    MPA to ROS tflite_data
    • E
      Eli Pollack
      I am trying to look at the messages coming from /tfite_data, however when using rostopic echo it throws the following error:
      "cannot load message class for [voxl_mpa_to_ros/AiDetection]. Are your messages built?".
      How can I view the messages?
      Thanks.
      • A
        aashry @Eli Pollack
        Hello @Eli-Pollack!
        Have you been able to figure it out? I'm running into the same problem now and I found your question.
