  3. Stereo interface received non-stereo frame, exiting stereo
1 Posts 1 Posters 372 Views
  • P Offline
    P Offline
    planch98
    Hi, I'm working with the stereo cameras. The stereo images and the disparity image are shown on voxl-portal. After launching voxl-mpa-to-ros and subscribing to /stereo_disparity/left with rostopic echo, voxl-mpa-to-ros prompt this error:
    After that, the topics related to stereo interface (/stereo_disparity/left,/stereo_disparity/right) disappear. Same happens with /stereo_disparity_scaled/right
    I also tried to visualize the disparity on rviz. In that case the mpa-to-ros crashes with the following:
    [voxl_mpa_to_ros_node-2] process has died [pid 5846, exit code -11, cmd /opt/ros/melodic/lib/voxl_mpa_to_ros/voxl_mpa_to_ros_node __name:=voxl_mpa_to_ros_node __log:=/home/root/.ros/log/2bfc2770-2715-11ee-9d49-00c0cab15bca/voxl_mpa_to_ros_node-2.log].
    log file: /home/root/.ros/log/2bfc2770-2715-11ee-9d49-00c0cab15bca/voxl_mpa_to_ros_node-2*.log
    Any clue on what is going on?
    system-image: 1.5.5-M0054-14.1a-perf
    kernel: #1 SMP PREEMPT Fri Mar 24 00:48:55 UTC 2023 4.19.125
    hw version: M0054
    voxl-suite: 0.9.5
