    CP with custom sensors
    Modal Pipe Architecture (MPA)
    • G
      giladWDS
      I want to integrate collision prevention into my system.
      currently, I have a microcontroller that manages all the sensor data and is connected to the voxl2 through serial.
      now I debate two ways to implement this and I don't know that is the best approach.
      1. using mavlink directly to px4. I saw that the px4 exposes a UDP port to send mavlink msgs directly to px4. this feels sub-optimal as this bypasses the integrated VOA system and the voxel-vision-hub.
      2. make a pipe client and transform the data from the serial port to some kind of TOF sensor and publish it.
        Is the second option the way to go or is the first option viable as well?
        Furthermore, I don't see all the voxl-vision-hub pipes:
      voxl2:~$ voxl-list-pipes -t
      camera_image_metadata_t
      	hires_large_color
      	hires_large_encoded
      	hires_large_grey
      	hires_small_color
      	hires_small_encoded
      	hires_small_grey
      	hires_snapshot
      cpu_stats_t
      	cpu_monitor
      imu_data_t
      	imu_apps
      imu_fft_data_t
      	imu_apps_fft
      mavlink_message_t
      	mavlink_ap_heartbeat
      	mavlink_attitude
      	mavlink_from_gcs
      	mavlink_gps_raw_int
      	mavlink_local_position_ned
      	mavlink_onboard
      	mavlink_sys_status
      	mavlink_to_gcs
      point_cloud_metadata_t
      	voa_pc_out
      pose_vel_6dof_t
      	vvhub_body_wrt_fixed
      	vvhub_body_wrt_local
      string
      	gcs_ip_list
      text
      	horizon_cal_io
      Is this presenting all server pipes that have clients?
      James StrawsonJ 1 Reply Last reply Reply Quote 0
      • James StrawsonJ
        James Strawson ModalAI Team @giladWDS
        @giladWDS
        it looks like very few services are running. If you run voxl-inspect-services you can see what's enabled. You will want to enable voxl-vision-hub, voxl-mavlink-server and voxl-px4
        What kind of sensors and data are you dealing with? voxl-vision-hub can subscribe to rangefinder, generic points clouds, and tof data. Since all the logic for compensating for roll/pitch to level out the point cloud data then slice the data into pie-slices to send to PX4 is done already in voxl-vision-hub I would suggest leveraging this. I think the most simple solution would be option 2 and then edit the voxl-vision-hub config file to point to your new server's pipe.
        • G
          giladWDS @James Strawson
          @James-Strawson
          Thank you for the response.
          we want to use an array of 4 vl53l5cx sensors to capture data around the drone. I know that there is existing support for vl53l1cx sensors. since it is crucial to know of possible obstacles from multiple angles we need the 4x4 version.
          in this case, I have a point cloud of 64 points around the drone. so should I send those on the pointcloud pipe?
          for the few services:
          this is the service inspect output:
           Service Name             |  Enabled  |   Running   |  CPU Usage
           docker-autorun           |  Enabled  | Not Running |
           modallink-relink         | Disabled  | Not Running |
           voxl-camera-server       |  Enabled  |   Running   |     2.2%
           voxl-cpu-monitor         |  Enabled  |   Running   |     0.6%
           voxl-dfs-server          | Disabled  | Not Running |
           voxl-feature-tracker     | Disabled  | Not Running |
           voxl-flow-server         | Disabled  | Not Running |
           voxl-imu-server          |  Enabled  |   Running   |     0.1%
           voxl-lepton-server       | Disabled  | Not Running |
           voxl-mavcam-manager      | Disabled  | Not Running |
           voxl-mavlink-server      |  Enabled  |   Running   |     2.9%
           voxl-modem               | Disabled  | Not Running |
           voxl-neopixel-manager    | Disabled  | Not Running |
           voxl-open-vins-server    | Disabled  | Not Running |
           voxl-portal              |  Enabled  |   Running   |     0.1%
           voxl-px4-imu-server      | Disabled  | Not Running |
           voxl-px4                 |  Enabled  |   Running   |    30.5%
           voxl-qvio-server         | Disabled  | Not Running |
           voxl-rangefinder-server  | Disabled  | Not Running |
           voxl-remote-id           | Disabled  | Not Running |
           voxl-softap              | Disabled  | Not Running |
           voxl-static-ip           | Disabled  | Not Running |
           voxl-streamer            | Disabled  | Not Running |
           voxl-tag-detector        | Disabled  | Not Running |
           voxl-tflite-server       | Disabled  | Not Running |
           voxl-time-sync           | Disabled  | Not Running |
           voxl-uvc-server          | Disabled  | Not Running |
           voxl-vision-hub          |  Enabled  |   Running   |     1.7%
           voxl-wait-for-fs         |  Enabled  |  Completed  |
