  3. Sentinel VOA software not available
sentinel
6 Posts 2 Posters 1.8k Views 1 Watching
  • M Offline
    M Offline
    mkwan
    My Sentinel drone is not outputting valid VOA measurements.
    I have enabled voxl-dfs-server, and I can see correct point clouds from stereo_front_pc and stereo_rear_pc using voxl-portal. I can also see correct stereo_front_disparity and stereo_rear_disparity.
    I have set en_voa to true, and en_send_voa_to_qgc to true, and I can see OBSTACLE_DISTANCE messages in QGC but they are all 1001 when max_distance is 1000.
    This is the list of items in /run/mpa:
    cpu_monitor	qvio_extended		       stereo_front_pc		     tracking		   vvpx4_fixed_pose_input
    hires		qvio_overlay		       stereo_rear		     voa_pc_out		   vvpx4_gps_raw_int
    imu_apps	stereo_front		       stereo_rear_disparity	     vvpx4_body_wrt_fixed  vvpx4_mavlink_io
    mavlink_to_px4	stereo_front_disparity	       stereo_rear_disparity_scaled  vvpx4_body_wrt_local  vvpx4_sys_status
    qvio		stereo_front_disparity_scaled  stereo_rear_pc		     vvpx4_control_input   vvpx4_vehicle_gps
    The command voxl-inspect-points voa_pc_out returns no data:
    timestamp(ms)| # points | # bytes |     1st point     | Format
    According to the documentation at https://docs.modalai.com/sentinel-user-guide-using-voa/, I should be able to run
    • voxl-voa-server-configure
    • voxl-voa-to-px4
    • voxl-voa-client
    but none of these commands are available.
    -bash: voxl-voa-server-configure: command not found
    Here is my version:
    root@qrb5165-rb5:/run/mpa# voxl-version
    system-image: 1.2.1-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Mon Apr 18 20:36:27 UTC 2022 4.19.125
    hw version:   M0054
    voxl-suite:   0.7.0
    Here is my voxl-inspect-services
    root@qrb5165-rb5:/run/mpa# voxl-inspect-services
     docker-autorun       | Disabled  | Not Running |
     docker-daemon        | Disabled  | Not Running |
     voxl-camera-server   |  Enabled  |   Running   |    83.3
     voxl-cpu-monitor     |  Enabled  |   Running   |     0.0
     voxl-dfs-server      |  Enabled  |   Running   |   144.4
     voxl-imu-server      |  Enabled  |   Running   |     0.0
     voxl-mavlink-server  |  Enabled  |   Running   |     0.0
     voxl-modem           |  Enabled  | Not Running |
     voxl-px4-imu-server  | Disabled  | Not Running |
     voxl-px4             |  Enabled  |   Running   |     0.0
     voxl-qvio-server     |  Enabled  |   Running   |    44.4
     voxl-static-ip       | Disabled  | Not Running |
     voxl-streamer        |  Enabled  |   Running   |    22.2
     voxl-tag-detector    | Disabled  | Not Running |
     voxl-vision-px4      |  Enabled  |   Running   |     0.0
    Am I missing something to get Sentinel's VOA to run?
    M 1 Reply Last reply
      Sorry but that page seems to have been erroneously uploaded, it's completely wrong. For sentinel VOA you should follow the normal collision prevention with voxl-vision-px4 page.
      • M mkwan
        • voxl-voa-to-px4
        • voxl-voa-client
        Here is my version:
        hw version:   M0054
        voxl-suite:   0.7.0
        M Offline
        M Offline
        mkwan
        @mkwan said in Sentinel VOA software not available:
        Hi @Alex-Gardner, thanks for looking into this. Does this setup look correct? This should cover the steps listed in voxl-vision-px4.
        Do you think it is because the Sentinel has two stereo cams, ie stereo_front and stereo_rear, instead of a body->stereo_ tf?
        Is the voxl-version the Sentinel shipped with equipped to handle voa with multiple input streams? voxl-suite: 0.7.0
        voxl-inspect-extrinsics:
        #5:
            parent:                body
            child:                 stereo_front_l
            T_child_wrt_parent:    0.079  -0.040  -0.024
            RPY_parent_to_child:   0.0    90.0    90.0
            R_child_to_parent:     0.000  -0.000   1.000
                                   1.000   0.000  -0.000
                                  -0.000   1.000   0.000
        #6:
            parent:                body
            child:                 stereo_rear_l
            T_child_wrt_parent:   -0.030   0.040   0.042
            RPY_parent_to_child:   0.0   -90.0   -90.0
            R_child_to_parent:     0.000   0.000  -1.000
                                  -1.000   0.000  -0.000
                                   0.000   1.000   0.000
        #7:
            parent:                body
            child:                 tof
            T_child_wrt_parent:    0.078   0.000  -0.025
                                   1.000   0.000  -0.000
                                  -0.000   1.000   0.000
        • M Offline
          M Offline
          mkwan
          wrote on last edited by mkwan
          tl;dr: No difference when renaming stereo_front to stereo
          As a test, I edited the config files to rename stereo_front to stereo:
          • voxl-camera-server.conf
          • extrinsics.conf
          • voxl-dfs-server.conf
          • /run/mpa/stereo_front
          Output of voxl-inspect-extrinsics:
          #5:
              parent:                body
              child:                 stereo
                                     1.000   0.000  -0.000
                                    -0.000   1.000   0.000
          I could see stereo_pc via voxl-portal populating successfully, but no change to voa_pc_out.
          Same output from voxl-vision-px4 as before:
          # voxl-vision-px4 -s
          detected platform NOT APQ8096
          loading our own config file
          config file version:        1
          qgc_ip:                     192.168.168.101
          en_secondary_qgc:           0
          secondary_qgc_ip:           192.168.1.214
          qgc_udp_port_number:        14550
          udp_mtu:                    512
          en_localhost_mavlink_udp    1
          localhost_udp_port_number:  14551
          en_vio:                     1
          en_voa:                     1
          en_send_vio_to_qgc:         1
          en_send_voa_to_qgc:         1
          voa_upper_bound_m:          -0.150000
          voa_lower_bound_m:          0.150000
          en_set_clock_from_gps:      1
          en_force_onboard_mav1_mode: 1
          en_reset_px4_on_error:      1
          qvio_auto_reset_quality:    0.000500
          horizon_cal_tolerance:      0.300000
          offboard_mode:              off
          follow_tag_id:              0
          figure_eight_move_home:     1
          en_tag_fixed_frame:         0
          fixed_frame_filter_len:     5
          loading extrinsics config file
          starting geometry module
          starting px4 monitor
          starting px4 mavlink
          starting udp mavlink
          Adding manual QGC IP address to udp connection list: 192.168.168.101
          Added new UDP connection to 192.168.168.101
          starting fixed pose input
          starting vio manager
          starting tag manager
          starting voa manager
          starting control input pipe
          failed to send VOA data out uart to PX4 // note, this eventually does connect
          Connected to voxl-mavlink-server
          Detected PX4 Mavlink SYSID 1
          Connected to voxl-qvio-server
          updating to use imu: imu_apps
          done updating transforms to use imu: imu_apps
          index:  0  dist: none back
          index:  1  dist: none
          index:  2  dist: none
          index:  3  dist: none
          index:  4  dist: none
          index:  5  dist: none
          index:  6  dist: none
          index:  7  dist: none
          index:  8  dist: none
          index:  9  dist: none left
          index: 10  dist: none
          index: 11  dist: none
          index: 12  dist: none
          index: 13  dist: none
          index: 14  dist: none
          index: 15  dist: none
          index: 16  dist: none
          index: 17  dist: none
          index: 18  dist: none forward
          index: 19  dist: none
          index: 20  dist: none
          index: 21  dist: none
          index: 22  dist: none
          index: 23  dist: none
          index: 24  dist: none
          index: 25  dist: none
          index: 26  dist: none
          index: 27  dist: none right
          index: 28  dist: none
          index: 29  dist: none
          index: 30  dist: none
          index: 31  dist: none
          index: 32  dist: none
          index: 33  dist: none
          index: 34  dist: none
          index: 35  dist: none
          index: 36  dist: none
          index:  1  dist: none
          index:  2  dist: none
          index:  3  dist: none
          index:  4  dist: none
          index:  5  dist: none
          index:  6  dist: none
          index:  7  dist: none
          index:  8  dist: none
            I just tried this on a fresh flash of platform 1.3.1-0.8 and everything seems to be working as intended on my end. My process:
            1. Flash platform release (didn't wipe data directory so my camera calibration remained)
            2. ADB in and run voxl-configure-mpa -p -f sentinel enabling most of the necessary services and setting up the cam->board extrinsics
            3. Run voxl-configure-dfs factory_enable to enable dfs
            4. Run voxl-vision-px4 -s to see the voa debug. It takes ~1 second for the full dfs pipeline to wakeup but eventually I start seeing data like this:
            index:  0  dist: 0.84m back
            index:  1  dist: 0.89m
            index:  2  dist: 1.18m
            index:  3  dist: none
            index:  4  dist: none
            index:  5  dist: none
            index:  6  dist: none
            index:  7  dist: none
            index:  8  dist: none
            index: 15  dist: 0.91m
            index: 16  dist: 0.75m
            index: 17  dist: 1.03m
            index: 18  dist: 1.17m forward
            index: 19  dist: 1.22m
            index: 20  dist: 1.22m
            index: 21  dist: 1.05m
            index: 34  dist: 0.68m
            index: 36  dist: 0.84m
            index:  3  dist: none
            index:  4  dist: none
            index:  5  dist: none
            index:  6  dist: none
            index:  7  dist: none
            index:  8  dist: none
            Can you give these steps a try and let me know if you're still seeing issues
            • M Offline
              M Offline
              mkwan
              @Alex-Gardner said in Sentinel VOA software not available:
              platform 1.3.1-0.8
              Yes, it worked! I am able to see correct data via voxl-vision-px4 -s and use PX4's Collision Prevention feature.
              The drone was shipped with system-image: 1.2.1-M0054-14.1a-perf and voxl-suite: 0.7.0, but after flashing to Voxl2 Platform 1.3.1-0.8, VOA worked out of the box as described. (Note: during the flashing, I noticed the Sentinel documentation does not list this newest release.)
              To others reading this, some tips:
              1. Use your /data folder to backup any files you don't want wiped, such as changes to /home/root.
              2. In QGroundControl, save your factory params so you don't have to recalibrate your sensors. (Parameters -> Tools -> Save to file...)
              3. Run and save apt list --installed in case there's some apt packages you don't want to forget.
              4. Don't forget to redo the parameters in QGroundControl as mentioned in the VOA documentation.
              Thanks, @Alex-Gardner!
