  3. No detections when running custom YOLOv8 model on voxl-tflite-server
voxl-2
17 Posts 3 Posters 2.6k Views
  • Zachary Lowell 0Z Offline
    Zachary Lowell 0
    https://gitlab.com/voxl-public/voxl-sdk/services/voxl-tflite-server/-/blob/master/include/tensor_data.h
    These are all the potential data types that voxl-tflite-server is expecting.
    S 1 Reply Last reply
      S Offline
      S Offline
      svempati
      wrote on last edited by svempati
      I see, so my model is not supported by the voxl-tflite-server since it is float16 and the tflite server only supports 32 bit precision if we want to use floating point values. Am I understanding that correctly or am I missing something? Cause the default YOLOv5 model that is included in the VOXL 2 model (yolov5_float16_quant.tflite) is also of float 16 precision so I wonder how the functions in tensor_data.h handle that.
      One question, what command did you use to view these error logs from voxl-tflite server?
      Error in TensorData<float>: should not reach here
        Zachary Lowell 0
        @svempati said in No detections when running custom YOLOv8 model on voxl-tflite-server:
        I just ran voxl-tflite-server directly from the command line instead of in the background via systemd - aka run voxl-tflite-server directly on the command line. I would recommend NOT quantizing your model as the directions in the train yolov8 do not recommend that.
        Zach
        S 2 Replies Last reply
          Zach
          S Offline
          S Offline
          svempati
          @Zachary-Lowell-0 Got it, I will try that out and will let you know if I have any more questions. Thanks for your help!
            Zach
            S Offline
            S Offline
            svempati
            #9
            @Zachary-Lowell-0 I wanted to follow up with you again on this, and the issue seems to be the model conversion process from pytorch to tflite. To confirm this, I tried it with the default yolov8n.pt downloaded from ultralytics by entering this command from the gitlab repository:
            python export.py yolov8n.pt
            So that I create a new yolov8n_float16.tflite file. However, running this file on voxl-tflite-server shows this output before displaying Error in TensorData<float>: should not reach here:
            WARNING: Unknown model type provided! Defaulting post-process to object detection.
            INFO: Created TensorFlow Lite delegate for GPU.
            INFO: Initialized OpenCL-based API.
            INFO: Created 1 GPU delegate kernels.
            Successfully built interpreter
            ------VOXL TFLite Server------
             4 5 6
             4 5 6
            Connected to camera server
            I even tried running export.py on the voxl emulator to account for any differences in the cpu architecture between my computer and the VOXL (between X86 and ARM) but I still get the same error. Do you think there is anything I would be missing? Thank you!
              Zachary Lowell 0
              @svempati I will try recreating this issue today and get back to you!
                S Offline
                S Offline
                svempati
                @Zachary-Lowell-0 Just wanted to follow up to see if you were able to replicate this issue?
                  Zachary Lowell 0
                  @svempati I was able to use an open source training set and then leverage the docs to make my own custom yolov8 model capable of running on the voxl2 - do you want to provide to me the actual dataset and I can try creating the model and training it on a TPU?
                    S Offline
                    S Offline
                    svempati
                    #13
                    @Zachary-Lowell-0 I would first like to diagnose what is causing the yolov8 model to not work on the voxl 2 for me. Will it only work when you train the model/ export it to tflite on a TPU? I am getting the issue even if I train the yolov8 model on an open source dataset/ use the pretrained yolov8n.pt model downloaded from ultralytics. I want to make sure I can train a yolov8 model on an open source dataset from scratch works on the voxl, so that I can move on to using my custom dataset.
                    In case there is no other workaround then I should be able to send you the dataset I am using.
                      Zachary Lowell 0
                      Let me try and train a custom model and run a loom on it in the next few days and get that over to you showing how I do it!
                        Zachary Lowell 0
                        https://www.loom.com/share/bf52e252ab09444bb366f265a3f36dc5
                        Alright take a look at this loom please - it might help point you in the right direction in terms of training your model.
                        Zach
                          Zach
                          S Offline
                          S Offline
                          svempati
                          @Zachary-Lowell-0 Thanks for sharing the video! I looked at it, and I pretty much did the same steps you did. It might be worth mentioning that I had to modify the Dockerfile because the one in the documentation was throwing a version mismatch error when installing the onnx part.
                          This was the original docker command
                          RUN pip3 install ultralytics tensorflow onnx "onnx2tf>1.17.5,<=1.22.3" tflite_support onnxruntime onnxslim "onnx_graphsurgeon>=0.3.26" "sng4onnx>=1.0.1" tf_keras
                          I modified it to this
                          RUN pip3 install ultralytics tensorflow "onnx2tf>1.17.5,<=1.22.3" tflite_support onnxruntime onnxslim "onnx_graphsurgeon>=0.3.26" "sng4onnx>=1.0.1" tf_keras
                          RUN pip3 install onnx==1.20.1
                          I don't think this should cause any issues, but could you confirm?
                          A 1 Reply Last reply
                          • S svempati
                            ApoorvThapliyal
                            Hey @svempati
                            I trained a model in the docker command as provided by you. I am able to run an inference on potholes following exactly the steps provided by @Zachary-Lowell-0 earlier.
                            Could I ask you what your voxl-tflite-version is? And if you havent yet, could you try to run this version: http://voxl-packages.modalai.com/dists/qrb5165/sdk-1.6/binary-arm64/voxl-tflite-server_0.5.1_arm64.deb
                            Make sure to change the .tflite model and labels as shown in the loom video after the install, then run voxl-configure-tflite
