voxl-tflite-server with USB Camera
Hey,
i'm currently trying to setup the voxl-tflite-server with a usb camera connected to the Voxl. Is it possible to use the tflite-server with a usb camera? I didn't find any support on the voxl-camera-server that forwards the camera stream to voxl-tflite-server, for usb. -
Hello @Philemon-Benner ,
It is possible to use any MPA image pipe as input for voxl-tflite-server.
For a usb camera, you must be using the latest voxl-uvc-server to get the camera frames from your usb device into our MPA pipes.
Then, you must modify the config file (under /etc/modalai/voxl-tflite-server.conf) such that the input pipe matches the new usb pipe:
voxl:/$ vi /etc/modalai/voxl-tflite-server.conf /** * This file contains configuration that's specific to voxl-tflite-server. * * skip_n_frames - how many frames to skip between processed frames. For 30hz * input frame rate, we recommend skipping 5 frame resulting * in 5hz model output. * model - which model to use. Currently support mobilenet for * object detection or midas for monocular depth * input_pipe - which camera to use (tracking or hires). */ { "skip_n_frames": 0, "model": "/usr/bin/dnn/ssdlite_mobilenet_v2_coco.tflite", "input_pipe": "/run/mpa/USB_PIPE_NAME/", // CHANGE HERE "delegate": "gpu" }The only limitation with the tflite server is supported image formats. In this code block, there is a switch for the supported formats, so if your input data is not in NV12, NV21, or RAW8 format you will have to add handling for your specific type.
