Nicholas SheldonN
Nicholas Sheldon
@Nicholas Sheldon
  • Starling 2 VIO Failure
    Nicholas SheldonN Nicholas Sheldon
    Hello! I am struggling to resolve an issue with our starling 2. In the process of building and deploying our own offboard mode, it seems that we have introduced a problem. We have since cloned the voxl-vision-hub repo, and built and deployed it in attempt to get back to square one. We cannot get VIO to work properly anymore. Please help me determine how to make progress!
    Background:
    kernel:       #1 SMP PREEMPT Mon Mar 24 22:31:58 UTC 2025 4.19.125
    hw platform:  M0054
    mach.var:     1.0.1
    SKU:          MRB-D0014-4-V1-C27-T7-M22-X0
    voxl-suite:   1.5.0
    voxl2:/$ voxl-inspect-services
    Scanning services...
     voxl-camera-server       |  Enabled  |   Running   |    75.0%
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.0%
     voxl-dfs-server          | Disabled  | Not Running |
     voxl-elrs-startup        | Disabled  | Not Running |
     voxl-feature-tracker     | Disabled  | Not Running |
     voxl-flow-server         | Disabled  | Not Running |
     voxl-imu-server          |  Enabled  |   Running   |     1.9%
     voxl-joystick-server     | Disabled  | Not Running |
     voxl-lepton-tracker      | Disabled  | Not Running |
     voxl-logger              | Disabled  | Not Running |
     voxl-mavcam-manager      |  Enabled  |   Running   |     0.0%
     voxl-mavlink-server      |  Enabled  |   Running   |     1.9%
     voxl-mini-tof-server     | Disabled  | Not Running |
     voxl-modem-doodle        | Disabled  | Not Running |
     voxl-open-vins-server    |  Enabled  |   Running   |    82.7%
     voxl-osd                 | Disabled  | Not Running |
     voxl-portal              |  Enabled  |   Running   |     0.0%
     voxl-px4                 |  Enabled  |   Running   |    25.0%
     voxl-qvio-server         |  Enabled  |   Running   |    34.6%
     voxl-rangefinder-server  |  Enabled  |   Running   |     0.0%
     voxl-seek-server         | Disabled  | Not Running |
     voxl-softap              | Disabled  | Not Running |
     voxl-state-estimator     | Disabled  | Not Running |
     voxl-streamer            |  Enabled  |   Running   |     0.0%
     voxl-tag-detector        | Disabled  | Not Running |
     voxl-tflite-server       | Disabled  | Not Running |
     voxl-vision-hub          |  Enabled  | Not Running |
     voxl-vrx                 | Disabled  | Not Running |
     voxl-vtx                 | Disabled  | Not Running |
    Here is the message we get when running voxl-vision-hub -o (important part at bottom):
    voxl2:/$ voxl-vision-hub -o
    loading our own config file
    Parameters as loaded from config file:
    config_file_version:        1
    MAVROS / MAVSDK
    en_localhost_mavlink_udp    0
    localhost_udp_port_number:  14551
    VIO
    en_vio:                     1
    vio_pipe:                   qvio
    secondary_vio_pipe:         ov
    en_reset_vio_if_initialized_inverted: 1
    vio_warmup_s:               10.000000
    send_odom_while_failed:     1
    MISC FEATURES
    horizon_cal_tolerance:      0.500000
    en_hitl:                    0
    OFFBOARD MODE
    offboard_mode:              figure_eight
    follow_tag_id:              0
    figure_eight_move_home:     1
    wps_move_home:     1
    wps_timeout:     0.000000
    wps_damp:     1.000000
    wps_vfc_mission:     true
    wps_vfc_mission_loop:     false
    wps_vfc_mission_to_ramp:     25.000000
    wps_vfc_mission_cruise_speed:     1.000000
    wps_vfc_mission_to_kp:     0.100000
    robot_radius:               0.300000
    collision_sampling_dt:      0.100000
    max_lookahead_distance:     1.000000
    backtrack_seconds     :     60
    backtrack_rc_chan     :     8
    backtrack_rc_thresh   :     1500
    FIXED FRAME RELOCALIZATION
    en_tag_fixed_frame:         0
    fixed_frame_filter_len:     5
    en_transform_mavlink_pos_setpoints_from_fixed_frame:0
    VOXL FLIGHT CONTROLLER (VFC)
    vfc_rate                    100.000000
    vfc_rc_chan_min             980
    vfc_rc_chan_max             2020
    vfc_thrust_ch               3
    vfc_roll_ch                 1
    vfc_pitch_ch                2
    vfc_yaw_ch                  4
    vfc_submode_ch              6
    vfc_alt_mode_rc_min         0
    vfc_alt_mode_rc_max         0
    vfc_flow_mode_rc_min        0
    vfc_flow_mode_rc_max        0
    vfc_hybrid_flow_mode_rc_min 0
    vfc_hybrid_flow_mode_rc_max 0
    vfc_position_mode_rc_min    0
    vfc_position_mode_rc_max    2100
    vfc_traj_mode_rc_min        0
    vfc_traj_mode_rc_max        0
    vfc_yaw_deadband            30
    vfc_vxy_deadband            50
    vfc_vz_deadband             150
    vfc_min_thrust              0.000000
    vfc_max_thrust              0.800000
    vfc_tilt_max                0.436000
    vfc_yaw_rate_max            3.000000
    vfc_thrust_hover            0.500000
    vfc_vz_max                  1.000000
    vfc_kp_z                    5.290000
    vfc_kd_z                    5.980000
    vfc_vxy_max                 3.000000
    vfc_kp_xy                   0.640000
    vfc_kd_xy                   2.560000
    vfc_kp_z_vio                5.290000
    vfc_kd_z_vio                5.980000
    vfc_kp_xy_vio               3.240000
    vfc_kd_xy_vio               3.960000
    vfc_w_filt_xy_vio           10.000000
    vfc_w_filt_xy_flow          3.000000
    vfc_vel_ff_factor_vio       0.900000
    vfc_xy_acc_limit_vio        2.500000
    vfc_max_z_delta             3.000000
    vfc_att_transition_time     0.500000
    vfc_stick_move_threshold    30.000000
    vfc_flow_transition_time    1.000000
    vfc_q_min                   10
    vfc_points_min              7
    vfc_en_submode_announcement 1
    vfc_disable_fallback        0
    COLLISION PREVENTION (VOA)
    en_voa:                     1
    voa_upper_bound_m:          -0.150000
    voa_lower_bound_m:          0.150000
    voa_memory_s:               1.000000
    voa_max_pc_per_fusion:      100
    voa_pie_min_dist_m:         0.250000
    voa_pie_max_dist_m:         20.000000
    voa_pie_under_trim_m:       1.000000
    voa_pie_threshold:          3
    voa_pie_slices:             36
    voa_pie_bin_depth_m:        0.150000
    voa_send_rate_hz:           20.000000
    voa_input #0
        enabled:            1
        type:               point_cloud
        input_pipe:         dfs_point_cloud
        frame:              stereo_l
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        x_fov_deg:          68.000000
        y_fov_deg:          56.000000
        conf_cutoff:        0
    voa_input #1
        enabled:            1
        type:               point_cloud
        input_pipe:         stereo_front_pc
        frame:              stereo_front_l
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        conf_cutoff:        0
    voa_input #2
        enabled:            1
        type:               point_cloud
        input_pipe:         stereo_rear_pc
        frame:              stereo_rear_l
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        conf_cutoff:        0
    voa_input #3
        enabled:            1
        type:               tof
        input_pipe:         tof
        frame:              tof
        max_depth:          6.000000
        min_depth:          0.150000
        cell_size:          0.080000
        threshold:          3
        x_fov_deg:          106.500000
        y_fov_deg:          85.099998
        conf_cutoff:        125
    voa_input #4
        enabled:            1
        type:               rangefinder
        input_pipe:         rangefinders
        frame:              body
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        conf_cutoff:        0
    loading extrinsics config file
    loading horizon cal file
    starting geometry module
    starting autopilot monitor
    starting mavlink IO
    Waiting to connect to voxl-mavlink-server
    Connected to voxl-mavlink-server
    starting fixed pose input
    starting vio manager
    Connected to VIO pipe: qvio
    Connected to VIO pipe: ov
    starting tag manager
    starting voa manager
    Connected to VOA input pipe: tof
    starting horizon cal module
    Connected to VOA input pipe: rangefinders
    starting imu manager
    starting state manager
    starting offboard figure eight
    Detected Autopilot Mavlink SYSID 1
    requesting autopilot_version
    Init complete
    Detected autopilot version: 1.14.0
    WARNING, _stop_helper_and_remove_pipe timed out joining read thread
    ERROR in pipe_client_get_info_json, channel 0 not initialized yet
    WARNING: failed to get info json from qvio server
    ERROR in pipe_client_get_info_json, channel 1 not initialized yet
    ^C
    Development Drones starling
