  2. VOXL Dev Drones
  4. issue with voxl streamer not reconnecting
5 Posts 2 Posters 1.1k Views
  • S Offline
    S Offline
    stevedan
    This post is related to this two -> https://forum.modalai.com/topic/827/sdk-version-1-1-3-issues-video-stream-breaks-reboot-issue?_=1670922006202 and https://forum.modalai.com/topic/770/streaming-stopping-after-running-once. It seems that whenever connection with the streamer is lost, it does not reconnect automatically. It requires I manually restart the voxl-streamer service and the cycle continues. There seem to be no fix currently.
    You can see the systemctl logs of the voxl streamer below.
    Dec 13 08:55:32 robot133 systemd[1]: Starting voxl-streamer...
    Dec 13 08:55:37 robot133 systemd[1]: Started voxl-streamer.
    Dec 13 08:55:37 robot133 voxl-streamer[7421]: Camera server Connected
    Dec 13 08:55:37 robot133 voxl-streamer[7421]: Stream available at rtsp://127.0.0.1:8900/live
    Dec 13 08:55:37 robot133 voxl-streamer[7421]: A new client has connected to the RTSP server
    Dec 13 08:55:37 robot133 voxl-streamer[7421]: gbm_create_device(156): Info: backend name is: msm_drm
    Dec 13 08:55:38 robot133 voxl-streamer[7421]: gbm_create_device(156): Info: backend name is: msm_drm
    Dec 13 08:56:26 robot133 voxl-streamer[7421]: A new client has connected to the RTSP server
    Dec 13 08:56:26 robot133 voxl-streamer[7421]: gbm_create_device(156): Info: backend name is: msm_drm
    Dec 13 08:56:29 robot133 voxl-streamer[7421]: A new client has connected to the RTSP server
    Dec 13 08:56:29 robot133 voxl-streamer[7421]: An existing client has disconnected from the RTSP server
    Dec 13 08:56:29 robot133 voxl-streamer[7421]: instance with invalid (NULL) class pointer
    Dec 13 08:56:29 robot133 voxl-streamer[7421]: g_signal_emit_by_name: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
    Dec 13 08:56:29 robot133 voxl-streamer[7421]: gbm_create_device(156): Info: backend name is: msm_drm
    Dec 13 08:56:33 robot133 voxl-streamer[7421]: A new client has connected to the RTSP server
    Dec 13 08:56:33 robot133 voxl-streamer[7421]: An existing client has disconnected from the RTSP server
    Dec 13 08:56:33 robot133 voxl-streamer[7421]: instance with invalid (NULL) class pointer
    Dec 13 08:56:33 robot133 voxl-streamer[7421]: g_signal_emit_by_name: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
    Dec 13 08:56:33 robot133 voxl-streamer[7421]: gbm_create_device(156): Info: backend name is: msm_drm
    Dec 13 08:56:37 robot133 voxl-streamer[7421]: An existing client has disconnected from the RTSP server
    Dec 13 08:56:37 robot133 voxl-streamer[7421]: A new client has connected to the RTSP server
    Dec 13 08:56:37 robot133 voxl-streamer[7421]: gbm_create_device(156): Info: backend name is: msm_drm
    Dec 13 08:56:41 robot133 voxl-streamer[7421]: An existing client has disconnected from the RTSP server
    Dec 13 08:56:41 robot133 voxl-streamer[7421]: A new client has connected to the RTSP server
    Dec 13 08:56:41 robot133 voxl-streamer[7421]: instance with invalid (NULL) class pointer
    Dec 13 08:56:41 robot133 voxl-streamer[7421]: g_signal_emit_by_name: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
    Dec 13 08:56:41 robot133 voxl-streamer[7421]: gbm_create_device(156): Info: backend name is: msm_drm
    Dec 13 08:56:45 robot133 voxl-streamer[7421]: An existing client has disconnected from the RTSP server
    Dec 13 08:56:45 robot133 voxl-streamer[7421]: A new client has connected to the RTSP server
    Dec 13 08:56:45 robot133 voxl-streamer[7421]: instance with invalid (NULL) class pointer
    Dec 13 08:56:45 robot133 voxl-streamer[7421]: g_signal_emit_by_name: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
    Dec 13 08:56:45 robot133 voxl-streamer[7421]: gbm_create_device(156): Info: backend name is: msm_drm
    Dec 13 08:56:49 robot133 voxl-streamer[7421]: An existing client has disconnected from the RTSP server
    Dec 13 08:56:49 robot133 voxl-streamer[7421]: A new client has connected to the RTSP server
    Dec 13 08:56:49 robot133 voxl-streamer[7421]: instance with invalid (NULL) class pointer
    Dec 13 08:56:49 robot133 voxl-streamer[7421]: g_signal_emit_by_name: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
    Dec 13 08:56:49 robot133 voxl-streamer[7421]: gbm_create_device(156): Info: backend name is: msm_drm
    Dec 13 08:56:53 robot133 voxl-streamer[7421]: An existing client has disconnected from the RTSP server
    Dec 13 08:56:53 robot133 voxl-streamer[7421]: A new client has connected to the RTSP server
    Dec 13 08:56:53 robot133 voxl-streamer[7421]: instance with invalid (NULL) class pointer
    Dec 13 08:56:53 robot133 voxl-streamer[7421]: g_signal_emit_by_name: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
    Dec 13 08:56:53 robot133 voxl-streamer[7421]: gbm_create_device(156): Info: backend name is: msm_drm
    Dec 13 08:56:57 robot133 voxl-streamer[7421]: An existing client has disconnected from the RTSP server
    Dec 13 08:56:57 robot133 voxl-streamer[7421]: A new client has connected to the RTSP server
    Dec 13 08:56:57 robot133 voxl-streamer[7421]: instance with invalid (NULL) class pointer
    Dec 13 08:56:57 robot133 voxl-streamer[7421]: g_signal_emit_by_name: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
    Dec 13 08:56:57 robot133 voxl-streamer[7421]: gbm_create_device(156): Info: backend name is: msm_drm
    Dec 13 08:57:01 robot133 voxl-streamer[7421]: An existing client has disconnected from the RTSP server
    Dec 13 08:57:01 robot133 voxl-streamer[7421]: A new client has connected to the RTSP server
    Dec 13 08:57:01 robot133 voxl-streamer[7421]: instance with invalid (NULL) class pointer
    Dec 13 08:57:01 robot133 voxl-streamer[7421]: g_signal_emit_by_name: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
    Dec 13 08:57:01 robot133 voxl-streamer[7421]: gbm_create_device(156): Info: backend name is: msm_drm
    Dec 13 08:57:05 robot133 voxl-streamer[7421]: A new client has connected to the RTSP server
    Dec 13 08:57:05 robot133 voxl-streamer[7421]: An existing client has disconnected from the RTSP server
    Dec 13 08:57:05 robot133 voxl-streamer[7421]: instance with invalid (NULL) class pointer
    Dec 13 08:57:05 robot133 voxl-streamer[7421]: g_signal_emit_by_name: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
    Dec 13 08:57:05 robot133 voxl-streamer[7421]: gbm_create_device(156): Info: backend name is: msm_drm
    Dec 13 08:57:09 robot133 voxl-streamer[7421]: An existing client has disconnected from the RTSP server
    Dec 13 08:57:09 robot133 voxl-streamer[7421]: A new client has connected to the RTSP server
    Dec 13 08:57:09 robot133 voxl-streamer[7421]: instance with invalid (NULL) class pointer
    Dec 13 08:57:09 robot133 voxl-streamer[7421]: g_signal_emit_by_name: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
    Dec 13 08:57:09 robot133 voxl-streamer[7421]: gbm_create_device(156): Info: backend name is: msm_drm
    Dec 13 08:57:13 robot133 voxl-streamer[7421]: An existing client has disconnected from the RTSP server
    Dec 13 08:57:13 robot133 voxl-streamer[7421]: ERROR:   New frame rejected
    Dec 13 08:57:13 robot133 voxl-streamer[7421]: A new client has connected to the RTSP server
    Dec 13 08:57:13 robot133 voxl-streamer[7421]: instance with invalid (NULL) class pointer
    Dec 13 08:57:13 robot133 voxl-streamer[7421]: g_signal_emit_by_name: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
    Dec 13 08:57:13 robot133 voxl-streamer[7421]: gbm_create_device(156): Info: backend name is: msm_drm
    Dec 13 08:57:17 robot133 voxl-streamer[7421]: A new client has connected to the RTSP server
    Dec 13 08:57:17 robot133 voxl-streamer[7421]: ERROR:   New frame rejected
    Dec 13 08:57:17 robot133 voxl-streamer[7421]: An existing client has disconnected from the RTSP server
    Dec 13 08:57:17 robot133 voxl-streamer[7421]: gbm_create_device(156): Info: backend name is: msm_drm
    Dec 13 08:57:21 robot133 voxl-streamer[7421]: ERROR:   New frame rejected
    Dec 13 08:57:21 robot133 voxl-streamer[7421]: A new client has connected to the RTSP server
    Dec 13 08:57:21 robot133 voxl-streamer[7421]: An existing client has disconnected from the RTSP server
    Dec 13 08:57:21 robot133 voxl-streamer[7421]: instance with invalid (NULL) class pointer
    Dec 13 08:57:21 robot133 voxl-streamer[7421]: g_signal_emit_by_name: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
    • U Offline
      U Offline
      umlr
      wrote on last edited by umlr
      It would be nice to have at least the service failing when this happens, so we can detect the issue and restart the service.
      • S Offline
        S Offline
        stevedan
        • S Offline
          S Offline
          stevedan
          @Chad-Sweet we found a solution for this. We had to make. A more detailled description of the issue can be found here->https://forum.modalai.com/topic/1647/voxl-streamer-does-not-handle-teardown-request-signal-correctly/2. We can share this patch if necessary.
          • S Offline
            S Offline
            stevedan
            Discussion moved to https://forum.modalai.com/topic/1647/voxl-streamer-does-not-handle-teardown-request-signal-correctly/4
