  3. Trouble streaming from OV7251A36 camera
image-sensor
2 Posts 2 Posters 795 Views
  • Henry CappelH Offline
    Henry Cappel
    I'm trying to stream a camera image from my OV7251A36 camera to QGC. It is connected into port J4 and i ran voxl-configure-camera to option 2. However, when I run voxl-streamer it can't seem to start the streaming service. The terminal stops at: Using configuration file /etc/modalai/voxl-streamer.conf. Is there a step I'm missing?
      I believe that voxl-streamer will attempt to stream the hires camera by defualt, if you'd like to stream a different camera, you can change this by modifying /etc/modalai/voxl-streamer.conf and change which configuration is used (or through the command line at runtime)
