  3. Calibrating Extrinsics and DFS
2 Posts 2 Posters 669 Views 1 Watching
  • Taylor PresleyT Offline
    Taylor Presley
    Re: VOXL2 Stereo Calibrate ERROR
    Hey everyone,
    I'm recalibrating the Sentinel stereo cameras because it was not publishing DFS (even though the server is running).
    Upon trying to recalibrate, I'm having a similar issue to @AP123 post VOXL2 Stereo Calibrate ERROR.
    All comments and recommendations are welcome!
    Taylor
    voxl2:/$ voxl-calibrate-camera stereo_front -s 6x9 -l 0.02
    Please open voxl-portal in a web browser to view the camera calibrator overlay stream
    Running Calibration...
    Calibrating Left Camera
    Matrix
    [548.5382302680308, 0, 285.3415669716975;
     0, 547.0025566893958, 235.3038337229943;
     0, 0, 1]
    Distortion
    [-0.2424323763061194;
     0.1269460760379177;
     -0.004142521667776578;
     0.002519660999314344;
     0]
    distortion_model: plumb_bob
    Re-projection error reported by calibrateCamera: 0.484597
    Calibration Succeded!
    Calibrating Right Camera
    Matrix
    [543.062224502327, 0, 301.719040785862;
     0, 542.0482517180614, 245.9552291727296;
     0, 0, 1]
    Distortion
    [-0.236760512593058;
     0.1416137307136648;
     -0.002976128262009898;
     0.0009654060730829055;
     0]
    Re-projection error reported by calibrateCamera: 0.528407
    7 frames will be processed
    R
    [0.999257189294548, -0.03760915797903753, -0.008403622984628861;
     0.03775986819471018, 0.9991144801232372, 0.01855930930804526;
     0.007698181413691082, -0.01886284295066306, 0.999792444039632]
    T
    [-0.07616424149746555;
     -0.001485191500948734;
     -0.01076830039005899]
    Re-projection error reported by stereoCalibrate: 1.421312
    Detected horizontal stereo pair
    Distance between cameras: 0.0762
    Extrinsics Calibration Failed
    exceeded allowable max reprojection error:  0.5
    Saved intrinsics to: /data/modalai/opencv_stereo_front_intrinsics.yml
    Exiting Cleanly
    Additional details for reference:
    voxl2:/$ voxl-inspect-services
    Scanning services...
     voxl-camera-server       |  Enabled  |   Running   |    97.7%
     voxl-cpu-monitor         |  Enabled  |   Running   |     0.4%
     voxl-dfs-server          |  Enabled  |   Running   |    18.2%
     voxl-imu-server          |  Enabled  |   Running   |     4.4%
     voxl-mavlink-server      |  Enabled  |   Running   |     2.7%
     voxl-neopixel-manager    | Disabled  | Not Running |
     voxl-open-vins-server    | Disabled  | Not Running |
     voxl-portal              |  Enabled  |   Running   |    31.8%
     voxl-px4-imu-server      | Disabled  | Not Running |
     voxl-px4                 |  Enabled  |   Running   |    29.5%
     voxl-qvio-server         |  Enabled  |   Running   |    13.5%
     voxl-softap              |  Enabled  |  Completed  |
     voxl-streamer            |  Enabled  |   Running   |     0.0%
     voxl-vision-hub          |  Enabled  |   Running   |     4.1%
    mdr@mdr-System-Product-Name:~$ adb shell
    * daemon not running; starting now at tcp:5037
    * daemon started successfully
    system-image: 1.7.4-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Fri Feb 9 21:59:24 UTC 2024 4.19.125
    hw platform:  M0054
    mach.var:     1.0
    voxl-suite:   1.1.3-1
    ? 1 Reply Last reply
    • Taylor PresleyT Taylor Presley
      Hey everyone,
      Taylor
      Matrix
       0, 0, 1]
      Distortion
       0.1269460760379177;
       0]
      Matrix
       0, 0, 1]
      Distortion
       0.1416137307136648;
       0]
      R
      T
      Exiting Cleanly
      hw platform:  M0054
      mach.var:     1.0
      voxl-suite:   1.1.3-1
      @Taylor-Presley
      Hey Taylor, happy to try and help!
      On calibrating we try to keep the reprojection error as low as possible. You're getting an error of 1.42 which is almost triple what we'd like at worst. I'd recommend trying to recalibrate in different lighting conditions with as flat of a checkerboard as you can make. Even small imperfections here can lead to bad calibration.
      Hope this helps!
      Thomas
