  3. Using IMX412 camera with 4K resolution.
2 Posts 2 Posters 712 Views
  • A Offline
    Anubhav
    Hello team,
    I want to use IMX412 camera for snapshots with 4k resolution but unable to do.
    the below command is with voxl-camera-server_1.6.1_arm64.deb
    voxl2:~$ voxl-camera-server
    configuration for 1 cameras:
    cam #0
        sensor type:         imx412
        isEnabled:           1
        camId:               0
        camId2:              -1
        fps:                 30
        en_preview:          0
        pre_width:           2048
        pre_height:          1536
        pre_format:          nv21
        en_small_video:      1
        small_video_width:   1024
        small_video_height:  768
        en_large_video:      1
        large_video_width:   4096
        large_video_height:  2160
        en_snapshot:         1
        snap_width:          4160
        snap_height:         3120
        ae_mode:             isp
        standby_enabled:     0
        decimator:           1
        independent_exposure:0
    Starting Camera: hires
    ERROR:   Camera 0 failed to find supported record config: 4096x2160
    ERROR:   Failed to start camera: hires, exiting
    and in this same camera server version when I have downgraded the resolution, camera started working but when I trigger voxl-portal to see the Hires image output camera is failing. below is the output.
    cam #0
        sensor type:         imx412
        isEnabled:           1
        camId:               0
        camId2:              -1
        fps:                 30
        en_preview:          0
        pre_width:           2048
        pre_height:          1536
        pre_format:          nv21
        en_small_video:      1
        small_video_width:   2048
        small_video_height:  1536
        en_large_video:      1
        large_video_width:   2048
        large_video_height:  1536
        en_snapshot:         1
        snap_width:          2048
        snap_height:         1536
        ae_mode:             isp
        standby_enabled:     0
        decimator:           1
    WARNING: Port Def 0:
    	Count Min: 8
    	Count Actual: 16
    	Buffers Contiguous: Yes
    	Buffer Alignment: 0
    WARNING: Port Def 1:
    	Count Min: 4
    	Count Actual: 16
    	Buffers Contiguous: No
    	Buffer Alignment: 0
    	Count Min: 8
    	Count Actual: 16
    	Buffer Alignment: 0
    	Count Min: 4
    	Count Actual: 16
    	Buffer Alignment: 0
    Segmentation fault:
    Fault thread: cam0-request(tid: 6949)
    Fault address: (nil)
    Unknown reason.
    Segmentation fault
    Thanks.
    Arjun Jain 0A 1 Reply Last reply
    • A Anubhav
      Hello team,
      cam #0
          sensor type:         imx412
          isEnabled:           1
          camId:               0
          camId2:              -1
          fps:                 30
          en_preview:          0
          pre_width:           2048
          pre_height:          1536
          pre_format:          nv21
          en_small_video:      1
          en_large_video:      1
          en_snapshot:         1
          snap_width:          4160
          snap_height:         3120
          ae_mode:             isp
          standby_enabled:     0
          decimator:           1
      cam #0
          sensor type:         imx412
          isEnabled:           1
          camId:               0
          camId2:              -1
          fps:                 30
          en_preview:          0
          pre_width:           2048
          pre_height:          1536
          pre_format:          nv21
          en_small_video:      1
          en_large_video:      1
          en_snapshot:         1
          snap_width:          2048
          snap_height:         1536
          ae_mode:             isp
          standby_enabled:     0
          decimator:           1
      	Count Min: 8
      	Count Actual: 16
      	Buffer Alignment: 0
      	Count Min: 4
      	Count Actual: 16
      	Buffer Alignment: 0
      	Count Min: 8
      	Count Actual: 16
      	Buffer Alignment: 0
      	Count Min: 4
      	Count Actual: 16
      	Buffer Alignment: 0
      Segmentation fault:
      Unknown reason.
      Segmentation fault
      Thanks.
      Arjun Jain 0A Offline
      Arjun Jain 0
      @Chad-Sweet - I have the same issue. How to enable the 4K resolution for IMX412 that we bought for $349 USD from you?
