    1. Home
    2. binu.abraham
    B
    • Profile
    • Following 0
    • Followers 0
    • Topics 1
    • Posts 4
    • Best 0
    • Controversial 0
    • Groups 0
    Posts made by binu.abraham
    • RE: Getting mavsdk server running on voxl2
      @binu-abraham
      Wanted to post about how I got this working finally
      I was having issues with docker build ( would segfault on ubuntu) and building the mavsdk from source ( while running the binary on voxl2, it complained that glibc was missing ) , so I finally downloaded the mavsdk_server_linux-arm64-musl from https://github.com/mavlink/MAVSDK/releases
      Followed the instructions to set the vision hub prameters from https://docs.modalai.com/mavsdk/
      Started the mavsdk-server
      ./mavsdk_server_linux-arm64-musl -p 50051 udpin://0.0.0.0:14550
      From the android app
      drone = System(
      <drone IP address>,
      50051 // -p parameter for mavsdk-server
      Don't call mavsdkServer.run as mavsdkserver is already running in voxl2
      posted in VOXL SDK
      B
      binu.abraham
      @binu-abraham Is there a pre-built docker image for mavsdk server on voxl2 ?
      posted in VOXL SDK
      B
      binu.abraham
      @binu-abraham I found the voxl-configure-docker-support script, trying to run it now
      posted in VOXL SDK
      B
      binu.abraham
    • Getting mavsdk server running on voxl2
      I have a voxl2 drone, I can ssh to it, but can't adb in right now.
      I am trying to follow the instructions on https://docs.modalai.com/mavsdk/ But cannot find the voxl-mavsdk.tar file that is referenced in the video in the download.
      So I have tried to build it using the docker https://gitlab.com/voxl-public/voxl-docker-images/voxl-docker-mavsdk. But the build.sh assumes the device is connected via adb .
      I tried running those commands from the ssh shell , but I couldn't find voxl-configure-docker-support.sh.
      Is there a different set of instructions for voxl2 ?
      posted in VOXL SDK
      B
      binu.abraham
