  2. VOXL SDK and Software
  3. Unable to run "rosrun mavros mavsafety arm": Request failed. Check mavros logs
1 Posts 1 Posters 757 Views
  • Captain 7thC Offline
    Captain 7th
    I am trying to disarm my drone through rosrun mavros mavsafety arm but I got this error: Request failed. Check mavros logs
    Does anyone know why?
    Let me share more info:
    voxl2:~$ roslaunch mavros px4.launch fcu_url:=udp://127.0.0.1:14551@127.0.0.1:14551
    ... logging to /home/root/.ros/log/bf820300-75cc-11ef-ac5b-00c0cab5abe5/roslaunch-m0054-3885.log
    Checking log directory for disk usage. This may take a while.
    Press Ctrl-C to interrupt
    Done checking log file disk usage. Usage is <1GB.
    started roslaunch server http://m0054:40181/
    SUMMARY
    CLEAR PARAMETERS
     * /mavros/
    PARAMETERS
     * /mavros/camera/frame_id: base_link
     * /mavros/cmd/use_comp_id_system_control: False
     * /mavros/conn/heartbeat_rate: 1.0
     * /mavros/conn/system_time_rate: 1.0
     * /mavros/conn/timeout: 10.0
     * /mavros/conn/timesync_rate: 10.0
     * /mavros/distance_sensor/hrlv_ez4_pub/field_of_view: 0.0
     * /mavros/distance_sensor/hrlv_ez4_pub/frame_id: hrlv_ez4_sonar
     * /mavros/distance_sensor/hrlv_ez4_pub/id: 0
     * /mavros/distance_sensor/hrlv_ez4_pub/orientation: PITCH_270
     * /mavros/distance_sensor/hrlv_ez4_pub/send_tf: True
     * /mavros/distance_sensor/hrlv_ez4_pub/sensor_position/x: 0.0
     * /mavros/distance_sensor/hrlv_ez4_pub/sensor_position/y: 0.0
     * /mavros/distance_sensor/hrlv_ez4_pub/sensor_position/z: -0.1
     * /mavros/distance_sensor/laser_1_sub/id: 3
     * /mavros/distance_sensor/laser_1_sub/orientation: PITCH_270
     * /mavros/distance_sensor/laser_1_sub/subscriber: True
     * /mavros/distance_sensor/lidarlite_pub/field_of_view: 0.0
     * /mavros/distance_sensor/lidarlite_pub/frame_id: lidarlite_laser
     * /mavros/distance_sensor/lidarlite_pub/id: 1
     * /mavros/distance_sensor/lidarlite_pub/orientation: PITCH_270
     * /mavros/distance_sensor/lidarlite_pub/send_tf: True
     * /mavros/distance_sensor/lidarlite_pub/sensor_position/x: 0.0
     * /mavros/distance_sensor/lidarlite_pub/sensor_position/y: 0.0
     * /mavros/distance_sensor/lidarlite_pub/sensor_position/z: -0.1
     * /mavros/distance_sensor/sonar_1_sub/horizontal_fov_ratio: 1.0
     * /mavros/distance_sensor/sonar_1_sub/id: 2
     * /mavros/distance_sensor/sonar_1_sub/orientation: PITCH_270
     * /mavros/distance_sensor/sonar_1_sub/subscriber: True
     * /mavros/distance_sensor/sonar_1_sub/vertical_fov_ratio: 1.0
     * /mavros/fake_gps/eph: 2.0
     * /mavros/fake_gps/epv: 2.0
     * /mavros/fake_gps/fix_type: 3
     * /mavros/fake_gps/geo_origin/alt: 408.0
     * /mavros/fake_gps/geo_origin/lat: 47.3667
     * /mavros/fake_gps/geo_origin/lon: 8.55
     * /mavros/fake_gps/gps_rate: 5.0
     * /mavros/fake_gps/mocap_transform: True
     * /mavros/fake_gps/satellites_visible: 5
     * /mavros/fake_gps/tf/child_frame_id: fix
     * /mavros/fake_gps/tf/frame_id: map
     * /mavros/fake_gps/tf/listen: False
     * /mavros/fake_gps/tf/rate_limit: 10.0
     * /mavros/fake_gps/tf/send: False
     * /mavros/fake_gps/use_mocap: True
     * /mavros/fake_gps/use_vision: False
     * /mavros/fcu_protocol: v2.0
     * /mavros/fcu_url: udp://127.0.0.1:1...
     * /mavros/gcs_url:
     * /mavros/global_position/child_frame_id: base_link
     * /mavros/global_position/frame_id: map
     * /mavros/global_position/gps_uere: 1.0
     * /mavros/global_position/rot_covariance: 99999.0
     * /mavros/global_position/tf/child_frame_id: base_link
     * /mavros/global_position/tf/frame_id: map
     * /mavros/global_position/tf/global_frame_id: earth
     * /mavros/global_position/tf/send: False
     * /mavros/global_position/use_relative_alt: True
     * /mavros/image/frame_id: px4flow
     * /mavros/imu/angular_velocity_stdev: 0.0003490659 // 0...
     * /mavros/imu/frame_id: base_link
     * /mavros/imu/linear_acceleration_stdev: 0.0003
     * /mavros/imu/magnetic_stdev: 0.0
     * /mavros/imu/orientation_stdev: 1.0
     * /mavros/landing_target/camera/fov_x: 2.0071286398
     * /mavros/landing_target/camera/fov_y: 2.0071286398
     * /mavros/landing_target/image/height: 480
     * /mavros/landing_target/image/width: 640
     * /mavros/landing_target/land_target_type: VISION_FIDUCIAL
     * /mavros/landing_target/listen_lt: False
     * /mavros/landing_target/mav_frame: LOCAL_NED
     * /mavros/landing_target/target_size/x: 0.3
     * /mavros/landing_target/target_size/y: 0.3
     * /mavros/landing_target/tf/child_frame_id: camera_center
     * /mavros/landing_target/tf/frame_id: landing_target
     * /mavros/landing_target/tf/listen: False
     * /mavros/landing_target/tf/rate_limit: 10.0
     * /mavros/landing_target/tf/send: True
     * /mavros/local_position/frame_id: map
     * /mavros/local_position/tf/child_frame_id: base_link
     * /mavros/local_position/tf/frame_id: map
     * /mavros/local_position/tf/send: False
     * /mavros/local_position/tf/send_fcu: False
     * /mavros/mission/pull_after_gcs: True
     * /mavros/mission/use_mission_item_int: True
     * /mavros/mocap/use_pose: True
     * /mavros/mocap/use_tf: False
     * /mavros/mount/debounce_s: 4.0
     * /mavros/mount/err_threshold_deg: 10.0
     * /mavros/mount/negate_measured_pitch: False
     * /mavros/mount/negate_measured_roll: False
     * /mavros/mount/negate_measured_yaw: False
     * /mavros/odometry/fcu/odom_child_id_des: base_link
     * /mavros/odometry/fcu/odom_parent_id_des: map
     * /mavros/plugin_blacklist: ['safety_area', '...
     * /mavros/plugin_whitelist: []
     * /mavros/px4flow/frame_id: px4flow
     * /mavros/px4flow/ranger_fov: 0.118682
     * /mavros/px4flow/ranger_max_range: 5.0
     * /mavros/px4flow/ranger_min_range: 0.3
     * /mavros/safety_area/p1/x: 1.0
     * /mavros/safety_area/p1/y: 1.0
     * /mavros/safety_area/p1/z: 1.0
     * /mavros/safety_area/p2/x: -1.0
     * /mavros/safety_area/p2/y: -1.0
     * /mavros/safety_area/p2/z: -1.0
     * /mavros/setpoint_accel/send_force: False
     * /mavros/setpoint_attitude/reverse_thrust: False
     * /mavros/setpoint_attitude/tf/child_frame_id: target_attitude
     * /mavros/setpoint_attitude/tf/frame_id: map
     * /mavros/setpoint_attitude/tf/listen: False
     * /mavros/setpoint_attitude/tf/rate_limit: 50.0
     * /mavros/setpoint_attitude/use_quaternion: False
     * /mavros/setpoint_position/mav_frame: LOCAL_NED
     * /mavros/setpoint_position/tf/child_frame_id: target_position
     * /mavros/setpoint_position/tf/frame_id: map
     * /mavros/setpoint_position/tf/listen: False
     * /mavros/setpoint_position/tf/rate_limit: 50.0
     * /mavros/setpoint_raw/thrust_scaling: 1.0
     * /mavros/setpoint_velocity/mav_frame: LOCAL_NED
     * /mavros/startup_px4_usb_quirk: False
     * /mavros/sys/disable_diag: False
     * /mavros/sys/min_voltage: 10.0
     * /mavros/target_component_id: 1
     * /mavros/target_system_id: 1
     * /mavros/tdr_radio/low_rssi: 40
     * /mavros/time/time_ref_source: fcu
     * /mavros/time/timesync_avg_alpha: 0.6
     * /mavros/time/timesync_mode: MAVLINK
     * /mavros/vibration/frame_id: base_link
     * /mavros/vision_pose/tf/child_frame_id: vision_estimate
     * /mavros/vision_pose/tf/frame_id: odom
     * /mavros/vision_pose/tf/listen: False
     * /mavros/vision_pose/tf/rate_limit: 10.0
     * /mavros/vision_speed/listen_twist: True
     * /mavros/vision_speed/twist_cov: True
     * /mavros/wheel_odometry/child_frame_id: base_link
     * /mavros/wheel_odometry/count: 2
     * /mavros/wheel_odometry/frame_id: odom
     * /mavros/wheel_odometry/send_raw: True
     * /mavros/wheel_odometry/send_twist: False
     * /mavros/wheel_odometry/tf/child_frame_id: base_link
     * /mavros/wheel_odometry/tf/frame_id: odom
     * /mavros/wheel_odometry/tf/send: False
     * /mavros/wheel_odometry/use_rpm: False
     * /mavros/wheel_odometry/vel_error: 0.1
     * /mavros/wheel_odometry/wheel0/radius: 0.05
     * /mavros/wheel_odometry/wheel0/x: 0.0
     * /mavros/wheel_odometry/wheel0/y: -0.15
     * /mavros/wheel_odometry/wheel1/radius: 0.05
     * /mavros/wheel_odometry/wheel1/x: 0.0
     * /mavros/wheel_odometry/wheel1/y: 0.15
     * /rosdistro: melodic
     * /rosversion: 1.14.13
    NODES
        mavros (mavros/mavros_node)
    ROS_MASTER_URI=http://localhost:11311
    process[mavros-1]: started with pid [3905]
    [ INFO] [1726671462.865298704]: FCU URL: udp://127.0.0.1:14551@127.0.0.1:14551
    [ INFO] [1726671462.869065077]: udp0: Bind address: 127.0.0.1:14551
    [ INFO] [1726671462.869132420]: udp0: Remote address: 127.0.0.1:14551
    [ INFO] [1726671462.871294744]: GCS bridge disabled
    [ INFO] [1726671462.879079883]: Plugin 3dr_radio loaded
    [ INFO] [1726671462.880078520]: Plugin 3dr_radio initialized
    [ INFO] [1726671462.880140811]: Plugin actuator_control loaded
    [ INFO] [1726671462.881787047]: Plugin actuator_control initialized
    [ INFO] [1726671462.885081236]: Plugin adsb loaded
    [ INFO] [1726671462.887321633]: Plugin adsb initialized
    [ INFO] [1726671462.887454236]: Plugin altitude loaded
    [ INFO] [1726671462.888070064]: Plugin altitude initialized
    [ INFO] [1726671462.888141782]: Plugin cam_imu_sync loaded
    [ INFO] [1726671462.888472769]: Plugin cam_imu_sync initialized
    [ INFO] [1726671462.888537195]: Plugin camera loaded
    [ INFO] [1726671462.888864223]: Plugin camera initialized
    [ INFO] [1726671462.888927244]: Plugin cellular_status loaded
    [ INFO] [1726671462.890160097]: Plugin cellular_status initialized
    [ INFO] [1726671462.890231347]: Plugin command loaded
    [ INFO] [1726671462.895107345]: Plugin command initialized
    [ INFO] [1726671462.895462550]: Plugin companion_process_status loaded
    [ INFO] [1726671462.897225972]: Plugin companion_process_status initialized
    [ INFO] [1726671462.897301700]: Plugin debug_value loaded
    [ INFO] [1726671462.902058064]: Plugin debug_value initialized
    [ INFO] [1726671462.902095616]: Plugin distance_sensor blacklisted
    [ INFO] [1726671462.902179990]: Plugin esc_status loaded
    [ INFO] [1726671462.902769673]: Plugin esc_status initialized
    [ INFO] [1726671462.902845037]: Plugin esc_telemetry loaded
    [ INFO] [1726671462.903176023]: Plugin esc_telemetry initialized
    [ INFO] [1726671462.903265502]: Plugin fake_gps loaded
    [ INFO] [1726671462.912476565]: Plugin fake_gps initialized
    [ INFO] [1726671462.912619012]: Plugin ftp loaded
    [ INFO] [1726671462.915981795]: Plugin ftp initialized
    [ INFO] [1726671462.916077836]: Plugin geofence loaded
    [ INFO] [1726671462.917684748]: Plugin geofence initialized
    [ INFO] [1726671462.917773550]: Plugin global_position loaded
    [ INFO] [1726671462.929318655]: Plugin global_position initialized
    [ INFO] [1726671462.929446571]: Plugin gps_input loaded
    [ INFO] [1726671462.930911037]: Plugin gps_input initialized
    [ INFO] [1726671462.930995567]: Plugin gps_rtk loaded
    [ INFO] [1726671462.932572793]: Plugin gps_rtk initialized
    [ INFO] [1726671462.932653834]: Plugin gps_status loaded
    [ INFO] [1726671462.933874761]: Plugin gps_status initialized
    [ INFO] [1726671462.933953302]: Plugin guided_target loaded
    [ INFO] [1726671462.936268854]: Plugin guided_target initialized
    [ INFO] [1726671462.936351874]: Plugin hil loaded
    [ INFO] [1726671462.946114912]: Plugin hil initialized
    [ INFO] [1726671462.946241265]: Plugin home_position loaded
    [ INFO] [1726671462.950601799]: Plugin home_position initialized
    [ INFO] [1726671462.950714038]: Plugin imu loaded
    [ INFO] [1726671462.954832178]: Plugin imu initialized
    [ INFO] [1726671462.954950042]: Plugin landing_target loaded
    [ INFO] [1726671462.964023242]: Plugin landing_target initialized
    [ INFO] [1726671462.964170064]: Plugin local_position loaded
    [ INFO] [1726671462.969867253]: Plugin local_position initialized
    [ INFO] [1726671462.969972044]: Plugin log_transfer loaded
    [ INFO] [1726671462.971817444]: Plugin log_transfer initialized
    [ INFO] [1726671462.971929110]: Plugin mag_calibration_status loaded
    [ INFO] [1726671462.981040591]: Plugin mag_calibration_status initialized
    [ INFO] [1726671462.981181319]: Plugin manual_control loaded
    [ INFO] [1726671462.985301907]: Plugin manual_control initialized
    [ INFO] [1726671462.985417740]: Plugin mocap_pose_estimate loaded
    [ INFO] [1726671462.989715410]: Plugin mocap_pose_estimate initialized
    [ INFO] [1726671462.989856711]: Plugin mount_control loaded
    [ WARN] [1726671463.000827967]: Could not retrive negate_measured_roll parameter value, using default (0)
    [ WARN] [1726671463.001137131]: Could not retrive negate_measured_pitch parameter value, using default (0)
    [ WARN] [1726671463.001397233]: Could not retrive negate_measured_yaw parameter value, using default (0)
    [ WARN] [1726671463.002250819]: Could not retrive debounce_s parameter value, using default (4.000000)
    [ WARN] [1726671463.002499359]: Could not retrive err_threshold_deg parameter value, using default (10.000000)
    [ INFO] [1726671463.002546806]: Plugin mount_control initialized
    [ INFO] [1726671463.003329768]: Plugin nav_controller_output loaded
    [ INFO] [1726671463.004275020]: Plugin nav_controller_output initialized
    [ INFO] [1726671463.004357363]: Plugin obstacle_distance loaded
    [ INFO] [1726671463.006672707]: Plugin obstacle_distance initialized
    [ INFO] [1726671463.006769633]: Plugin odom loaded
    [ INFO] [1726671463.010279810]: Plugin odom initialized
    [ INFO] [1726671463.010398351]: Plugin onboard_computer_status loaded
    [ INFO] [1726671463.012245105]: Plugin onboard_computer_status initialized
    [ INFO] [1726671463.012358438]: Plugin param loaded
    [ INFO] [1726671463.014463731]: Plugin param initialized
    [ INFO] [1726671463.014579407]: Plugin play_tune loaded
    [ INFO] [1726671463.016387256]: Plugin play_tune initialized
    [ INFO] [1726671463.016483453]: Plugin px4flow loaded
    [ INFO] [1726671463.021737052]: Plugin px4flow initialized
    [ INFO] [1726671463.021872832]: Plugin rallypoint loaded
    [ INFO] [1726671463.023855731]: Plugin rallypoint initialized
    [ INFO] [1726671463.023897554]: Plugin rangefinder blacklisted
    [ INFO] [1726671463.026300814]: Plugin rc_io loaded
    [ INFO] [1726671463.029646200]: Plugin rc_io initialized
    [ INFO] [1726671463.029698231]: Plugin safety_area blacklisted
    [ INFO] [1726671463.029798282]: Plugin setpoint_accel loaded
    [ INFO] [1726671463.031504986]: Plugin setpoint_accel initialized
    [ INFO] [1726671463.031618110]: Plugin setpoint_attitude loaded
    [ INFO] [1726671463.037076968]: Plugin setpoint_attitude initialized
    [ INFO] [1726671463.037183842]: Plugin setpoint_position loaded
    [ INFO] [1726671463.049201131]: Plugin setpoint_position initialized
    [ INFO] [1726671463.049335557]: Plugin setpoint_raw loaded
    [ INFO] [1726671463.054972121]: Plugin setpoint_raw initialized
    [ INFO] [1726671463.055100089]: Plugin setpoint_trajectory loaded
    [ INFO] [1726671463.057608452]: Plugin setpoint_trajectory initialized
    [ INFO] [1726671463.057704180]: Plugin setpoint_velocity loaded
    [ INFO] [1726671463.062054923]: Plugin setpoint_velocity initialized
    [ INFO] [1726671463.062260650]: Plugin sys_status loaded
    [ INFO] [1726671463.070084278]: Plugin sys_status initialized
    [ INFO] [1726671463.070212090]: Plugin sys_time loaded
    [ INFO] [1726671463.076160110]: TM: Timesync mode: MAVLINK
    [ INFO] [1726671463.076424014]: TM: Not publishing sim time
    [ INFO] [1726671463.077227704]: Plugin sys_time initialized
    [ INFO] [1726671463.077334787]: Plugin terrain loaded
    [ INFO] [1726671463.077742752]: Plugin terrain initialized
    [ INFO] [1726671463.077829939]: Plugin trajectory loaded
    [ INFO] [1726671463.080625903]: Plugin trajectory initialized
    [ INFO] [1726671463.080710486]: Plugin tunnel loaded
    [ INFO] [1726671463.083419889]: Plugin tunnel initialized
    [ INFO] [1726671463.083536242]: Plugin vfr_hud loaded
    [ INFO] [1726671463.085674660]: Plugin vfr_hud initialized
    [ INFO] [1726671463.085863721]: Plugin vibration blacklisted
    [ INFO] [1726671463.086246322]: Plugin vision_pose_estimate loaded
    [ INFO] [1726671463.091077165]: Plugin vision_pose_estimate initialized
    [ INFO] [1726671463.091167268]: Plugin vision_speed_estimate loaded
    [ INFO] [1726671463.093310999]: Plugin vision_speed_estimate initialized
    [ INFO] [1726671463.093423237]: Plugin waypoint loaded
    [ INFO] [1726671463.097554242]: Plugin waypoint initialized
    [ INFO] [1726671463.097620544]: Plugin wheel_odometry blacklisted
    [ INFO] [1726671463.097717366]: Plugin wind_estimation loaded
    [ INFO] [1726671463.098288819]: Plugin wind_estimation initialized
    [ INFO] [1726671463.098411839]: Built-in SIMD instructions: ARM NEON
    [ INFO] [1726671463.098450745]: Built-in MAVLink package version: 2022.12.30
    [ INFO] [1726671463.098471005]: Known MAVLink dialects: common ardupilotmega ASLUAV AVSSUAS all cubepilot development icarous matrixpilot paparazzi standard storm32 uAvionix ualberta
    [ INFO] [1726671463.098493921]: MAVROS started. MY ID 1.240, TARGET ID 1.1
    [ INFO] [1726671463.098563817]: udp0: Remote address: 127.0.0.1:54920
    [ WARN] [1726671463.100022814]: GP: No GPS fix
    [ INFO] [1726671463.100963952]: IMU: High resolution IMU detected!
    [ INFO] [1726671463.102041859]: IMU: Attitude quaternion IMU detected!
    [ INFO] [1726671463.171056245]: CON: Got HEARTBEAT, connected. FCU: PX4 Autopilot
    [ INFO] [1726671463.207674565]: IMU: High resolution IMU detected!
    [ INFO] [1726671463.260930602]: IMU: Attitude quaternion IMU detected!
    [ INFO] [1726671464.182184752]: GF: Using MISSION_ITEM_INT
    [ INFO] [1726671464.182427406]: RP: Using MISSION_ITEM_INT
    [ INFO] [1726671464.182707403]: WP: Using MISSION_ITEM_INT
    [ INFO] [1726671464.183667864]: VER: 1.1: Capabilities         0x000000000000ecff
    [ INFO] [1726671464.184980248]: VER: 1.1: Flight software:     010e0000 (636ffefcb102004d)
    [ INFO] [1726671464.185900552]: VER: 1.1: Middleware software: 010e0000 (636ffefcb1000000)
    [ INFO] [1726671464.186142217]: VER: 1.1: OS software:         04137dff (3f77354c0dc88793)
    [ INFO] [1726671464.186327215]: VER: 1.1: Board hardware:      00000001
    [ INFO] [1726671464.186974709]: VER: 1.1: VID/PID:             0000:0000
    [ INFO] [1726671464.187178041]: VER: 1.1: UID:                 5649414c324c584f
    [ WARN] [1726671464.188356520]: CMD: Unexpected command 520, result 0
    [ INFO] [1726671473.177403186]: HP: requesting home position
    [ INFO] [1726671478.176482057]: GF: mission received
    [ INFO] [1726671478.177594704]: RP: mission received
    [ INFO] [1726671478.178223448]: WP: mission received
    [ INFO] [1726671483.176735398]: HP: requesting home position
    [ INFO] [1726671493.176405941]: HP: requesting home position
    [ WARN] [1726671493.275066105]: GP: No GPS fix
    [ INFO] [1726671503.180478788]: HP: requesting home position
    [ INFO] [1726671513.176654363]: HP: requesting home position
    [ INFO] [1726671523.176815788]: HP: requesting home position
    And here is:
    voxl2:~/.ros/log/latest$ rostopic echo /mavros/state
    header:
      seq: 860
      stamp:
        secs: 1726672322
        nsecs: 120797373
      frame_id: ''
    connected: True
    armed: False
    guided: False
    manual_input: True
    mode: "MANUAL"
    system_status: 3
    header:
      seq: 861
      stamp:
        secs: 1726672323
        nsecs: 121633367
      frame_id: ''
    connected: True
    armed: False
    guided: False
    manual_input: True
    mode: "MANUAL"
    system_status: 3
    header:
      seq: 862
      stamp:
        secs: 1726672324
        nsecs: 120723284
      frame_id: ''
    connected: True
    armed: False
    guided: False
    manual_input: True
    mode: "MANUAL"
    system_status: 3
    And here is:
    voxl2:~/.ros/log/latest$ rostopic list
    /diagnostics
    /mavlink/from
    /mavlink/gcs_ip
    /mavlink/to
    /mavros/actuator_control
    /mavros/adsb/send
    /mavros/adsb/vehicle
    /mavros/altitude
    /mavros/battery
    /mavros/cam_imu_sync/cam_imu_stamp
    /mavros/camera/image_captured
    /mavros/cellular_status/status
    /mavros/companion_process/status
    /mavros/debug_value/debug
    /mavros/debug_value/debug_float_array
    /mavros/debug_value/debug_vector
    /mavros/debug_value/named_value_float
    /mavros/debug_value/named_value_int
    /mavros/debug_value/send
    /mavros/esc_info
    /mavros/esc_status
    /mavros/esc_telemetry
    /mavros/estimator_status
    /mavros/extended_state
    /mavros/fake_gps/mocap/tf
    /mavros/geofence/waypoints
    /mavros/global_position/compass_hdg
    /mavros/global_position/global
    /mavros/global_position/gp_lp_offset
    /mavros/global_position/gp_origin
    /mavros/global_position/home
    /mavros/global_position/local
    /mavros/global_position/raw/fix
    /mavros/global_position/raw/gps_vel
    /mavros/global_position/raw/satellites
    /mavros/global_position/rel_alt
    /mavros/global_position/set_gp_origin
    /mavros/gps_input/gps_input
    /mavros/gps_rtk/rtk_baseline
    /mavros/gps_rtk/send_rtcm
    /mavros/gpsstatus/gps1/raw
    /mavros/gpsstatus/gps1/rtk
    /mavros/gpsstatus/gps2/raw
    /mavros/gpsstatus/gps2/rtk
    /mavros/hil/actuator_controls
    /mavros/hil/controls
    /mavros/hil/gps
    /mavros/hil/imu_ned
    /mavros/hil/optical_flow
    /mavros/hil/rc_inputs
    /mavros/hil/state
    /mavros/home_position/home
    /mavros/home_position/set
    /mavros/imu/data
    /mavros/imu/data_raw
    /mavros/imu/diff_pressure
    /mavros/imu/mag
    /mavros/imu/static_pressure
    /mavros/imu/temperature_baro
    /mavros/imu/temperature_imu
    /mavros/landing_target/lt_marker
    /mavros/landing_target/pose
    /mavros/landing_target/pose_in
    /mavros/local_position/accel
    /mavros/local_position/odom
    /mavros/local_position/pose
    /mavros/local_position/pose_cov
    /mavros/local_position/velocity_body
    /mavros/local_position/velocity_body_cov
    /mavros/local_position/velocity_local
    /mavros/log_transfer/raw/log_data
    /mavros/log_transfer/raw/log_entry
    /mavros/mag_calibration/report
    /mavros/mag_calibration/status
    /mavros/manual_control/control
    /mavros/manual_control/send
    /mavros/mission/reached
    /mavros/mission/waypoints
    /mavros/mocap/pose
    /mavros/mount_control/command
    /mavros/mount_control/orientation
    /mavros/mount_control/status
    /mavros/nav_controller_output
    /mavros/obstacle/send
    /mavros/odometry/in
    /mavros/odometry/out
    /mavros/onboard_computer/status
    /mavros/param/param_value
    /mavros/play_tune
    /mavros/px4flow/ground_distance
    /mavros/px4flow/raw/optical_flow_rad
    /mavros/px4flow/raw/send
    /mavros/px4flow/temperature
    /mavros/radio_status
    /mavros/rallypoint/waypoints
    /mavros/rc/in
    /mavros/rc/out
    /mavros/rc/override
    /mavros/setpoint_accel/accel
    /mavros/setpoint_attitude/cmd_vel
    /mavros/setpoint_attitude/thrust
    /mavros/setpoint_position/global
    /mavros/setpoint_position/global_to_local
    /mavros/setpoint_position/local
    /mavros/setpoint_raw/attitude
    /mavros/setpoint_raw/global
    /mavros/setpoint_raw/local
    /mavros/setpoint_raw/target_attitude
    /mavros/setpoint_raw/target_global
    /mavros/setpoint_raw/target_local
    /mavros/setpoint_trajectory/desired
    /mavros/setpoint_trajectory/local
    /mavros/setpoint_velocity/cmd_vel
    /mavros/setpoint_velocity/cmd_vel_unstamped
    /mavros/state
    /mavros/statustext/recv
    /mavros/statustext/send
    /mavros/target_actuator_control
    /mavros/terrain/report
    /mavros/time_reference
    /mavros/timesync_status
    /mavros/trajectory/desired
    /mavros/trajectory/generated
    /mavros/trajectory/path
    /mavros/tunnel/in
    /mavros/tunnel/out
    /mavros/vfr_hud
    /mavros/vision_pose/pose
    /mavros/vision_pose/pose_cov
    /mavros/vision_speed/speed_twist_cov
    /mavros/wind_estimation
    /move_base_simple/goal
    /rosout
    /rosout_agg
    /tf
    /tf_static
