  3. Open CV and CV Bridge
rb5
1 Posts 1 Posters 786 Views
  • alfa budimanA Offline
    alfa budiman
    wrote on last edited by alfa budiman
    I'd like to share my experience installing these packages on the RB5 drone. It was not pleasant but it got done.
    I tried several variations of pip install opencv-python, with different versions of opencv and pip / pip2 / pip3, none of those worked. I tried sudo apt install and that didn't work. Similar issues popped up trying CV Bridge.
    Ultimately, I ended up having to build these packages from source (I think that's the right term). I followed the steps here: https://pyimagesearch.com/2015/06/22/install-opencv-3-0-and-python-2-7-on-ubuntu/
    to install opencv. I ignored steps 8 and 9.
    To install CV Bridge, first I installed opencv as per the linked instructions. Then, I repeated the linked instructions step 10 but with the github repo for CV Bridge (https://github.com/ros-perception/vision_opencv). After this, you must edit the ~/.bashrc on the drone and enter the following:
    export LD_LIBRARY_PATH=/usr/local/lib
    These packages can then be used for computer vision work with camera imagery from voxl_mpa_to_ros_node. If anyone was able to install these packages using just pip install, I'd like to know how, as I believe this issue, of having to install from source may pop up in other packages I try to install on the drone.
