/JL.
    Is there something that potentially is causing a hardware fault in this configuration?
    The highest sensor configuration we can get working is that above, 1 HiRes and 2 Trackers.
    Thanks for any help Modal Team!
