  3. Why does voxl-inspect-pose -f fail when voxl-vision-px4 -b command is executed ?
2 Posts 2 Posters 659 Views
  • A Offline
    ahmed-mustahid
    The following is my voxl version:
    voxl:~$ voxl-version
    system-image: 3.8.0
    kernel:       #1 SMP PREEMPT Tue Apr 26 18:08:39 UTC 2022 3.18.71-perf
    hw version:   VOXL
    voxl-suite:   0.8.1
    0.7.0
    voxl related packages in opkg are:
    voxl:~$ opkg list-installed | grep voxl
    libvoxl-cutils - 0.1.1
    voxl-camera-calibration - 0.1.5
    voxl-ceres-solver - 1.14.0-7
    voxl-cpu-monitor - 0.2.6
    voxl-docker-support - 1.2.4
    voxl-gphoto2-server - 0.0.10
    voxl-jpeg-turbo - 2.1.3-4
    voxl-libgphoto2 - 0.0.4
    voxl-libuvc - 1.0.6
    voxl-logger - 0.1.2
    voxl-mapper - 0.0.7
    voxl-mavlink - 0.0.7
    voxl-mavlink-server - 0.1.1
    voxl-modem - 0.15.1
    voxl-mongoose - 7.6.0
    voxl-mpa-to-ros - 0.3.2
    voxl-mpa-tools - 0.6.3
    voxl-nlopt - 2.5.0-4
    voxl-opencv - 4.5.5-1
    voxl-portal - 0.2.8
    voxl-qvio-server - 0.4.6
    voxl-streamer - 0.3.1
    voxl-suite - 0.7.0
    voxl-tag-detector - 0.0.4
    voxl-tflite-server - 0.2.3
    voxl-utils - 1.1.1
    voxl-uvc-server - 0.1.1
    voxl-vision-px4 - 1.0.5
    voxl-voxblox - 1.0.4
    voxl-vpn - 0.0.6
    Initially I can view voxl-inspect-pose -f without any issue:
    voxl:~$ voxl-inspect-pose -f
    timestamp(ms)|     Position (m)     | Roll Pitch Yaw (deg) |    Velocity (m/s)    | angular rate (deg/s) |
          228543 |  -0.04  -0.03  -0.01 |   -2.2   15.6   -0.5 |  -0.00   0.00  -0.00 |  -0.13  -0.22  -0.04 |^C
    received SIGINT Ctrl-C
    But after I execute voxl-vision-px4 -b, I get the following output:
    voxl:~$ voxl-vision-px4 -b
    detected platform APQ8096
    loading our own config file
    config file version:        1
    qgc_ip:                     192.168.8.60
    en_secondary_qgc:           0
    secondary_qgc_ip:           192.168.1.214
    qgc_udp_port_number:        14550
    udp_mtu:                    512
    en_localhost_mavlink_udp    1
    localhost_udp_port_number:  14551
    en_vio:                     1
    en_voa:                     1
    en_send_vio_to_qgc:         0
    en_send_voa_to_qgc:         0
    voa_upper_bound_m:          -0.150000
    voa_lower_bound_m:          0.150000
    en_set_clock_from_gps:      1
    en_force_onboard_mav1_mode: 1
    en_reset_px4_on_error:      1
    qvio_auto_reset_quality:    0.000500
    horizon_cal_tolerance:      0.300000
    offboard_mode:              trajectory
    follow_tag_id:              0
    figure_eight_move_home:     1
    en_tag_fixed_frame:         0
    fixed_frame_filter_len:     5
    loading extrinsics config file
    exising instance of voxl-vision-px4 found, attempting to stop it
    starting geometry module
    starting px4 monitor
    starting px4 mavlink
    starting udp mavlink
    Adding manual QGC IP address to udp connection list: 192.168.8.60
    Added new UDP connection to 192.168.8.60
    starting px4 shell
    starting fixed pose input
    starting vio manager
    starting tag manager
    starting voa manager
    starting offboard trajectory
    starting control input pipe
    Connected to voxl-mavlink-server
    Detected PX4 Mavlink SYSID 1
    uart send msgid: 111 sysid:  1 compid:197
    Connected to voxl-qvio-server
    updating to use imu: imu1
    done updating transforms to use imu: imu1
    ERROR validating VIO data received through pipe: read partial packet
    read 156 bytes, but it should be a multiple of 324
    uart send msgid: 330 sysid:  1 compid:197
    uart send msgid:  84 sysid:  1 compid:197
    Connected to TOF
    ^C
    Starting shutdown sequence
    stopping control input
    stopping offboard trajectory
    exiting offboard trajectory thread
    stopping horizon_cal
    stopping voa manager
    exiting VOA thread
    stopping tag manager
    stopping vio manager
    stopping fixed pose in module
    stopping px4 shell module
    Stopping udp mavlink module
    exiting QGC udp listener thread
    exiting localhost udp listener thread
    udp_mavlink stopped
    Stopping uart mavlink module
    waiting for px4 mavlink timer thread to join
    Stopping px4 monitor
    closing remaining client pipes
    closing remaining server pipes
    Removing PID file
    exiting
    The error being:
    and voxl-inspect-pose -f shows nothing:
    waiting for server at /run/mpa/vvpx4_body_wrt_fixed/
    Why is it happening?
      The partial packet read error usually occurs when there is a version mismatch between packages (i.e. the size of the packet has been updated and one package has the new size but another doesn't). If you update all of your packages together this issue should go away.
