    1. Home
    2. colombe.ai
    C
    • Profile
    • Following 0
    • Followers 0
    • Topics 6
    • Posts 9
    • Best 0
    • Controversial 0
    • Groups 0
    Posts made by colombe.ai
    • Starling 2 Max GPS
      My organization just received our Starling 2 Max Drone. We flew it today for the first time. We had had QGround Control Up but couldn’t ever get a GPS lock. I had the drone outside in open area for well over 30 minutes for it to cold boot.
      The cable harness from the u-blox M10 GNSS GPS module down to the Voxl seems secured.
      Could it be a driver issue? What else can my engineers try and check?
      Thank you
      posted in Starling & Starling 2
      C
      colombe.ai
    • RE: Starling V1 - cannot use RC and GPS
      @Eric-Katzfey
      I bought the drone off of Ebay, the seller claimed that it was open box, never flown or operated, there is no visual damage to the drone.
      I am out today, I will be ready to do lower level debugging 22 hours after I post this message. Let me know if there are any tools which would be useful for debugging that I can try to get in advance. Right now, all I have is a multimeter.
      C
      colombe.ai
      @Eric-Katzfey
      Hi Eric,
      Sorry for the late response.
      Here is the inspect SKU output:
      voxl-inspect-sku
      family code:   MRB-D0005 (starling-1-discontinued (D0005))
      compute board: 4 (voxl2)
      hw version:    2
      cam config:    6
      modem config:  0 (none)
      tx config:     7 (elrs_beta_fpv)
      extras config: 0 (none)
      SKU:           MRB-D0005-4-V2-C6-T7-M0-X0
      The drone was not flying previously, I was using SDK version 1.0.0, if I go back to that version the problem is not resolved.
      Please let me know if you need anything else, and thank you for your help!
      C
      colombe.ai
      The GPS is the Taoglas that comes with the Starling V1, the light is green, the ELRS is a BetaFPV 900 Nano RX, the light is solid blue, so I think it's stuck in bootloader mode, but I can't even reset it with the voxl-elrs utility, since the scan doesn't even register that something is connected to the port.
      C
      colombe.ai
    • Starling V1 - cannot use RC and GPS
      I cannot fly my Starling V1, flashed with latest M0054-1 image(14.1a_1.7.8) and latest SDK version(1.6.2), with correctly selected voxl-configure-mpa version(Starling V1 with silver motors)
      QGroundControl says that Compass Sensor 0 is missing, even though I have the GPS Taoglas chip connected.
      Furthermore:
      px4-listener sensor_gps
      never published
      Also, the RC was not working, so I just wanted to check that:
      px4-listener input_rc
      TOPIC: input_rc
       input_rc
          timestamp: 91987808 (0.005253 seconds ago)
          timestamp_last_signal: 0
          rssi: -1
          rssi_dbm: nan
          rc_lost_frame_count: 0
          rc_total_frame_count: 0
          rc_ppm_frame_length: 0
          values: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
          channel_count: 16
          rc_failsafe: True
          rc_lost: True
          input_source: 14
          link_quality: -1
      It is receiving messages, but the RC is lost. After running voxl-elrs --scan:
      voxl-elrs --scan
      Autodetecting device information...
      As seen above, nothing shows up and no device is recognized where the ELRS should be detected. Since both the GPS and ELRS are plugged into the same physical connector(J19), I wonder if there is a driver issue with that, and just wanted general guidance if this was an issue seen before. Both the ELRS and GPS get power, the WiFi USB dongle(ALFA Network) on the same extension board(M2300000KGX) as the J19 connector works too, it's just that the data connections to the ELRS and GPS don't seem to work.
      C
      colombe.ai
    • Starling 2 Max Accessories and Cables
      Where can I locate a data sheet for all the required accessories I will need for the Starling 2 Max.
      My company will need the following:
      1. Batteries
      2. Charger
      3. Handheld transmitter that is compatible with receiver inside of the drone
      4. Anytime of UART Debugging cable or programming cable that the engineers will need.
      C
      colombe.ai
    • Shipping to Texas Starling 2 Max with 5G
      What has been the typical turn around time for a Starling 2 Max with 5G in the US?
      Does Modal AI provide overnight shipping if customer request and pays for it ?
      C
      colombe.ai
    • Starling 2 Max with 5G capability
      In everyone’s experience, what has been the best cellular carrier provider for the 5G access to the Starling 2 Max with 5G capability?
      My engineers would need to be able to push updates remotely to our drone and we would like to see full motion video of the drone for short durations of time during testing.
      C
      colombe.ai
    • fully factory reset my Starling V1
      I just bought a Starling V1, and want to reset it to full factory configuration, how can I do that?
      C
      colombe.ai
